-1
I am about to publish an Android app project I would like to do it using GPLv3 license to avoid it being used in proprietary projects for now.
If I change my mind in the future, since I am the project owner, may I later relicense it to Apache 2.0?
JP Ventura
  • 209
In general, the principle is that you cannot revoke the GPL license, once it is applied to a particular version of a software.
If you choose to release your software under a new version using a different license, you're certainly free to do that, but all older releases of the code would still fall under the GPL.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
    That last sub-sentence is a bit misleading. You can certainly remove the GPL license from older releases of the code. What you *cannot* do, is force people whom you already licensed the code under GPL to give back the code. IOW: you can remove the GPL from *future* downloads of *older* releases but not *past* downloads. – Jörg W Mittag Apr 18 '16 at 01:25
    @JörgWMittag: The people whom you already licensed the code to under the GPL still have the right to distribute it under the GPL, and the folks they distribute it to are still licensed under the GPL. You cannot revoke rights you've already granted, and that effectively means that you cannot remove the license from older versions of the software. – Robert Harvey Apr 18 '16 at 02:00
    I think you need to change "under a new version" and "but all older releases", because that makes it sound like you can't rerelease the original version under a new license. You certainly can do this. You can take your code, add an Apache License file, remove the GPL License file and upload. The *only* thing that you can't do is tell people who *already downloaded* the GPL version that what they have is now Apache licensed. – Gort the Robot Apr 18 '16 at 02:19
  • Distinguishing licenses based on which download a person used might be technically legal, but it's way too tricky or confusing for other people who may not expect that. It's far better to make such a significant change come along with a bump in the version number (and preferably document it in a list of program history). – TOOGAM Apr 18 '16 at 02:36
  • @StevenBurnap: Sure, but anyone can still get the GPL'd version from someone who obtained the code under the GPL, and that would effectively still make it GPL. – Robert Harvey Apr 18 '16 at 02:49
  • Right, though going from GPL -> Apache involves mostly just removing restrictions. A real world case would be if a company doesn't like the GPL requirement to give source code and pays you money to get an Apache Licensed version of the same thing. That would be a perfectly reasonable thing to do. – Gort the Robot Apr 18 '16 at 03:29
  • @StevenBurnap: They're not restrictions from the point of view of the users of the software; they are *freedoms.* Mostly, the freedom to have access to *all* of the program's source code so that they can use or modify the software as they see fit. Apache is not copyleft, and so doesn't necessarily give them those freedoms. – Robert Harvey Apr 18 '16 at 05:24
  • @RobertHarvey: I always find that somewhere between amusing and annoying when users can't have software because their freedom must be protected :-( – gnasher729 Apr 18 '16 at 22:03
