While I was reading a research paper on concurrency named Software and the Concurrency Revolution (html version). I came across following lines:
Unfortunately, although locks work, they pose serious problems for modern software development. A fundamental problem with locks is that they are not composable. You can’t take two correct lock-based pieces of code, combine them, and know that the result is still correct. Modern software development relies on the ability to compose libraries into larger programs, and so it is a serious difficulty that we cannot build on lock-based components without examining their implementations.
I was thinking, how Java guarantee composable concurrency or even there is a way to produce this scenarios.
And how we can synchronize data in one or more libraries? Can a programmer do it from his program or it is up to library to synchronize things.
If not Java then is there any other language which use lock based concurrency and guarantee composable concurrency?
Following is also taken from same paper:
There are at least three major problems with synchronized methods. First, they are not appropriate for types whose methods call virtual functions on other objects (e.g., Java’s Vector and .NET’s SyncHashTable), because calling into third-party code while holding a lock opens the possibility of deadlock. Second, synchronized methods can perform too much locking, by acquiring and releasing locks on all object instances, even those never shared across threads (typically the majority). Third, synchronized methods can also perform too little locking, by not preserving atomicity when a program calls multiple methods on an object or on different objects. As a simple example of the latter, consider a banking transfer: account1.Credit(amount); account2.Debit(amount)...
Note: Paper was published on September 2005
