Given the set of rules explained in "Clean Code", can one really use for loops? My confusion stems form the fact that a for loop is a low-level construct per se, thus it can only be used at the very lowest level of abstraction, by the book. But then, does it mean that using the loop is forbidden in those pieces of code that belong to a higher level of abstraction, i.e., the pieces of code where functions are being called?
I'm asking because I tried to look at my code from the point of the view of "don't mix low and high level" as per the book and realised I couldn't even write a for loop. That slowed me down to a crawl (slower than my usual turtle slow coding).
iksemyonov
  • 453
    What set of rules? Most of us don't have the book handy. Is your question only directed at those of us who have the book sitting next to our mouse? – Robert Harvey Mar 16 '16 at 22:21
    That said, I'm not buying it. Looping is essentially the only thing that separates the computer from a pocket calculator, so the notion that I would not be allowed to do it somewhere seems ridiculous. – Robert Harvey Mar 16 '16 at 22:23
  • @RobertHarvey Neither do I (don't have the time to read the whole thing), but basically there have been a few articles explaining the idea that high and low level can't belong in the same function (and those articles were explaining / based on Clean Code). See for example http://programmers.stackexchange.com/questions/110933/how-to-determine-the-levels-of-abstraction – iksemyonov Mar 16 '16 at 22:24
  • `foreach(item in shoppingCart) { checkout(item); }` Morally equivalent to a `for` loop, and `checkout()` is about as high-level as you can get. I suppose you could use a `map` function, but that essentially amounts to the same thing. – Robert Harvey Mar 16 '16 at 22:26
  • @RobertHarvey tell you more, it prohibits methods longer than 7 lines, and in mathematical or scientific coding it's plain impossible to achieve. Thus, I'm really at loss whenever I try to think in the terms the book suggests: it declares a lot if not most of the existing code null, void and dead at the moment it's written. Think I'll answer one more question on that book, if that's ok by the site rules. – iksemyonov Mar 16 '16 at 22:27
    Try not to let your thinking process be dictated by what a book says. Rather, let your thinking process be *guided* by that book, and then make up your own damn mind. – Robert Harvey Mar 16 '16 at 22:28
  • See, in general I agree, but many years in a maths school taught me to look for rules and guidelines as well as quality metrics. Guess this approach doesn't really scale to programming. – iksemyonov Mar 16 '16 at 22:29
    Rules are meant to be learned well enough so that you know when it is appropriate to break them. **First rule of Programmers.SE:** random strangers on the Internet can say anything they want about a subject that lacks context. – Robert Harvey Mar 16 '16 at 22:29
    Are the rules that you're referring to on this [cheat sheet](https://www.bbv.ch/images/bbv/pdf/downloads/V2_Clean_Code_V3.pdf)? – Robert Harvey Mar 16 '16 at 22:33
  • First time in my life I see this exact PDF, but, well, if it comes from the author called Robert C. Martin, it may well be it. Looks similar. – iksemyonov Mar 16 '16 at 22:35
    Perhaps you could lift the relevant rules from that cheat sheet and put them in your question. – Robert Harvey Mar 16 '16 at 22:36
  • Well, I'm not that familiar with it. If anything, it looks close to "Code at wrong level of abstraction", "High cohesion" and "Low coupling", at least that's what the article mentioned. – iksemyonov Mar 16 '16 at 22:43
  • The example provided there is `a PercentageFull property on a generic IStack`, which is *clearly wrong.* – Robert Harvey Mar 16 '16 at 22:44
  • Aha, this one is closer: Methods Should Do One Thing "Loops, exception handling, … encapsulate in sub-methods" , Methods Should Descend 1 Level of Abstraction. – iksemyonov Mar 16 '16 at 22:45
    [**Functions Should Descend Only One Level of Abstraction (CC) / Composed Method (IP)** - Split up large methods so that they deal with just one level of abstraction, delegating work to other methods for work on a lower level of abstractions. Not only does this make the code easier to understand, you may also discover reusable bits of code this way. Doing this is easy to do with the support modern IDE's have for refactoring operations such as "Extract Method".](http://blog.xebia.com/clean-code-vs-implementation-patterns/) Absolutely true. But that has nothing to do with loops. – Robert Harvey Mar 16 '16 at 22:46
    Keep in mind many programmers don't take anything Uncle Bob says as gospel. I've read enough embarrassing posts by him about functional programming, for example... :/ – Andres F. Mar 17 '16 at 16:09
  • Don’t trust anyone calling himself “uncle”. – gnasher729 Aug 22 '22 at 05:56
I think you refer to the principle "One level of abstraction per function" in Clean Code.
This general principle makes perfect sense: a level of abstraction is the hiding of lower levels of details, in order to master the complexity. Mixing different levels of abstraction therefore implies that your attempt to hide/encapsulate complexity of higher level is broken by the simultaneous use of lower level, which requires a clear understanding of how both levels are interrelated. So you loose benefits of encapsulation.
This has nothing to do with the value judgment that you give to different instructions. If you consider for to be low level, you could consider the same for if, while, return, function calls, etc...
So you can use the for in your design, without breaking the rule.
Remark: What could break the rule is if you would use a for loop to access a level of detail that should be hidden. For example, if you'd use in a high level function a for to iterate through an array, when you already have a higher level function to perform a search.
Christophe
  • 74,672
  • 115
  • 187
  • I guess you are on the wrong track, all control structures can be seen as low level constructs, and if ones takes to the extreme, this would indeed mean not to use `for` on the higher levels. See my answer why. – Doc Brown Mar 17 '16 at 12:00
  • To be honest, I don't know if my track is right or yours is wrong. But one shall not confuse a fundamental language structure with a low level structure. Let's make an analogy: take any high level philosophical text of your favorite author about the sense of life, a text full of abstract words: only high level concepts. Such text will certainly not bother us with low level details such as atoms and quarks. But it will certainly use prepositions, articles, conjunctions and other fundamental language structures. Will you really get the impression of mixing levels of abstraction then ? – Christophe Mar 17 '16 at 20:49
  • Well, we can agree upon the "One level of abstraction per function" rule is not about forbidding control structures on higher abstraction levels. But my point is that this this rule does not cover what "separation of concerns" will cause for high and low level constructs when thought to an end. When "high level constructs" will exclusively be used for integration of lower level components, and only lower level components contain "business logic", in the end that means there will be no control structures at the higher level components.... – Doc Brown Mar 17 '16 at 21:42
    But don't get me wrong: I am not saying that is the only possible or right way of writing "clean code". It is just one interpretation, maybe a little bit extreme, but actually a correct interpretation the OP came up by himself by thinking about what the clean code rules might imply. And indeed, I think it is possible to create real-world programs that way (maybe "more cleaner than anyone needs"). – Doc Brown Mar 17 '16 at 21:44
Firstly, it's worth remembering that the book Clean Code suggests guidelines rather than rules. It seems that the specific guideline referred to here is the recommendation that you Don't mix levels of abstraction.
It's worth remembering that this advice is specifically referring to class interface design. (i.e. public/protected methods, public properties - anything which is exposed to something which uses a class)
Consider a high-level abstract class Animal, from which a low-level concrete class Dog class is derived. The Dog may include a method called Bark(), which would seem appropriate for Dog's level of abstraction..
However, there is nothing to stop the Bark() method being included in the interface of the abstract Animal class; but if other classes derived from Animal could not make use of the Bark() method then this would be a code smell. Anything derived from Animal is forced to inherit (and even override) the Bark() method, even if a Bark() method is wholly inappropriate to the concrete class.
i.e.
public abstract class Animal
     public abstract void Bark();
public class Elephant : Animal
     public override void Bark()
         // HUH?!
The advice is generally encouraging you to think carefully about what methods you provide in high-level abstractions/interfaces; to avoid forcing derived ("lower level") classes to inherit, override or implement any methods or behaviour which do not logically belong to the lower level class.
Language constructs such as the for keyword are unrelated to class interfaces; and the advice regarding "mixed levels of abstraction" doesn't really make any sense with regard to method implementations.
Ben Cottrell
  • 11,656
  • 30
  • 41
Your question title is a little bit provoking, since from the text its clear, what you mean is "Are for loops allowed in the “Clean Code” set of rules, except for low-level components". So this is how I interpret your question.
I think this is IMHO a very interesting question, not so trivial as it might look at a first glance. I would not interpret this just in the light of "Clean code" by Bob Martin, but also when looking at "Clean Code" as it is advertised by people like Ralf Westphal (german reference: http://clean-code-developer.de/, try Google translate). His suggestion for what he calls IODA architecture brings the principle "don't mix low and high level" to the extreme. And indeed, in this architecture, you won't find any "for" loops (and no other control structures like conditionals) at the "higher level components" - only at the lower level. The purposes of higher level components in this architecture is exclusively for "plugging" lower level components together.
If you take this really to the extreme, you need to change the structure of every function like
  function HighLevelfunction()
      sum=0
      for i = 1 to upperLimit  logic
           sum+=LowLevelFunction1(i)
      return sum
into
  function LowLevelfunction2( func funcAsParameter)
      sum=0
      ' just for demonstration purposes, think not of reusage here
           sum+=funcAsParameter(i)
      return sum
Note in the first version HighLevelfunction depends on LowLevelFunction, in the second LowLevelfunction2 does not depend on any other function anymore. In the second one, you will need a "higher level" function where the call LowLevelfunction2(LowLevelFunction1) takes place - but this is simply an integration step, there will be no "for" loop at the higher level needed.
However, doing this for each and every function in a real world program this will probably become soon very impractical. I (and I guess most other programmers, too) draw the line between high level and low level functions, classes or components on a much coarser granularity. One has to find the right balance, and make sure not to write clean code just for the sake of cleanlyness. Or, to say it with the words of Ralf Westphal, "Don’t Let Cleaning-Up Go Overboard".
Glorfindel
  • 3,137
Doc Brown
  • 199,015
  • 367
  • 565
  • I think the take-away is that `LowLevelfunction2` now really is `sum` and therefore a reusable algorithm. The C++ community has taken this kind of algorithm extraction quite far which I believe is a good thing. Indeed, I would consider an explicit loop to compute a sum in a function that has other business than just computing a sum a code smell. – 5gon12eder Mar 17 '16 at 11:06
  • @5gon12eder: you comment shows me my example was not well choosen to show my point. This question is about clean code, functions for abstractions, not for reuse, and the question was if this kind of decoupling should be done always, not just when there is a possible resuage scenario. I will edit the question to make this more clear. – Doc Brown Mar 17 '16 at 11:45
