For a system that consist of multiple services calling each other (e.g. Front End -> Backend -> Storage), I often heard people using terminology such as "downstream" or "upstream" services. I'm not clear which direction these mean. Data flows in both direction. Requests flow from more user-facing to more backend service, but responses flow in the opposite direction, so it seems to me one either way can be argued
12Interestingly, the HTTP specification RFC 7230 happens to include definitions of the terms "upstream" and "downstream" in Section 2.3: https://tools.ietf.org/html/rfc7230#section-2.3 – Jack Jan 11 '18 at 22:19
The downstream services are the ones that consume the upstream service. In particular, they depend on the upstream service. So the front-end is downstream to the back-end because it depends on the back-end. The back-end can exist meaningfully without the front-end, but the front-end doesn't make sense without the back-end.
The dependency doesn't have to be as strong as I made it out to be in the previous paragraph. More generally, upstream services don't need to know or care about the existence of downstream services. Downstream services care about the existence of upstream services, even if they only optionally consume them.
- 3
- 2
- 6,591
- 2
- 13
- 21
I think it should be *"downstream services"* in place of *"services downstream"*. – Nawaz Aug 25 '18 at 17:30
easy metaphor for remembering which is upstream and which is downstream https://softwareengineering.stackexchange.com/a/395738/74944 – GWed Jan 30 '20 at 10:34
It takes some real contortion to think of it like this answer. Much easier to think in terms of the dependency chain and use the river analogy. – Kias Mar 06 '20 at 22:58
This seems to not fully agree with https://tools.ietf.org/html/rfc7230#section-2.3 Upstream and downstream are with respect to messages, which go both directions. – McKay Sep 03 '20 at 21:05
The best way to think about this is to think of a river.
The downstream part of the river cant get any water unless it comes from upstream i.e. downstream is dependent on upstream for its water.
If someone destroyed the downstream part of the river, this would have no impact upstream. If someone destroyed the upstream part of the river, this would impact downstream i.e. it wouldnt get any water.
So downstream services depend on upstream services. If the upstream services are removed, the downstream services wont work properly.
- 3,085
- 5
- 26
- 43
And for the extra bit of clarity; in a standard CRUD client-server relationship, both ends are both upstream and downstream to each other. The client can't get any data or updates if the server's down, and the server doesn't have any instructions to execute if there isn't a client. – Delioth Aug 07 '19 at 16:53
9@Delioth disagree. The backend can have many clients, but doesn’t depend on any single one of them. If you removed a client, backend would still work. The client can have many backends it could use. If one backend is removed without the client knowing, the client can’t work properly. Client is downstream. Backend is upstream. – GWed Aug 07 '19 at 16:56
I have seen nginx/apache in reverse proxy context calling the backend services as upstream services. Then I saw an API gateway called ocelot that call the backend services as downstream. That is the reason why I'm reading this thread. – rineez Sep 29 '21 at 04:52
1I guess it is just a difference caused by some people thinking about it in terms of flow of message/control, while some others thinking in terms of flow of dependency? – rineez Sep 29 '21 at 05:27
This discussion shows the terms are confusing when used in context of dependencies and bidirectional data flows (like request+response). I therefore suggest to only use them when the directionality is very clear: up=before, down=afterwards (e.g. batch processing) – Efrain Aug 30 '23 at 12:42
Unfortunately there are differences in opinion on the meaning of upstream/downstream. When talking about system architecture, I define it as follows:
Given a system of concern, systems that initiate messages/data exchange to the system of concern are upstream systems, and systems that the system of concern depends on (i.e. those to which my system initiates data exchange) are downstream systems.
This link from ibm describing interactions with one of their products corroborates this view: Integrating with upstream and downstream systems
An upstream system is any system that sends data to the Collaboration Server system. A downstream system is a system that receives data from the Collaboration Server system.
Given the terminology 'upstream' and 'downstream' it may help to make an analogy with a river. If you drop a message (data) in the river it flows from upstream (initiator) to downstream (receiver).
Anecdotally, I've found that architects and middleware developers use this definition and web developers the opposite (maybe due to 'upload'ing).
With Event timelines, an event is upstream when it happens before a point on the timeline (i.e. triggers another event) and downstream when it happens afterwards (i.e. received the event). What is upstream and what is downstream in a sequence of events, therefore, depends on where you are in the timeline. An event can be both downstream and upstream, depending on whether your starting point is before or after it.
As @Jack notes RFC7230 tools.ietf.org/html/rfc7230#section-2.3 has this:
The terms "upstream" and "downstream" are used to describe
directional requirements in relation to the message flow: all
messages flow from upstream to downstream
1This is just confusing because you are confused yourself on the matter. There is no discrepancy, just a difference in point of view. – Martin Maat Jan 16 '19 at 07:02
@MartinMaat I disagree with your first sentence, and agree with your second. – roj Jan 17 '19 at 03:57
Not sure which context this reply is in reference to--apparently not web apps and microservices: "systems that initiate messages/data exchange to the system of concern are upstream systems" --the term "initiate" suggests a request (e.g. a GET) from a dependent--i.e. downstream system (not upstream system) per the other answers. – user1527469 Jul 27 '21 at 16:19
This may be more a linguistic and geographical problem than a technical one.
The request for information goes upstream. It comes from a downstream system.
The response to the request for information (the requested information) goes downstream and is sent by an upstream system.
There is no difference between the classic IBM view and today's web community's use of the terms.
A service provider (server) will be located upstream compared to a service consumer and sends information downstream to the consumer.
A service consumer (client) will be located downstream compared to the service provider and sends requests upstream to the provider.
Theoretically roles of physical systems could change instantly and so would the direction of the stream between those systems. In a peer-to-peer network this may be the case.
The terms uploading and downloading are client centered terms. From the client's perspective a request is uploaded and a response is downloaded, which is consistent with the stream metaphor.
- 18,218
- 3
- 30
- 57
