Consider a test suite like this:
public class MyTestSuite {
@Test
public void test_something() {
testHelperMethod("value11", "value12", "value13");
@Test
public void test_something_else_meaningful_name() {
testHelperMethod("othervalue21", "othervalue22", "othervalue23");
private void testHelperMethod(String value1, String value2, String value3) {
// set up part (independent of value1, value2, value3)
// action part (dependent on values)
// assertion part (dependent on values)
// tear down part (independent of values)
In other words, all the test cases are executed via a single, parametrized helper method, which is structured according to the arrange-act-assert schema. The test cases just call this method with various parameters, according to what exactly needs to be tested.
Question: what is the disadvantage, if any, of structuring the tests like this, and does this (anti?)-pattern have a common name?
Remarks
I tried to Google for it for a long time, including on SO and on the blog, but could not find anything useful till now.
This question is the closest I found, but the answers there address other aspects/problems, namely:
- assertions/setup code intermixed (not the case here, as all assertions are at the end of the helper method)
- more assertions per test (also the case in my example, but I think this is an unrelated issue)
- responsibility of helper method is not clear: I think in my case it is clear, just it is different from the 'traditional' one
To be more precise, the assertion part in
testHelperMethod
is also a separate utility method (called with many-many parameters), but I guess that does not matter much for the question. (I.e.: why is it bad practice to delegate testing to helper methods, if at all?)In case this matters, this is an integration test, but I suspect that the answer would be the same for unit-tests as well.
EDIT: Changed the names of the test cases to avoid confusion (Previously, they were called test1
, test2
. In fact, the tests in the project in questions do have meaningful names, I had just made this simplification myself.)
