I am currently charged with taking over a lot of code that is written with fields names placed into Java constant at the top of the file, and then the SQL queries constructed using string concatenation with the field names. At the top of the file is the following block:
private static final String TABLE_VALID_USER = "valid_user_table";
private static final String TABLE_USER_MANAGEMENT = "V1_USER_MANAGEMENT_TABLE";
private static final String TABLE_ROLE_DEFINITION = "V1_ROLE_DEFINITION_TABLE";
private static final String TABLE_ROLE_MANAGEMENT = "V1_ROLE_MANAGEMENT_TABLE";
private static final String TABLE_USER_STATUS_DEF = "V1_USER_STATUS_DEFNITION";
private static final String COLUMN_NAME_OPEN_ID = "hashed_open_id";
private static final String COLUMN_NAME_INTERNAL_USER_ID = "internal_user_id";
private static final String COLUMN_NAME_USER_ID = "hashed_open_id";
private static final String COLUMN_NAME_USER_NAME = "name";
private static final String COLUMN_NAME_ROLE_ID = "role_id";
private static final String COLUMN_NAME_ROLE_NAME = "role_name";
private static final String COLUMN_NAME_USER_STATUS_CODE = "status_code";
private static final String COLUMN_NAME_USER_STATUS_NAME = "status_name";
private static final String DEFAULT_USER_STATUS = "Pending";
private static final String AS_NAME_COUNT = "cnt";
Later in the code, there are SQL queries that are constructed like this using these constants in the string construction.
What you have to remember is that these are very far apart in the code, so to find out what a field name is, you have to scroll up and down all the time. To be able to read the query, requires a lot of mental exercise. I realize for the original programmer this is not a big deal, because the column might be hashed_open_id but that programmer felt that the constant name COLUMN_NAME_USER_ID was a perfectly acceptable replacement for that. The good news is that this is explained to be the user id.
The bad news is that the actual column in the database is named hashed_open_id which is not obvious. When you read the code, you have learn this new, arbitrary symbol COLUMN_NAME_USER_ID and you have to remember that it really means hashed_open_id and you have to do this for every column in the table! It would seem to double the amount of things that you have to learn in order to read the code.
To understand the query, you need to have knowledge of the database. When using the database, you have to have the real column names in mind. The Java constant symbols are not helpful when dealing with the SQL data browser.
String sql =
    "SELECT "
    + "COUNT(" + COLUMN_NAME_OPEN_ID +") as " + AS_NAME_COUNT + ", "
    + "FROM "
        + TABLE_VALID_USER + " "
    + "WHERE "
        + COLUMN_NAME_OPEN_ID + "= ? "
Wouldn't it be better to just use the real table names and the real column names directly? If you did so, the query would be in the code as:
    String sql =
        "SELECT COUNT(hashed_open_id) as cnt, "
        + "FROM valid_user_table "
        + "WHERE hashed_open_id= ? ;";
This latter query is clearly easier to read and understand, especially if you know the actual table structure. You can easily see exactly what the table name is being manipulated, and what columns are involved. Go back to the original, and try looking up the values in the constants to arrive at the same understanding. And you HAVE to know the table structure because it is manipulated by other classes and other programs. Does anyone really believe that using constants as an extra level of symbol redirection in this way is a benefit?
Theoretically, if you decide to change a column name, then you go to one place, and it propagates through the entire code. Hey, that is cool, but how often do you do that? And it only changes this class ... there are other classes and programs, some written in different languages, that manipulate the table. One change of the constant will never change everything.
Readability is important. Isn't the ability to read, review, and quickly understand code by the programmers that are going to maintain the code more important than the rare convenience of changing a column? Consider code that lives for 10 years. How many new programmers will have to read this code? How many times will a column name change?
And, imagine that you do need to change a column name from hashed_open_id to standard_user_id is it really that hard to do a search and replace? You probably had to do the same thing in some SQL scripts used to create the table. The constant is not a universal symbol for the column name. The column name is a universal symbol for the column name. Why not use it directly everywhere? The point of a column name is to be a symbol for the data in the column.
Can anyone think of any reason that an extra level of indirection to make Java constants for each column is worth the problems that it causes?
AgilePro
  • 312
  • Eghads. Go find your .pom file and add ` org.hibernate hibernate-core 5.1.0.Final ` before you go any more insane. –  Mar 08 '16 at 03:38
  • I guess you are saying that we should not be fiddling with SQL queries, and use a more advanced/sane mapping from the SQL straight to Java objects, am I right? That is probably a wise suggestions, but my question here is more about the use of constants, and less about the use of SQL. There are other non-SQL places where constants are being used just as egregiously. – AgilePro Mar 08 '16 at 04:01
    There are many approaches to this. And I'm perfectly fine with SQL queries. However, I *really* like being able to copy the string out of the text and paste it into whatever SQL editor I have handy and run it. These constants work against such things. Furthermore, I like IntelliJ as an IDE. It has useful things like tab completion and intellisence on strings that look like SQL within a Java file - this again makes that not work as well. For me, in my environment, the structure you have described works against my productivity in several ways. –  Mar 08 '16 at 04:04
  • Aside, if you like SQL a bit more (I haven't use this yet - but I like its idea), glance at [MyBatis](http://www.mybatis.org/mybatis-3/getting-started.html). But again, I would urge you to look at your own productivity and consider its utility or lack there of. I can only speak for my environments. –  Mar 08 '16 at 04:06
I agree with what you say. Having worked in several companies on a variety of platforms I have not seen the level of abstraction you describe. Occassionally I will write code snippets and construct SQL from them, but couched in application and problem domain terms, not DB design terms. For example
where-cluase-for-employee = "<several lines of SQL>"
whereas
where-clause-for-contractor="<a different complex predicate>".
SQL is a programming language. No one would consider it best practice to construct a Java method call as a string then execute it. Why would this be done for SQL?
Maintainability and ease of change are important, too. I believe that code should be written with consideration for the unfortunate on-call person who has to fix it at 3am, never having seen it before. Make code efficient and compact by all means, but not so much that the writer's the only person who can understand it.
There is a different approach which can abstract table and column names from the Java and keep SQL as a compact block. It can also improve runtimes, depending on the applications workload. Put the SQL into a stored procedure. Good SP naming conventions will say exactly what it does (read_count_by_user for the example in the question), and the contract between application and SQL is defined. If the returned columns change the application must change, too, but this is a problem you face currently. Impact analysis is a text search of the source code. Modularity is improved. Tuning and re-writes can be done on a per-procedure basis.
If the developers' only gripe is with the DB naming convention ask for a set of views to be defined with developer-friendly names for tables and columns. For the simple use cases shown these will have no impact on performance.
Michael Green
  • 903
Just for info. Since the fields are constants (static final), I can tell you that the byte code resulting to the compilation will be exactly what you want.
The compilation will replace every constants to its value, so your query will be a String (might be a concatenation of String, not really sure).
Using your examples
This is the java file :
String sql =
    "SELECT "
    + "FROM "
    + "WHERE "
And here is the byte code, the class file:
String sql =
This approch of code has the advantage to be more secure if you change a fields, no need to check all the code. I used this design sometimes... This is probably why you have some difficulties to understand why the user_id is actually the hashed_open_id, probably at one point, the user_id column where present but some updates remove this column to used the hashed_open_id one. It's simpler to read if the constant name is well choosen.
EDIT :
I invite you to try some generic code on constants to find out that you can update the constant value without problem but every place you use it will keep the value at the compilation.
AxelH
  • 109
IMO that practice only makes sense if they were trying to make a graphical, point-and-click, ad-hoc query builder for end-users, and even in that case I would use JDBC metadata to pull out column names.
Otherwise I see no practical advantages, only disadvantages.
Tulains Córdova
  • 39,201
  • 154
The anwer: probably for template code, to hundredfold being copied and customized´.
Refactoring needs care. Refactoring to make the code just a bit better, often does not pay. A more radical refactoring is better.
Here: simply filling in the constants (could be automized), especially manually, just gives work.
The old state is bad, and my guess is, that the code results from copied queries, copied code. It would be a good time, to check code-copies. These will no longer easily be found after refactoring. Can don't-repeat-yourself be applied? How does the code fetch generated keys?
It would be a good moment to see whether things can be improved, try-with-resources, JPA, maybe SQL as declarative data or whatever.
Also this kind of refactoring should not be mixed with business logic changes. Think how unnice it would be if manually substituting a column name replaced the wrong column. Nice debugging new code.
Joop Eggen
  • 2,011
