Background:
System call overhead is much larger than function call overhead (estimates range from 20-100x) mostly due to context switching from user space to kernel space and back. It is common to inline functions to save function call overhead and function calls are much cheaper than syscalls. It stands to reason that developers would want to avoid some of the system call overhead by taking care of as much in-kernel operation in one syscall as possible.
Problem:
This has created a lot of (superfluous?) system calls like sendmmsg(), recvmmsg() as well as the chdir, open, lseek and/or symlink combinations like: openat
, mkdirat
, mknodat
, fchownat
, futimesat
, newfstatat
, unlinkat
, fchdir
, ftruncate
, fchmod
, renameat
, linkat
, symlinkat
, readlinkat
, fchmodat
, faccessat
, lsetxattr
, fsetxattr
, execveat
, lgetxattr
, llistxattr
, lremovexattr
, fremovexattr
, flistxattr
, fgetxattr
, pread
, pwrite
etc...
Now Linux has added copy_file_range()
which apparently combines read lseek and write syscalls. Its only a matter of time before this becomes fcopy_file_range(), lcopy_file_range(), copy_file_rangeat(), fcopy_file_rangeat() and lcopy_file_rangeat()...but since there are 2 files involved instead of X more calls, it could become X^2 more. OK, Linus and the various BSD developers wouldn't let it go that far, but my point is that if there were a batching syscall, all(most?) of these could be implemented in user space and reduce the kernel complexity without adding much if any overhead on the libc side.
Many complex solutions have been proposed that include some form special syscall thread for non-blocking syscalls to batch process syscalls; however these methods add significant complexity to both the kernel and user space in much the same way as libxcb vs. libX11 (the asynchronous calls require a lot more setup)
Solution?:
A generic batching syscall. This would alleviate the largest cost (multiple mode switches) without the complexities associated with having specialized kernel thread (though that functionality could be added later).
There is basically already a good basis for a prototype in the socketcall() syscall. Just extend it from taking a array of arguments to instead take an array of returns, pointer to arrays of arguments (which includes the syscall number), the number of syscalls and a flags argument... something like:
batch(void *returns, void *args, long ncalls, long flags);
One major difference would be that the arguments would probably all need to be pointers for simplicity so that the results of prior syscalls could be used by subsequent syscalls (for instance the file descriptor from open()
for use in read()
/write()
Some possible advantages:
- less user space -> kernel space -> user space switching
- possible compiler switch -fcombine-syscalls to try to batch automagically
- optional flag for asynchronous operation (return fd to watch immediately)
- ability to implement future combined syscall functions in userspace
Question:
Is it feasible to implement a batching syscall?
- Am I missing some obvious gotchas?
- Am I overestimating the benefits?
Is it worthwhile for me to bother implementing a batching syscall (I don't work at Intel, Google or Redhat)?
- I have patched my own kernel before, but dread dealing with the LKML.
- History has shown that even if something is widely useful to "normal" users (non-corporate end users without git write access), it may never get accepted upstream (unionfs, aufs, cryptodev, tuxonice, etc...)
References:
