In order to run complex simulations, I need to do preprocessing of data from various data sources. This is done by a bunch of Postgresql scripts. However, having only these is unsatisfactory, because they are not very intelligible, maintainable etc. I want to express the data preprocessing using BPMN/BPEL, which would allow me to graphically visualise
  • the different data sources and sinks
  • the flow of data between them
  • filtering of data according to some conditions
  • merging of data
  • transformations on the data (which are usually simple computations)
Is there a possibility of attaching Postgresql snippets to my BPMN or BPEL model, such that I just can run the BPMN/BPEL in order to execute the data processing?
Christophe
  • 74,672
  • 115
  • 187
tillmo
  • 103
  • what language / technology to take up next is explicitly off-topic per [help/on-topic]. See http://meta.programmers.stackexchange.com/a/6486/40980 – gnat Feb 10 '16 at 10:45
    OK, have reformulated my question such that hopefully now it is in scope. – tillmo Feb 10 '16 at 12:06
You could do that with BPMN tool that are available today as they usually provides layer to connect to external system or database. By example, Bonita BPM has a feature called "connector" to integrate third-party systems.
As far as the BPEL that I'm not sure as this language is mainly designed to orchestrate web-services, so unless you have an web-services layer to interface your PostGreSQL DB, I don't think it would be a good option.
Another option you should consider is using an ETL tool (Extract, Transform, Load). It's a concept (not a standard, as BPMN is) that usually uses for data integration between heterogeneous systems.
lio
  • 26
