I’m currently building a dashboard to view some analytics about the data generated by my company's product. We use MySQL as our database. The SQL queries to generate the analytics from the raw live data can be a bit complicated and take long time to process. So I put in place some batches that run every day or every hour, query this live data and generate the analytics and store this in some special tables that are queried only by the dashboard. It works well but the drawback is that the analytics are not real-time.
So I would like to know what is the best practice for my requirements. I don’t need strict real-time but near real-time of one or a few minutes.
I would like to know if replicating the live data from MySQL to something like hadoop or Elasticsearch would be a good solution.
Julien
  • 141
    Whenever somebody asks for realtime analytics, ask how quickly they can act on the information. Up to the minute data gives suits hardons but if it takes the business 30 days to do anything about it there's no need to engineer a realtime data feed. – Sean McSomething Feb 04 '16 at 07:31
  • Using a technology such as Elastic could ease the load on primary database servers, which is a good idea. Although the real question really is, how important it is to have real real time statistics. – Andy Feb 04 '16 at 07:32
  • The real real time is not super important actually. For Elasticsearch I'm not sure if I should have a batch that copy the data from mysql to Elasticsearch or insert the data in Elasticsearch at the same time as I insert it in MySQL – Julien Feb 04 '16 at 08:43
There are multiple things to consider in your case. What program are you using to create your dashboard? There are tools, such as Tableau that could help via creation of extract - though this may cost money.
You could try using PostgreSQL - it is known to be faster than MySQL and it is free. You could set up your batch process to real time where it cleans up data and saves in PostgreSQL, where you can point your dashboard.
If you have the budget, and the flexibility to store data on the cloud, look into Google Big Query. You could set up a batch process within Google Big Query that uses nodes which process data at a really fast pace (we used it at my company to improve our processing times from 22 hours to 2 hours).
Try optimizing the scripts using indices as well. This may improve processing times - may be not too much, but should help a little if you want to improve performance.
Hope this helps.
madham
