I've recently had an argument with a colleague about using getters (without setters) in a view-model classes used by XAML.
Example:
public string FullName
get
return $"{FirstName} {LastName}";
//call OnPropertyChanged("FullName") when setting FirstName or LastName
His argument was that you should only ever create get/set pairs which use a private field (with the setter raising the PropertyChanged
event if the value has indeed been changed).
Example:
private string _fullName;
get
return _fullName;
set
if (value != _fullName)
_fullName = value;
OnPropertyChanged("FullName");
//Set FullName when setting FirstName or LastName
I, on the other hand, think it's fine to use getters (which calculate the output on the fly), provided they aren't updated all the time via too many PropertyChanged
calls.
I don't think my colleagues approach is bad - I just think it's way more busy work which might simply be not needed. However he was sure my approach is bad and should be avoided at all cost.
As a counter example I pointed out that the MVVM base class from DevExpress has RaisePropertyChanged
and RaisePropertiesChanged
(for refreshing multiple properties) methods ready for use - both of which wouldn't be needed if all the properties were get/set pairs (the DevExpress base class also exposes a SetProperty
method for use in setters, which also includes a PropertyChanged
call). His argument was that "well, people are stubborn, keep doing it wrong, so DevExpress simply added those methods to make sure people are happy" which I found... odd, to say the least.
So what's the take here? Is it bad design to use getters in view-models designed to be used by XAML?
EDIT: I forgot to mention... my colleague also made the claim that using get/set pairs will always be faster. That does seem to be true as far as updating the UI is concerned, but he also used this as an argument that getters shouldn't ever be used. The whole argument started when I had a bit of performance issues when populating a data grid with more (i.e. 12k) rows where my VM used quite a few getters...
