Many coverage tools evaluate an entire project, including unit test code itself. In VS 2013, the Analyze Code Coverage/All Tests option includes test code in its report. OpenCover does so as well I believe. In Eclipse, a Maven project with the typical src/main/java and src/test/java setup, EclEmma will report coverage for both main and test code
This seems of minimal value to me, except for possibly ensuring that all tests are actually being executed. With test code included, the coverage % is often artificially high since often the tool will report close to 100% coverage for test code, which can skew the entire project above a benchmark level (say 80%) that it might not have otherwise achieved.
Are there legitimate reasons to include test code in coverage? Or should I continue filtering it out when automating our coverage reporting?
gnat
  • 21,442
  • 112
  • 288
Dan1701
  • 3,118
  • it have never happened to me that test code was included in coverage, can you give more details on what tool does that? – gnat Feb 02 '16 at 08:16
    @gnat In VS 2013, the Analyze Code Coverage/All Tests option includes test code in its report. OpenCover does so as well I believe. – Dan1701 Feb 02 '16 at 08:30
  • these seem to be .Net tools, have you seen this at other platforms? – gnat Feb 02 '16 at 08:48
    I think the question is valid even if few (or no) tools actually exhibit this behavior, but yes, in Eclipse, a Maven project with the typical src/main/java and src/test/java setup, EclEmma will report coverage for both main and test code – Dan1701 Feb 02 '16 at 09:02
    @gnat dotCover for VS works this way too. You've gotta filter it out. Drives me nuts. – RubberDuck Feb 02 '16 at 09:27
  • I'm finding it frustrating that SonarQube has no concept of separate metrics for test and production code - I'd like confirmation that test code is near 100% (some test-harness code for reporting failures might be unexercised, though I would normally arrange to test that too), but don't want to artificially inflate numbers that might mislead our stakeholders. – Toby Speight Jan 22 '22 at 16:01
I wouldn't say reasons exactly but they do provide a good sense check. All tests being the same (not attributed), you'd expect this to be 100% for a full run. Anything less than this suggests you have dead code which could be removed.
For CI builds, it is quite common to ignore integration tests so it is useful (for me as a build manager) to see this as I know the solution under test has an integration element or similar.
It can also be a smoking gun for developers who are seeking to hide their broken tests with the Ignore attribute. We had one cowboy who broke the tests and then simply added others to cover it up. The test count remained the same but the coverage went down over time. Needless to say he was soon shown the door!
Robbie Dee
  • 9,717
  • 53
  • I hadn't thought about seeing what % of the tests had run, or dead code detection in the test project. ++! – RubberDuck Feb 02 '16 at 11:40
  • I understand this and thank you. I added code to our CI so we get this as an extra metrics because in normal situations i agree suspicion in the raised question that it should be included normally. – Lothar Apr 02 '21 at 20:06
