How would I write a unit test, say JUnit, for validating an XML file?
I have an application that creates a document as an XML file. In order to validate this XML structure, do I need to create an XML mock object and compare each of its elements against the ones in the 'actual' XML file?
IF SO: Then what is the best practice for doing so? e.g. would I use the XML data from the 'actual' XML file to create the mock object? etc.
IF NOT: What is a valid unit test?
gnat
  • 21,442
  • 112
  • 288
Mohammad Najar
  • 203
To validate an XML file, you first need an XML Schema Definition (XSD) that describes the structure of a valid XML document. You can find the specification for XSD files at W3C.
Going into how to build the XSD requires knowing how your XML should be structured.
For detailed information about the actual Java implementation of this, check out What's the best way to validate an XML file against an XSD file? on StackOverflow.
Relevant code from that post:
import javax.xml.XMLConstants;
import javax.xml.transform.Source;
import javax.xml.transform.stream.StreamSource;
import javax.xml.validation.*;
URL schemaFile = new URL("http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd");
Source xmlFile = new StreamSource(new File("web.xml"));
SchemaFactory schemaFactory = SchemaFactory
    .newInstance(XMLConstants.W3C_XML_SCHEMA_NS_URI);
Schema schema = schemaFactory.newSchema(schemaFile);
Validator validator = schema.newValidator();
try {
  validator.validate(xmlFile);
  System.out.println(xmlFile.getSystemId() + " is valid");
} catch (SAXException e) {
  System.out.println(xmlFile.getSystemId() + " is NOT valid");
  System.out.println("Reason: " + e.getLocalizedMessage());
Adam Zuckerman
  • 3,715
  • So validating an XML only means to validate against its schema and not against a mock XML, correct? – Mohammad Najar Jan 30 '16 at 00:29
    You can do either, but I would recommend the validation using the schema. It will be more robust of a comparison than verifying the mock matches what you expect. – Adam Zuckerman Jan 30 '16 at 00:32
  • Beware that xsd can create a hyper rigid schema. Take the time to understand how schema changes will impact you with respect to forwards/backwards compatibility. – kojiro Jan 30 '16 at 14:00
