27
In TDD there is Arrange Act Assert (AAA) syntax:
[Test]
public void Test_ReturnItemForRefund_ReturnsStockOfBlackSweatersAsTwo_WhenOneInStockAndOneIsReturned()
    //Arrange
    ShopStock shopStock = new ShopStock();
    Item blackSweater = new Item("ID: 25");
    shopStock.AddStock(blackSweater);
    int expectedResult = 2;
    Item blackSweaterToReturn = new Item("ID: 25");
    //Act
    shopStock.ReturnItemForRefund(blackSweaterToReturn);
    int actualResult = shopStock.GetStock("ID: 25");
    //Assert
    Assert.AreEqual(expectedResult, actualResult);
In BDD writing tests uses a similar structure but with Given When Then (GWT) syntax:
    [Given(@"a customer previously bought a black sweater from me")]
    public void GivenACustomerPreviouslyBoughtABlackSweaterFromMe()
    { /* Code goes here */   }
    [Given(@"I currently have three black sweaters left in stock")]
    public void GivenICurrentlyHaveThreeBlackSweatersLeftInStock()
    [When(@"he returns the sweater for a refund")]
    public void WhenHeReturnsTheSweaterForARefund()
    [Then(@"I should have four black sweaters in stock")]
    public void ThenIShouldHaveFourBlackSweatersInStock()
Although they are often considered the same there are differences. A few key ones are:
  1. GWT can be mapped directly to the specification of a feature file in BDD frameworks
  2. GWT is easier for non-developers to understand by encouraging use of plain English, and having a short description of what each part is doing
  3. Given When and Then are keywords in various BDD frameworks such as SpecFlow, and Cucumber
My question is are there any other differences (besides the names) between AAA and GWT? And is there any reason besides the ones specified above that one should be preferred over the other?
Cognitive_chaos
  • 373
    I don't see a difference except for the 'reads more like a natural language'. Given an arrangement, when an action happens, then assert things about the new state.' – Sjoerd Job Postmus Jan 24 '16 at 16:00
  • I think you've found a couple of relevant points, and will unlikely receive an answer with additional differences. For what its worth, I exclusively use AAA for unit tests since the format is completely methodology-independent but encourages small, independent tests. – amon Jan 24 '16 at 17:24
  • is this a duplicate of http://programmers.stackexchange.com/questions/111837/relation-between-bdd-and-tdd , http://programmers.stackexchange.com/questions/135218/what-is-the-difference-between-writing-test-cases-for-bdd-and-tdd , http://programmers.stackexchange.com/questions/135218/what-is-the-difference-between-writing-test-cases-for-bdd-and-tdd/224102 – k3b Jan 27 '16 at 15:07
I think you listed the differences very well in your question, however I'll add some of my opinions regarding the two approaches.
AAA is very useful for me when I'm testing my own code. If I'm working on a project or a library for myself, AAA is the way that I go. It lets me set up whatever I need to execute my test and then just test it. It's quick to setup, and quick to verify that my code is working as I expect.
GWT is useful in business environments, where work that is done by programmers needs to be mapped to business value. Business value is mapped by features, and hopefully features that don't introduce bugs. There are many strategies for mapping features to programming tasks, but one of them is through requirements. In my experience, requirements range from user-level requirements all the way down to small tasks for the user to execute. This is useful because it's easy for the managers to understand how the work the programmer is doing is impacting their customers/users, and therefore why the programmers are adding value to their business
  • User-Level Requirement: Given the warehouse has at least N item(s) in inventory, when a user purchases N item(s), then the warehouse ships N item(s) to the user
  • System-Level Requirement 1: Given the inventory system has N item(s) in inventory, when a request for N item(s) is input into the inventory system then the inventory system decreases the inventory count for that type of item
  • System-Level Requirement 2: Given the payment system has N item(s) in inventory, when a request for N item(s) is input into the payment system then the payment system charges the user for N item(s)
  • Programmer-Level Requirement 1: Given 5 sweaters are in inventory, when 3 sweaters are removed from inventory then 2 sweaters are left in the inventory
This sort of requirement structure allows for a tree-like design where all of the Programmer-Level Requirements map up the tree to the User-Level Requirements. In this way, when a Programmer-Level Requirement fails then you know which User-Level Requirement is affected.
In contrast, an AAA test might look like this. This to me is very programmer-facing and not useful to the business. That's not to say a similar tree structure of requirements couldn't be made from an AAA testing strategy, but nothing in the language of AAA makes it easier to do so.
public void Test_CaseWhereThereAreEnoughSweatersLeft() {
    // Arrange
    // setup Sweater Inventory mock (DB mocks, etc)
    // count = 5
    // when The number of sweaters remaining is request, return count
    // when Inventory is requested to remove N items, then count = count - N
    // Act
    // call the Unit Under Test to remove 3 items from inventory
    // Assert
    // the number of sweaters in the inventory is 2
    // the removal should return indicating a successful removal of items from the inventory
public void Test_CaseWhereThereAreNotEnoughSweatersLeft() {
    // Arrange
    // count = 2
    // Act
    // Assert
    // the number of sweaters remaining is still 2
    // the removal should return an error indicating not enough items in the inventory
Frank Bryce
  • 938
  • I always find it interesting when people question whether computers (and thus programmers) are adding value to their business. Could it *really* be just a big self-serving bamboozle? I think that a business manager should either learn enough about programming to understand how it is accomplishing their objectives, or simply trust that it does and not worry. I might not really understand how a chemical that influences the onset of the delayed rectifier current in atrial cells works, but I can definitely feel how good it is to not have a heart arrhythmia anymore. –  Mar 29 '18 at 14:32
  • Abstraction is important outside of just Computer Science. People will have expertise in different fields, and being able to communicate that expertise with others is crucial to a business. GWT is an abstraction that is useful to get programmers and (program|project) managers to communicate. Second, as a programmer it's easy to imagine that programmers have the potential to produce little to no value for a business. Lastly, it's worth noting that GWT is not that only way to have programmers and managers communicate, but one of many tools that a business may want to try. – Frank Bryce Mar 30 '18 at 13:16
    Also, I'd want my *doctor* to understand why my heart arrhythmia correction mechanism works before they put it in, not just that it does. GWT tests are supposed to help answer the "why". GWT helping communication between programmer and product manager is analagous to a communication between chemist and doctor. A product manager communicates with users what features they are getting while a doctor is communicating to their patients what value they are getting with a heart arrhythmia correction. – Frank Bryce Mar 30 '18 at 13:24
There is no difference at all.
Three states of test:
Given = Arrange,
When = Act,
Then = Assert.
Differences you provided in the question is differences between TDD and BDD and not GWT and AAA.
In TDD you can have three different methods for one test
public class TestsOfFormatMethod
    public void Arrange() { // set dependencies }
    public string Act() { // return formattted result }
    public string AssertThatFormatIsEmpty()
        Arrange();
        var actual = Act();
        Assert.IsEmpty(actual);
Fabio
  • 3,086
I guess it's dependent upon the framework you're using. Generally, so far as my understanding, AAA is supported by the NUnit framework, and thus is the natural choice in that regard. As for the theoretical differences between TDD and BDD, they appear to be slight. See this link, someone more qualified than myself to give you an explanation.
George Grainger
  • 485
