You can't map the surface of a sphere onto a plane square grid, whilst at the same time preserving distance, area and angles - there has to be some sort of compromise. See here for more details.
If you really want "equal sized elements", a better solution might be to use a spherical co-ordinate system - latitude and longitude with elements of equal arc length. That way, any point on the surface can be assigned to a single element. However this means that the elements are not perfectly square so there will be a little distortion if you treat them as such. Also, all of the elements will have the same height, but they will become progressively narrower as you move away from the equator.
Assuming the earth is a perfect sphere of radius 6371 Km, and using a 1 degree granularity, each element will be 111.19 km from north to south. Those along the equator will be 111.19 Km along the southern edge but 111.17 Km along the northern edge. You'd be hard pressed to notice this 0.02% difference though if you just treated it as a square.
As you move further north, the difference between the length northern and southern edges becomes more pronounced.
for example :-
Guatemala City (15 deg north) 107.89 - 107.41 Km (0.45%)
San Antonio (30 deg north) 97.25 - 96.26 Km (0.98%)
Lyon (45 deg north) 78.62 - 77.24 Km (1.76%)
Oslo (60 deg north) 57.27 - 55.60 Km (2.92%)
So you could draw a 5 element high grid centred on any of these cities with limited distortion, just with the elements becoming more rectangular as you move north, so you need more elements for the same horizontal distance. It's only as you get towards the poles that you start to get big problems, with the final element effectively being a triangle, coming to a point at the pole.
If you were to zoom in by using a smaller granularity, say 0.1 degree of arc, then the "squareness" of the elements improves. You'd have to go to 80.2 deg north before you get even a 1% difference between the lengths of the northern and southern edges, although these elements will have an aspect ratio of 5.8:1 - 11.1 x 1.89 km. This is almost enough to cover the northernmost permanently inhabited place in the world - Albert, Canada is 82.5 deg north.
