On POSIX systems (e.g. Linux, MacOSX), at least for programs possibly started in a shell terminal (e.g. most of them), I would recommend using the GNU coding conventions (which also lists common argument names) and look into the POSIX utilities guidelines, even for proprietary software:
always handle --version
and --help
(even /bin/true
accepts them!!). I curse the authors of software not understanding --help
, I hate them (because prog --help
is the first command I am trying on a new program)! Often --help
can be abbreviated as -h
Have the --help
message list all the options (unless you have too many of them... in that case list the most common ones and explicitly refer to some man
page or some URL) and default values of options, and perhaps important (and program-specific) environment variables. Show these option lists on option argument error.
accept -a
short argument (single letter) and have some equivalent --long-argument
, so -a2
--long-argument=2
, --long-argument 2
; of course you could have (for rarely used options) some --only-long-argument
name; for modal arguments without extra options -cf
is generally handled as -c -f
, etc. so your -argument:value
proposal is weird, and I don't recommend doing that.
use GLIBC getopt_long or better (e.g. argp_parse, in OCaml it's Arg
module, ...)
often use -
for standard input or output (if you can't do that, handle /dev/stdin
& /dev/stdout
even on the few operating systems not having them)
mimic the behavior of similar programs by reusing most of their options conventions; in particular -n
for dry run (à la make
), -h
for help, -v
for verbosity, etc...
use --
as separator between options & file or other arguments
if your program uses isatty
to test than stdin is a terminal (and behave "interactively" in that case), provide an option to force non-interactive mode, likewise if your program has a GUI interface (and tests getenv("DISPLAY")
on X11 desktop) but could also be used in batch or command line.
Some programs (e.g. gcc
) accept indirect argument lists, so @somefile.txt
is meaning read program arguments from somefile.txt
; this could be useful when your program might accept a very big lot of arguments (more than your kernel's ARG_MAX
BTW, you might even add some auto-complete facilities for your program and usual shells (like bash
or zsh
Some old Unix commands (e.g. dd
, or even sed
) have weird command arguments for historical compatibility. I would recommend not following their bad habits (unless you are making some better variant of them).
If your software is a series of related command-line programs, take inspiration from git (which you surely use as a development tool), which accepts git help
and git --help
and have many git
subcommand
and git
subcommand
--help
In rare cases you might also use argv[0]
(by using symlinks on your program), e.g. bash
invoked as rbash
has a different behavior (restricted shell). But I usually don't recommend doing that; it might make sense if your program could be used as a script interpreter using shebang i.e. #!
on first line interpreted by execve(2). If you do such tricks, be sure to document them, including in --help
messages.
Remember that on POSIX the shell is globbing arguments (before running your program!), so avoid requiring characters (like *
or $
or ~
) in options which would need to be shell-escaped.
In some cases, you could embed an interpreter like GNU guile or Lua in your software (avoid inventing your own Turing-complete scripting language if you are not expert in programming languages). This has deep consequences on the design of your software (so should be thought of early!). You should then easily be able to pass some script or some expression to that interpreter. If you take that interesting approach, design your software and its interpreted primitives with care; you could have some weird user coding big scripts for your thing.
In other cases, you might want to let your advanced users load their plugin into your software (using dynamic loading techniques à la dlopen
& dlsym
). Again, this is a very important design decision (so define and document the plugin interface with care), and you'll need to define a convention to pass program options to these plugins.
If your software is a complex thing, make it accept some configuration files (in addition or replacement of program arguments) and probably have some way to test (or just parse) these configuration files without running all the code. For example, a mail transfer agent (like Exim or Postfix) is quite complex, and it is useful to be able to "half-dry" run it (e.g. observing how it is handling some given email address without actually sending an email).
Notice that the /option
is a Windows or VMS thing. It would be insane on POSIX systems (because the file hierarchy uses /
as a directory seperator, and because the shell does the globbing). All my answer is mostly for Linux (and POSIX).
P.S. If possible, make your program a free software, you would get improvements from some users & developers (and adding a new program option is often one of the easiest things to add to an existing free software).
Also, your question depends a lot on the intended audience: a game for teenagers or a browser for grandma probably does not need the same kind and amount of options than a compiler, or a network inspector for datacenter sysadmins, or a CAD software for microprocessor architects or for bridge designers. An engineer familiar with programming & scripting probably likes much more having lots of tunable options than your grandma, and probably might want to be able to run your application without X11 (perhaps in a crontab
job).
