QUESTION: Is it a good or a bad style to replace this pointer with
variables and why?
To me, if we try to go as language agnostic as possible, then a lot of the temptation to give this
a more meaningful name seems kind of counter-productive.
Focus on Abstract Interfaces
First, a lot the flexibility of languages that allow you to write this.someFunction()
where this
could point to different data types at different times within the same function can benefit from that flexibility. In such a generic context, it shouldn't matter to the correctness of the function what this
is:
function impale(stick)
// Kill this thing. It doesn't matter what it is in the context
// of this function, all that matters is that it can be killed.
this.kill();
stick.combine(this);
In such a case, the impale
function shouldn't care about what is actually implicitly passed through it (what object it is invoked on). All it should care about is that it can be killed, made dead, and can be combined with a stick (though some of that passes responsibility passes over to stick
). If someone passes something which cannot be killed, that's an error in the one calling the function, and not the callee (the function) itself.
In such generic contexts, to try to assign a variable name as a sort of alias defeats a lot of the purpose:
// This kind of documentation suggests this function only works on cats.
var cat = this;
cat.kill();
stick.combine(cat);
... same goes for this (simply a comment):
// Kill a cat.
this.kill();
To add this kind of type-based information, even in the form of a comment, might actually place an unhealthy focus on concrete details over abstract interfaces: "what is this exactly?" vs. "what can this do regardless of what it actually is?"
Focusing much more on the latter, and caring less about the former, will generally enhance your ability to write code that works in a wider range of scenarios (and therefore ultimately write less code to maintain). Yet, of course, it is hard to do this perfectly. In debugging scenarios, for example, what something actually is might start to become very relevant, yet that's something most decent debuggers will show in a watch window when examining what this
is.
Superfluous, Mutable State
Taking the above example though, I'd say the comment route is actually preferable to aliasing this
through a mutable variable, in cases where there is no logical difference and the local variable only serves as an alias for documentation purposes.
It's because the complexity of a function to human interpreters is often multiplied by the amount of mutable state that is accessible. This is especially true in a team-wide setting where we don't even know what the other members of the team did exactly to every single line of code in every function until we carefully decipher them line-by-line. A function that has 300 lines of code and 20 mutable variables at the top and access to 5 global variables at module/file/class scope, e.g., will feel like it has an immediate state complexity of 25*300 = 7500
. Meanwhile a function that is 20 lines of code with access to one local variable in the middle of the function (10 lines of code capable of accessing it) and no global variables will feel more like it has a state complexity of 1*10 = 10
As asinine as it might seem to think that the introduction of a cat
variable above might lead to a higher potential of error ("no one would ever mess with that and set it to anything else"), in a wide team setting, you start to see every kind of goofy mistake imaginable at some point, accompanied by a strong appreciation for Murphy's law.
This idea of state complexity
is kind of a rough metric I made up (perhaps best formally expressed in terms of coupling), and we don't perfectly think this way, but the more mutable state is exposed to each line of code, the more it tends to feel complex, the more room there will seem to exist for error, since the more our mental stack has to account for potential changes made to all such accessible states.
This is one of the reasons why it's generally preferable to give variables a narrower scope (shorter functions, variables declared more locally within shorter scopes, classes with fewer member functions that have access to internal states, smaller files if they have access to file-scope global variables, etc). From the same standpoint, if a class can store fewer member variables because they can be computed cheaply on demand, then it might very well be preferable to cheaply compute them on demand instead of storing and managing extra state. The less places that exist that have access to mutable states, the less potential there typically is for human error, and the fewer suspects we have to check when we encounter a bug caused from an invalid state (a failure to maintain an invariant). If we encounter a variable that is set to a value it should never have, then our immediate list of suspects is basically the number of lines that had access to the variable (the fewer the better). For this reason, it's likewise generally preferable not to create temporary local variables superfluously, like solely for the sake of aliasing/documentation with no other benefit, when a comment will do.
So in this ultra general, language-agnostic context, for any question that asks, "Should I create more mutable state than necessary?", I'd suggest to err on the side of less state to manage. A lot of the obstacles for a program to function correctly will be the number of mutable states multiplied by their scope. If you can get away with fewer variables or smaller scopes, then aim for fewer variables/smaller scopes.
Non-Generic Contexts
In cases where type information seems very relevant, including cases where the functions cannot hope to apply to more than one type of thing, it should generally be contextually obvious what this
is. That's where I'd suggest looking to improve things more than trying to alias/document what this
is in such a blatant and immediate way. That is, improve the documentation and organization of the surrounding code.
There are many ways to make such contextual info more obvious. For example, if the file name in which the function is defined is called cat.something
, then it should be obvious that it applies to cat
objects. If naming files to contain a single class is not idiomatic (something I found is not very idiomatic in Python, e.g., but it has special safeguards to make module-scope global variable access blatantly explicit to mitigate the problems), then perhaps we'll at least have something like this:
// Pretty obvious that this kills a cat.
cat.impale = new function(stick)
this.kill()
If you're doing something fancy with closures as in Caleb's example where the difference between capturing this
to a variable makes a logical difference and not merely designed for documentation, you'll notice he used the variable name, self
, which is equally generic. That's also what I'd recommend if you encounter a scenario where it makes a difference: don't try to degeneralize the function by giving the variable capturing this
a data type-specific name.
Asserting Preconditions
Yet let's say, after exhausting all of these scenarios, you still find the information about what this
is both extremely relevant and elusive simultaneously (not obvious from the surrounding context). If refactoring is out of the question, then perhaps you could at least do something like this:
assert(this is cat);
this.kill();
With this at least, the assert
does more than document. It guarantees that the function is invoked for a cat
or else it'll become a runtime error, immediately noticeable (in a good way, helping to spot bugs immediately before they grow more difficult and elusive to correct the longer they fly under radar). I'd still recommend it as a last resort, but at least this does something more than just add documentation which could end up no longer matching what is actually going on. The assert
makes it impossible: it serves as both documentation and an enforced guarantee/safeguard that the function will always match the expected behavior should it continue past the assertion.
