For the Red-black tree insertion fixup the book distinguishes between 6 cases, 3 of which are symmetric. The cases are (z is the node being inserted):
  • Case 1: z's uncle is red
  • Case 2: z's uncle is black and z is a right child
  • Case 3: z's uncle is black and z is a left child
Case 2 is a subset of case 3, as we can transform Case 2 into 3 with a left rotation.
However in the book's pseudocode which you can see here or here they write as follows:
if uncle.color == red:
  # Handle case
else if z == z.p.right:
  # Handle case 2
  # Handle case 3
Shouldn't this be:
  # Handle case
else:
  if z == z.p.right:
    # Handle case 2
  # Handle case 3
Am I missing something? Does the book use else if in a different way than say Python does? The C++ implementation provided here uses the second version as I expected.
Bar
  • 173
The indentation in the code is important:
     # Handle case
          # Handle case 2
     # Handle case 3
The syntax is a bit quirky, because they squished the if to appear on the same line as the else, but case 2 is indented further inward compared to the remaining case 3, indicating that they do not belong to the same group.
This is what I think the author intended:
if (uncle.color == red)
   # Handle case
else
    if (z == z.p.right)
         # Handle case 2
    # Handle case 3
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
Rufflewind
  • 2,217
    Yeah after looking at it some more it makes sense. Still it's not immediately obvious, bad choice of optimizing for LOC vs. readability. – Bar Jan 12 '16 at 16:07
  • @RobertHarvey: the code was deliberately written such a contorted way to show where the blocks begin and end. – Rufflewind Jan 12 '16 at 20:42
