54
I've been learning about NoSQL Databases for a week now.
I really understand the advantages of NoSQL Databases and the many use cases they are great for.
But often people write their articles as if NoSQL could replace Relational Databases. And there is the point I can't get my head around:
NoSQL Databases are (often) key-value stores.
Of course it is possible to store everything into a key-value store (by encoding the data in JSON, XML, whatever), but the problem I see is that you need to get some amount of data that matches a specific criterion, in many use cases. In a NoSQL database you have only one criterion you can search for effectively - the key. Relational Databases are optimized to search for any value in the data row effectively.
So NoSQL Databases are not really a choice for persisting data that need to be searched by their content. Or have I misunderstood something?
An example:
You need to store user data for a webshop.
In a relational database you store every user as an row in the users table, with an ID, the name, his country, etc.
In a NoSQL Database you would store each user with his ID as key and all his data (encoded in JSON, etc.) as value.
So if you need to get all users from a specific country (for some reason the marketing guys need to know something about them), it's easy to do so in the Relational Database, but not very effective in the NoSQL Database, because you have to get every user, parse all the data and filter.
I don't say it's impossible, but it gets a lot more tricky and I guess not that effective if you want to search in the data of NoSQL entries.
You could create a key for each country that stores the keys of every user who lives in this country, and get the users of a specific country by getting all the keys which are deposited in the key for this country. But I think this techique makes a complex dataset even more complex - it's harder to implement and not as effective as querying an SQL Database. So I think it's not a way you would use in production. Or is it?
I'm not really sure if I misunderstood something or overlooked some concepts or best practices to handle such use cases. Maybe you could correct my statements and answer my questions.
Rachel
  • 23,979
  • 91
  • 159
Leo Lindhorst
  • 862
    This reads more like a rant than a question. You seem to have a good grasp of the advantages and disadvantages of key-value storage versus relational. So what exactly is the question? – JacquesB Jan 11 '16 at 18:09
    It's not a rant at all :) NoSQL Databases are awesome, but I think Relational Databases are not as bad as some people state. I just want to find out, if my thesis, that NoSQL Databases are not the best choice if it comes to searching in 'datarows'...or if I didn't understood the topic correctly. – Leo Lindhorst Jan 11 '16 at 18:10
    http://programmers.stackexchange.com/q/54373/17853 – Lightness Races in Orbit Jan 11 '16 at 18:13
    @DevWurm: No sane person would state that relational databases are bad, but there are some particular use cases where a key-value storage could be more appropriate. – JacquesB Jan 11 '16 at 18:18
    @RobertHarvey edited it out, but in my answer, I noted that you say "I don't say it's impossible," while your title is "Isn't the use of NoSQL Databases impossible..." You might want to amend that – Cort Ammon Jan 11 '16 at 18:34
  • Anything is *possible* given enough time, money and programmer resources, unless the problem is NP-hard. Whether it's practical or not is a different question. – Robert Harvey Jan 11 '16 at 18:38
  • @CortAmmon oh, you're right, i messed the title :/ – Leo Lindhorst Jan 11 '16 at 18:55
    But [MongoDB is Webscale](https://www.youtube.com/watch?v=b2F-DItXtZs)! [warning: includes some NSFW language] – Jerry Coffin Jan 11 '16 at 19:28
    Lumping in all NoSQL databases together is... not ideal. There is greater variation within the things called NoSQL than there is between MongoDB and Postgresql. –  Jan 11 '16 at 19:40
    @DevWurm: You shoudn't conflate key-value stores with NoSQL in general. For example googles BigTable is considered a NoSQL database, but you can still search and create indexes on multiple fields. A key-value store is appropriate when you know you only need to search on a single field (the key). – JacquesB Jan 11 '16 at 20:52
    NoSQL: is just a "word" meaning roughly: an alternative to a relational database. This "category" is so wide, that you really can't do a NoSQL vs relational comparison. It's like comparing apples with NoApples and then choosing to only compare to bananas and forgetting there's also pears and a lot of other NoApple fruit. – Pieter B Jan 12 '16 at 00:43
  • NoSQL does *not* (or at least it *should not*) mean your database is not relational, but that it doesn't use SQL. I would settle for a relational database with an actually structured query language such as that of MongoDB instead of the string hell that is SQL. – Darkhogg Jan 12 '16 at 12:55
  • @Darkhogg: In practice the term NoSQL is used to describe databases which are not relational. There exists a few experimental databases which are relational but uses a different query language than SQL - but this is not what the term NoSQL is used for. – JacquesB Jan 13 '16 at 11:58
8 Answers8
42
While I agree with your premise that NoSQL is not a panacea for all database woes, I think you misunderstand one key point.
In NoSQL database you have only one criterion you can search for effectively - the key.
This is clearly not true.
For example MongoDB supports indices. (from https://docs.mongodb.org/v3.0/core/indexes-introduction/)
Indexes support the efficient execution of queries in MongoDB. Without indexes, MongoDB must perform a collection scan, i.e. scan every document in a collection, to select those documents that match the query statement. If an appropriate index exists for a query, MongoDB can use the index to limit the number of documents it must inspect.
Indexes are special data structures [1] that store a small portion of the collection’s data set in an easy to traverse form. The index stores the value of a specific field or set of fields, ordered by the value of the field. The ordering of the index entries supports efficient equality matches and range-based query operations. In addition, MongoDB can return sorted results by using the ordering in the index.
As does couchbase (from http://docs.couchbase.com/admin/admin/Views/views-intro.html)
Couchbase views enable indexing and querying of data.
A view creates an index on the data according to the defined format and structure. The view consists of specific fields and information extracted from the objects in Couchbase.
In fact anything that calls itself a NoSQL database rather than a key-value store should realy support some kind of indexing schemes.
In fact, it is often the flexibility of these index schemes that makes NoSQL shine. In my opinion, the language used to define the NoSQL indices are often more expressive or natural than SQL, and since they usually live outside the table, you don't need to change your table schemas to support them. (Not to say you cant do similar things in SQL but to me it feels like there is a lot more hoop-jumping involved).
Michael Anderson
  • 1,395
    "...since they usually live outside the table, you don't need to change your table schemas to support them." That's the same situation between a non-clustered index in an SQL database and an index for a noSQL database, right? – Jirka Hanika Jan 12 '16 at 08:00
  • Pretty solid answer. I'd add that NoSQL is somewhat predicated on the idea that if you want to go faster, you should make 90%++ requests by a primary key without a join, and if you want to do anything else, you're in the world of table scans and secondary indexes, which always have performance and scale limits. Once you're searching an index, or you've created a bunch, you're simply not in the area where speed can be attained ( except for small datasets of a few million rows ). If you code in the style where alternate lookups are rare, you'll end up with a very solid operational system. – Brian Bulkowski Mar 14 '18 at 15:43
41
Generally speaking, if your workflow is a perfect match for relational database queries, you'll find relational databases to be the most efficient approach. Its kind of tautological, but its true.
The claim that many NoSQL advocates would make is that many workflows were actually massaged into a relational form, and would have been more effective before such massaging. The validity of this claim is complicated to ascertain. Clearly there are jobs that are very well described by SQL queries. I can say from my experience that my particular relational programming tasks could have been done using NoSQL with nearly the same level of efficiency, if not more. However, that's a very subjective statement based on narrow experience.
I have a feeling much of the sale of the NoSQL approach comes from the assumption of large databases. The larger the database is, the more you must groom your workflow to support the larger datasets. NoSQL seems to be better at supporting that grooming effort. Thus, the larger the database, the more important NoSQL's features can potentially be.
To use the example, in SQL querying by country is just as slow as the NoSQL scan of all users, unless you explicitly told SQL to index the users table by country. NoSQL can do the same, where you create an ordered key-value collection that is the index (just like SQL does under the hood) and maintain it.
The difference? SQL engines had the concept of indexing the table built in. This means you got to do less work (all you had to do was add an index to the table). However, it also means you had less control. For most cases, that loss of control is acceptable, in exchange for the SQL engine doing the work for you. However, in massive datasets, you may want a different consistency model than the typical SQL ACID model. You may want to use the BASE model which supports eventual consistency. That could be very difficult in SQL, because the SQL engine is doing the work for you so it has to be done by the SQL engine's rules. In NoSQL, those layers are typically exposed, letting you hack at them.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
Cort Ammon
  • 10,840
  • 32
    In your example, you assert "_SQL querying by country is just as slow as the NoSQL scan of all users_". Do you have evidence to support this? The NoSQL described in the question is key-value pair, so you would have to scan the value to get the location of the country, then do the comparison. SQL already knows where that data is, so it can select it directly from the disk (skipping what is not needed), then check the value. If the country is a foreign key, it is a quick integer comparison. Wound't this will always be faster since you are pulling less from the disk and the check is quicker. – Trisped Jan 12 '16 at 18:06
    @Trisped Its hard to provide evidence, because NoSQL is an approach, not a product (same for SQL). However, it is worth noting that BigTable, a NoSQL implementation, has a concept of columns, just like SQL tables do. Its the concept of columns that lets you skip data by knowing where to look, which can be applied to either implementaiton. – Cort Ammon Jan 12 '16 at 18:24
16
NoSQL is a rather vague term, since it basically covers all database systems which are not relational.
What you describe is a key-value store, which is a kind of database where a blob of data is stored under a key, and can be quickly looked up if you know the key. These databases are blazingly fast if you know the exact key, but as you say yourself, if you need to search or filter on multiple properties on the data, it will be slow and cumbersome.
Nobody in their right mind would claim that key-value stores can replace relational databases in general. However there may be particular use cases where are key-value store is a good fit. Key-value stores are often used for caching, since you typically cache items by id, but you don't need to perform ad-hoc queries over caches. For example the Stackoverflow site itself uses Redis (a key-value db) extensively, but only for output caching. The underlying canonical data is still persisted in a relational database.
So the answer is pretty obvious: Use a key-value store if you only need to store and lookup using a single key. Otherwise use a different kind of database. And if you are in doubt, use a relational database, since this is the most versatile kind of database, while the NoSQL databases are often optimized towards very particular use cases.
JacquesB
  • 57,310
  • 127
  • 176
    "NoSQL is a rather vague term, since it basically covers all database systems which are not relational." – That's not true. It covers all database systems which are not SQL databases. There are relational databases that don't use SQL, such as Rel and Tutorial D (databases that are designed to follow the relational model more closely *without* the "softening" that SQL does). There are hyperrelational databases. Really, NoSQL means "Not Only SQL", which means "don't automatically assume SQL, choose the correct database model which matches the structure of your date … which may very well be SQL." – Jörg W Mittag Jan 11 '16 at 23:38
  • @JörgWMittag By your definition, if I choose MySQL because its the best DB to match my data, thats a valid NoSQL solution. –  Jan 12 '16 at 05:08
    @JörgWMittag: Thee is no official definition of the term NoSQL, but typically it does refer to non-relational database systems. The "Not Only Sql"-backronym is really a more recent retcon to counteract the unavoidable hype-backlash. But in common use, NoSQL is used to describe systems like MongoDb, Bigtable etc., not say tutorial D (which isn't even a database). – JacquesB Jan 12 '16 at 08:54
    @JörgWMittag [NoSQL](https://en.wikipedia.org/wiki/NoSQL) originally meant "non SQL" or "non relational". The "Not Only SQL" would be NOSQL since it is an acronym instead of the combination of the word "No" and the acronym "SQL". It became popular as a counter to the general practice of putting everything in a database (as stated in the Wikipedia article). As you commented, the field is quite a bit more complex now. – Trisped Jan 12 '16 at 18:00
  • Completely agree. It seems the main patterns of NoSQL are key-value (e.g. Redis) document store (e.g. Mongo) and graph (e.g. Neo4J). I wish people would ditch NoSQL and use one of those terms. – paj28 Jan 13 '16 at 07:54
Your assertions about relational databases are all true, up until the point where you have so much data you can't fit a copy of it on a single server anymore. Then you start running into all sorts of interesting problems. How do you split up your tables so most of your queries can run on a single server? How many copies of the data do you make? How do you deal with inconsistencies between those copies? How do you keep a user's data in a data center that's relatively close to him or her geographically?
These goals often conflict with each other. A lot of twitter users follow people from all over the world. Should twitter's database be geographically optimized for reading tweets or writing tweets?
It turns out when you deal with that kind of scale, you start inventing solutions, adding redundancies, and imposing restrictions that very much resemble a NoSQL database. If you can fit all your data on one box, you're only getting the restrictions and have no need for the benefits.
Karl Bielefeldt
  • 146,727
  • 38
  • 279
  • 479
  • Reading 10TB into RAM takes a while @Daniel... A couple of hours would be a pretty good result. It would make recovering from a disaster relatively disastrous. – Ben Jan 12 '16 at 08:19
    I would say Big Data is certainly one area where NoSQL databases come into play, but it is only one. There are also lots of other reasons why a NoSQL database might be a better fit for a problem. If you have data graphs it makes sense to use a graph database, if you have XML data it makes sense to use an XML database. Not only Big Data, but also the data model is an important criteria when selecting an appropriate database (and of course many times SQL-databases are the right choice, depending on the problem) – dirkk Jan 12 '16 at 10:13
    This is wrong. Sharding as programming approach has been standard in large scale databases for years and some databases support clusters with data sharing transparently (Oracle RAC). How you think all the banks work? And with a proper setup you RARELY do restore backups - that is left as a real "2 data centers burned down" scenario. And yes, been working on a 30tb database once - we had no problems. – TomTom Jan 12 '16 at 17:32
  • Yes, relational databases do transparent data sharding and clustering, but it's a very leaky abstraction if you care about optimizing performance. – Karl Bielefeldt Jan 12 '16 at 18:45
NoSQL databases have very little to do with “No SQL”.
They are about admitting that you can’t have a database at scale that is always consistent and supports complex transactions and has durability.
In a normal relational database all indexes are automatically kept updated within the scope of a transaction, so can be used for any query.
In a NoSQL database the programmer is responsible for maintaining a lot of the indexes and it is assumed that indexes will always be out of date.
For example:
  • An index of people by tax number may contain some people that never complete the process of registration for tax.
  • Therefore code that uses the index has to be able to cope with incomplete registration for tax
  • Another option is to have times when a person that is registered for tax is not in the index. (So your design has to cope with not having consistent data and decide how the data will not be consistent.)
As a real would example, Amazon would rather show me the out of date description of a book than delay the display of the web page by waiting for 106 computers to confirm that the correct lock has been taken out.
Therefore.....
If a single normal relational database can hold all your data and process each transaction quickly enough that locking does not stop your system from doing useful work, a relational database is the best option.
But as soon as you have to start thinking about using more than one relational database, or splitting up transactions to avoid locking errors, you are going down the road of having to cope with the sort of issues you get when using “NoSQL” databases.
As “NoSQL” databases do not hide these issues, they may become the best option when you scale up a system. But remember that Stackoverflow still uses an relational database for storing all its data, with limited use of NoSQL in the caching layer – so you have to be VERY big before you are forced to use NoSQL to store your data.
Nathan Hughes
  • 195
Ian
  • 4,594
  • That last tidbit is very interesting - do you have a link to some meta SO site for interested readers to click through to about SO's (non)use of NoSQL? Thanks! – kcrisman Jan 12 '16 at 18:42
  • @kcrisman, see http://highscalability.com/stack-overflow-architecture for exmaple – Ian Jan 12 '16 at 18:44
Relational Databases are optimized to search for any value in the datarow effectively.
Don't confuse the ability to search on "any" value in a row with "every" value in a row. The most effective way to do this requires one or more indexes. You could have indexes include all the fields, but then you just hindered you're ability to make changes that require altering the index (inserts, updates, deletes). You (or your DBA) have to understand the data, the usage, bottlenecks etc.
JeffO
  • 36,816
  • 57
  • 124
  • A good example would be saving chats. There could be a need to relate them to some other data and do all sorts of analysis, but during chat session itself, the users will appreciate something faster that doesn't have all the overhead of a RDBMS such as a transaction, or constraint. – JeffO Jan 11 '16 at 21:47
-1
There are many answers already, but I just wanted to add my summary.
Clearly NoSQL concept covers a variety of different approaches in organizing data on-disk, in-memory and exposing it via a query language (some are even SQL-like!). In my view the strength comes from this variety of systems so you can choose the best tool for the job. But still hopefully you can cover a dozen different needs with just a few different solutions, you wouldn't want to manage a dozen different systems.
Relational databases can get you very far and are a proven technology, but just like the database you might want to choose the programming language based on each project's needs (but taking team's experience into account as well).
NikoNyrh
  • 107
I've been using couchdb for two years now. It's mostly used for content management and configuration.
For hierarchical relationships are much easier to manage when you can visualize them. For read-mostly data, it's easier to edit JSON than it is to write an UPDATE statement in many cases. Doesn't take a programmer, actually, to edit JSON. And SQL gives you rows and columns, which you then have to map into some sort of object structure.
You also get a performance boost because you're not joining 10-20 tables on complex queries. Couchdb views are very fast because the javascript they are based on are not executed at query time.
Most programmers understand Javascript, and most programmers struggle with SQL occasionally.
In Couchdb, a view can be thought of as an abstract of a JSON document. How the view data is structured is up to you (you are not constrained by the original hierarchy).
I wouldn't use Couchdb for highly transactional data, but for semi-static data with a parts-explosion type structure, it is MUCH easier to work with than SQL.
Note though, that there is no clear 'normalization' that can be applied (though avoiding duplication of data is a worthy goal), and there is essentially and 'optimistic' update strategy akin to optimistic locking.
