19
The anemic domain model is described as an anti-pattern in domain driven design by Martin Fowler. To have business logic on the domain models often domain services are used. But injecting domain services into domain models is considered harmful by Vaughn Vernon (see "Implementing Domain-Driven Design, Page 387).
In my opinion those opinions are contradictory, is this true? How can both points be considered?
Is it really rich domain model with domain services injected vs. anemic domain model and normal domain services?
Sjoerd222888
  • 669
    I am by no means an expert on this, but I thought the *type* of logic that went into domain services and into domain entities was fundamentally different. The logic that goes into Entities is the logic needed to keep the object in a correct state. This involves validation and transformation logic. Domain services, on the other hand, are for higher level logic. So, for example, a domain service would model a business process that involves multiple different types of entities is complex ways. – MetaFight Dec 17 '15 at 15:46
    @MetaFight: Even if a business process affects multiple entities in complex ways, you can achieve this without services given a good Aggregate Root domain model, that is, a domain model that has access to all the affected entities as properties or fields on itself. – Greg Burghardt Dec 17 '15 at 18:06
  • That makes sense :) – MetaFight Dec 17 '15 at 18:08
An anemic model is simply a data container. It doesn't contain behavior. (This might actually be considered a good thing in the functional paradigm.) The opposite of an anemic model is not a model injected full of domain services. You're describing two extremes -- both are bad.
If you have an anemic model, you're not fully embracing what OOP offers. If you start injecting services into those models, you're likely injecting concerns that don't belong there. Either that or your model is more anemic than you think. Why else would you need the service other than it provides something that's required but missing? (Missing might mean anemic.)
Avoiding both "tells" leads to stronger design. Do you have something in a service that a model needs? Maybe it should be moved to the model. If not, maybe you should reconsider your concerns. A model's behavior should work inside the model. It should mainly (if not only) concern itself with members. But remember, there will still be things that work on or with the model. For example, models shouldn't be opening TCP connections or listening for UI events, even if they're somehow involved. That's someone else's responsibility and that someone never belongs inside the model.
Scant Roger
  • 9,038
  • 47
    A good distinction I like to remember is that your Domain Model *implements* business logic, and your Domain Services *execute* the business logic on the Domain Models. The difference is who is calling who. Services can call Domain Model methods. If Domain Models are calling Service methods, you've flipped the pattern on top of its head. – Greg Burghardt Dec 17 '15 at 18:04
  • Actually it depends how You understand concept of a service. What a about cases when a domain object needs to vary its behaviour basing on something? Then it could be beneficial to inject a 'service' into a domain entity (eg tax calculator and so on). – Mic Mar 20 '20 at 13:11
It's not contradictory. Both proponents would like you to put your actual code in the domain object itself.
ie.
public class Order
    private string status = "not bought";
    public void Buy()
        this.status = "bought";
vs ADM
public class Order
    public string Status = "not bought";
public class BuyingService
    public Order Buy(Order order)
         Order o = new Order();
         o.status = "bought";
         return o;
vs injected services
public class Order
    public Order(IBuyingService bs)
        _bs = bs;
    private IbuyingService _bs;
    public void Buy()
        this.status = _bs.Buy();
public class BuyingService : IBuyingService
    public string Buy()
         return = "bought";
Frankly though each approach has pluses and minuses. The one you choose is largely a matter of personal preference
Ewan
  • 70,664
  • 76
  • 161
