Suppose we have an interface such as
public interface anInterface
      public void aMethod();
and a class as follows:
public class aClass
      //bla bla bla
Now I'm going to define another class such as Subclass that extends aClass and implements anInterface, as in:
public class Subclass extends aClass implements anInterface
      //do something
What does exactly aMethod() do in Subclass? Does it implement the method in anInterface? Or does it overrides the method in aClass?
What should I do in order to make aMethod() implement the method of anInterface? Similarly, if I want it to override the method in aClass, what can I do with it?
Dan Pichelman
  • 13,773
  • 42
  • 73
It does both.
The compiler checks that Subclass fulfills its contract, being concrete: it must override all abstract methods in its hierarchy, including methods defined on interfaces. From the compiler's standpoint, an interface method and an abstract method on a regular class are the same thing: a method declaration with no definition.
The compiler sees that Subclass must have a method with the exact signature public void aMethod(). It has this method, so it satisfies the interface. This method overrides the definition in its parent class and its declaration in its parent interface.
  • That's kind of ambiguity or proble.! If one sets the return type of aMethod() in anInterface to int, and that of aMethod() in aClass to String for example, then there is no way for them to write code for aMethod() in Subclass. If they write 'public int aMethod()' in Subclass, then the compiler returns an error complaining that the return type is not compatible with aMethod() of class aClass. Conversly, if they write 'public String aMethod()' then the compiler says that the return type is not compatible with aMethod() of anInterface!!! How can one solve this problem? – Hedayat Mahdipour Nov 26 '15 at 20:18
  • @Hedayat it is not possible to have incompatible method signatures like that. The solution is lose either the supertype or superinterface declaration. –  Nov 27 '15 at 03:42
