In my company we have this obligatory practice before a review to be send the binary size impact of the code change to be measured and provided.
We must use -Os for this metric to avoid unpredictable inlining. There is no customer or product driven arguments for it. It is a big server that is installed as singleton of a dedicated machine, where the executable size is completely ignorable in comparison to all the other resources involved in the system.
The main argument for this practice is that -Os binary size correlates with code complexity.
Is measuring the binary size a reliable metric to use when evaluating code complexity? Or for evaluating anything else?
Rachel
  • 23,979
  • 91
  • 159
gsf
  • 264
    If this is for an embedded device, the size of the binary might be very important. – Dan Pichelman Nov 17 '15 at 19:36
  • ok, let me change the question – gsf Nov 17 '15 at 19:37
    The only value of that metric that I know of is to verify if you aren't hitting a ROM size limit for an embedded platform. – Bart van Ingen Schenau Nov 17 '15 at 19:37
  • Touched briefly a point of sales system that had to fit in an old 640k memory on an ancient machine. Binary size was important. –  Nov 17 '15 at 19:38
    Measuring code quality this way makes about as much sense as measuring [productivity by number of check-ins](http://thedailywtf.com/articles/Productivity-20). –  Nov 17 '15 at 20:10
    To point out the probably obvious: there are real tools (ls -l a.out is not a real tool) for calculating complexity for C code (e.g. https://www.gnu.org/software/complexity/manual/complexity.html for an example, e.g. http://stackoverflow.com/questions/125898/tool-for-calculating-cyclomatic-complexity for a list of tools) C++ appears to be less prevelant than C#/Java/etc., but there are some tools (not sure if GNU complexity handles C++ or if it's just focused on C syntax) – Foon Nov 17 '15 at 23:42
    Imagine a complex function being replaced by a very large table of precomputed values. The code is much simpler, and the binary is much larger. – Viktor Dahl Nov 18 '15 at 03:57
    Binary size is not a good metric for code complexity, but it is a good metric for your manager's ... err ... lack of complexity. – utnapistim Nov 19 '15 at 10:19
  • While the main argument is invalid (or simply a circular logic), code size has some impact on performance due to the impact on the use of CPU code cache. However, this cannot be measured statically on the binary files; this can only be measured at runtime in a realistic hardware test environment with the help of CPU profilers. – rwong Jan 15 '18 at 05:50
As noted in the comments, size of the binary could be very important for some embedded systems - especially old ones.
However, as you've noted in the update to the question
This is one of the most pointy-haired schemes I've heard in a long time. You'll be penalized for including a library that's well tested and solves a lot of problems, but they'll let a Bubble sort get past?
Seriously, it would be useful to see some justification for their main argument that the binary size correlates with other qualities of the code. It's entirely possible that I'm dead wrong and there is such a correlation, but I kind of doubt it.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
Dan Pichelman
  • 13,773
  • 42
  • 73
    Change the -O2, and a tail call gets changed to a loop (possibly more code, possibly faster), change it again to -O3 and the loop gets unrolled (certainly more code, and possibly faster again). Change to -Os and you're a deity of programming for making it so small. –  Nov 17 '15 at 19:55
  • I've had the size of the slug be a big problem for the deployment process, which can hinder testing by having longer testing cycles and I suppose in theory that could lead to lower code quality. But I suspect if that really did have an impact, there would undoubtedly be other failures in the process that would be far worthier of your attention. – corsiKa Nov 17 '15 at 22:27
  • People who believe this also probably think you can save hard drive space by programming in a smaller font... – Darrel Hoffman Nov 17 '15 at 22:52
    Just to play a bit of devil's advocate, I would guess that this is being used as _a_ metric, but not a critical metric. So bubble sort would still fail because of regular code reviews, but would be ok because its is tested and solves the a big problem. On the flip side, if we double the binary size just to solve a small problem its a pretty big red flag no matter how much testing you do. – David says Reinstate Monica Nov 18 '15 at 00:22
  • Nope, it is the main metric and the only obligatory one. Everybody is free to do whatever else they want, but it is up to them. – gsf Nov 18 '15 at 14:48
There have been a few changes and updates, so I'm going with rev4 of your question.
You're asking size-optimized binary size to act as a proxy for code complexity; from version to version that number can go up or down. If you said that observed "up" measurements generally correlate to increases in code complexity I'd say that's ... reasonable.
But that alone is hardly actionable.
You haven't said why your bosses are asking you to do it, or how they use the information. If they are rejecting a change solely because the -Os version of the binary went up 3K, that sounds mighty foolish. If they are just interested in seeing/charting/graphing changes to the code over time, that sounds okay, especially because it should/could/might be easy to compute this number during an automated build process. If nothing else, metrics can start conversations and/or act as sanity checks.
Scenario 1
Boss: I see the size is down, how'd that happen?
Coder: Marketing finally gave us permission to completely remove that set of deprecated features.
Boss: Oh, nice.
Scenario 2
Boss: A 30% increase in size? I thought the new feature involved a minor tweak!
Coder: That's what we thought too, but once we understood what the client was asking for, we had to blah blah blah....
Final note, in case someone thinks otherwise, I'll state explicitly: complexity != maintainability != quality
brian_o
  • 160
  • How the reaction to the result might impact the reliability of the measurement - which my question is about? – gsf Nov 17 '15 at 23:27
    _"complexity != maintainability != quality"_ hang on what? – Lightness Races in Orbit Nov 17 '15 at 23:29
    @LightnessRacesinOrbit: I interpret that as saying that those are three separate things, though they may be (anti)correlated to some degree. – Kevin Nov 18 '15 at 00:25
    @gsf If you're writing code to optimize a single metric like binary size at the expense of every other good coding practice *because* you think that's the only metric your boss cares about, that's probably self-defeating in the long run. Cynicism aside, I doubt that's what your company had in mind when it instituted the policy. – brian_o Nov 18 '15 at 00:55
  • @brian_o I am not sure how did I express such intention, but thank you for letting me know. I will keep this in mind. – gsf Nov 18 '15 at 01:11
The size of the binary is pretty much only a good indication of the size of the binary. Code complexity fundamentally stems from "choice" (be that the choice to terminate a loop, a condition in am if statement, a switch or cond block, duck-typing, having multiple classes implementing an interface, ...). For any given binary size, there's a binary of comparable size that is composed entirely of linear, non-branching code.
Change in binary size (which is what you actually seem to be asking about) may or may not correlate to changes in complexity. Is it "more complex" to pull in a well-tested library to do one (or more) things? Probably not in any useful sense, as long as the library interfaces are clean and sufficiently "black box". Would it increase the binary size? Most probably.
Vatine
  • 4,251
What does code complexity mean in this context? Are we talking in terms of machine code or the C++ source code that humans have to maintain? I would say "not necessarily" even if the former, but especially "no" for the latter.
In a past company I worked at, we shipped over 90 megabytes just in terms of binaries, and that was an optimized release build stripped of debugging info and so forth. And it was a pretty complex codebase, millions of LOC, but it would be very misleading to deduce the code complexity from that binary size...
... because one weekend I just kind of fooled around with the build system and got the whole thing to result in less than 10 megabytes without changing any code or changing the optimization settings. All I did was dynamically link the CRT (C runtime lib) and a couple other big libaries in our third party section. Presto; that eliminated all sorts of code being statically linked into all of our binaries (which spanned in the hundreds with all the plugins we had). I didn't check those changes in since I was just goofing around (and wasn't sure about the impact of depending on dylibs in that case and C++ can get hairy working across module boundaries if the code wasn't written upfront to deal with it to avoid doing things like throwing across boundaries), but it at least kinda satisfied my curiosity that the binaries at least didn't have to theoretically be so massive.
When I see other products that have massive binaries, I tend to wonder if they might benefit from the same thing. On the flip side, it might not be worth caring about this stuff so much outside of embedded devices with our hard drives being epic and bandwidth being plentiful. I still like the aesthetics of small binaries though and things that install and download very quickly and so forth. It's one of the places where I'm still very impractical and would prefer to spend time making binaries smaller, starting out from days where a 10MB hard drive was considered awesome, but again I don't consider binary size to be a reflection of the complexity of a codebase since many binaries are probably statically linking redundant code over and over.
My memory is a bit fuzzy, but I somewhat recall a time around 25 years ago when you could take a C++ "Hello World" program and statically link everything and end up with a binary that was a few hundred KB, and that got a lot of criticism from C programmers. My memories might be exaggerating that a bit (maybe it wasn't that huge), but I sorta recall a time when some C++ compilers, now faded into obscurity, would tend to generate massive binaries for the most trivial programs even without any debugging info or anything like that. That was back before I/O streams were standardized in C++, I think (sorry, my memory is so hazy).
The binary size is the most fundamental metric of any build because it will hit the bottom line of the deliverable, for better or worse.
For large programs, as a general rule, binary size will reflect complexity. This seems counter intuitive because redundant or duplicated code would seem to be a path to greater size. In practice, however, for non-trivial programs redundant code tends to be hard to maintain so it is self limiting. In other words, the larger a program gets, the more essential it becomes to abstract it to support further growth. For this reason, binary size tends to approximate complexity.
Note that it is only a very rough metric, however. In some cases you can find bloatware by large organizations, like IBM, where they have succeeded in creating large binaries using very large teams of developers which are somewhat redundant. However, even in these case the law of maintainability applies and even IBM is not immune to it; eventually even the most massive manhour efforts will succumb to inertia if they are not abstracted.
Thus, as rule, especially for a given corporate context binary size will provide a very rough generalization of complexity.
Tyler Durden
  • 533
    Plenty of programs can have resources embedded in them such as images, icons, and sounds, which will trivially destroy any naive binary size->complexity relationship. – whatsisname Nov 18 '15 at 03:27
    what about code execution time?? that's more of a fundamental metric of complexity than code size. seems to me that squirrelly code will take longer to execute than good code. and inlining (which increases code size) may well reduce execution time. as Dan implies, it sounds pretty "pointy haired" to me. – robert bristow-johnson Nov 18 '15 at 04:43
