I am building a wrapper to a load-testing tool that will take configuration and scenario files as yaml and build a large, unwieldy xml file which will be destroyed when it is no longer needed.
A sample yaml file would look like this:
# basic.yml
config:
ip: 127.0.0.1
rate: 1
maximum: 10
iterations: 75
email: foo@bang.com
repeat: true
scenario:
- wait 5
- ping 7
- wait 5
The xml contains a host of data that is specific to the underlying tool being wrapped but which never needs to be seen by an end user.
For example, the header is as
<send retrans="500">
<![CDATA[
<!-- 25 lines of specific configuration that will never change -->
</send>
<recv response="100" optional="true"/>
<recv response="180" optional="true"/>
<recv response="183" optional="true"/>
<recv response="503" optional="true"/>
<recv response="200" rrs="true" rtd="true"></recv>
where literally none of the information in this segment needs to ever be altered. In fact, nothing in the config
section of the yaml effects the xml. What does effect the xml is the scenario. We can think of the scenario as a domain specific language (dsl) in which wait 5
signifies that we must add
<pause milliseconds="5000"/>
after the header, and ping 7
<![CDATA[
<!-- 12 lines of specific configuration that will never change -->
Signal=7 <!-- passed from yaml -->
<!-- 6 lines of specific configuration that will never change -->
</send>
followed by a final
before another 30-40 lines of specific xml that will never change.
My Approach
I plan to use Ruby to do this implementation, but that is irrelevant to my question, which is about best practices in generating xml from a dsl template. I am thinking of holding my xml "units" in a subdirectory as text files:
- header.txt
- wait.txt
- ping.txt
- footer.txt
Where wait.txt
would look as
<pause milliseconds="#{time}"/>
and my parser would pull the text file, use string interpolation to insert the time pulled from the yaml before appending the message to the xml file being generated. We could think of the dsl to generate an xml file for this yaml file as
header
wait 5
ping 7
wait 5
footer
Question
What are best practices in using yaml to generate xml? Is there a more "rubyish" way to store the underlying xml components? Am I missing opportunities in using the xml format?
