We have a new piece of functionality coming up. It comprises of 9 different user stories, covering the functions needed. Three of these are listed below:
- As a user I should be able to add a person so that...
- As a user I should be able to edit a person so that...
- As a user I should be able to delete a person so that...
These three issues make out about 20 sp's each.
The challenge is that these three issues are in practice treated as one issue. So, instead of having a nice burndown with 20 sp's burned on Tuesday, 20 sp's burned on Thursday and 20 on the following Monday, I get to see 60 sp's burned on the last day (e.g. Monday).
In theory, (I believe) this is wrong. Each issue implemented should be "atomic" in the way that you can deploy this in production once the issue is done. This makes sense, and in my scenario above, you can deploy "add" to production without having edit and delete.
However, from a technical perspective, it makes sense to "combine" the implementation of the three. Or at least add and edit. They share a lot of logic, and you might have to "pay more" if you first complete "add" and then start on "edit" the day after.
Question is if we should continue as this, and have a rotten burndown in these cases, or if we should allow for more overhead and focus on the theoretical part - e.g. "atomic" issues.
Or should we consider something else?
