While understanding how yield
keyword works, I came across link1 and link2 on StackOverflow which advocates the use of yield return
while iterating over the DataReader and it suits my need as well. But It makes me wonder as what happens, if I use yield return
as shown below and if I don't iterate through entire DataReader, will the DB connection stay open forever?
IEnumerable<IDataRecord> GetRecords()
SqlConnection myConnection = new SqlConnection(@"...");
SqlCommand myCommand = new SqlCommand(@"...", myConnection);
myCommand.CommandType = System.Data.CommandType.Text;
myConnection.Open();
myReader = myCommand.ExecuteReader(CommandBehavior.CloseConnection);
try
while (myReader.Read())
yield return myReader;
finally
myReader.Close();
void AnotherMethod()
foreach(var rec in GetRecords())
i++;
System.Console.WriteLine(rec.GetString(1));
if (i == 5)
break;
I tried the same example in a sample Console App and noticed while debugging that the finally block of GetRecords()
is not executed. How can I ensure then the closure of DB Connection? Is there a better way than using yield
keyword? I am trying to design a custom class which will be responsible for executing select SQLs and stored procedures on DB and will return the result. But I don't want to return the DataReader to the caller. Also I want to make sure that the connection will be closed in all scenarios.
Edit Changed the answer to Ben's answer as it is incorrect to expect method callers to use the method correctly and with respect to DB connection it will be more expensive if the method is called multiple times for no reason.
Thanks Jakob and Ben for detailed explanation.
