In an application, I have a recursive folder structure (like folders in OS X or Windows file system).
Each folder can contain three kind of things:
  • Other folders (hence the recursive structure)
  • Employees
  • Tasks
Here are the simplified models for those elements:
class Folder:
    parent_folder: Folder
class Employee:
    folder: Folder
    task: Task
class Task:
    folder: Folder
As you may understand from the models above, each Employee can be attributed a single Task.
The pain point is that an employee can only have a task which is located in this employee’s tree of folders (aka be part of its path). Let me illustrate this with some examples:
Valid:
    Employee in /MyFolder/OtherFolder
    Task in /MyFolder
Valid:
    Task in /MyFolder/OtherFolder
Invalid:
    Task in /MyFolder/OtherFolder # not in Employee’s path
Invalid:
    Task in /RandomFolder # not in Employee’s path
Desired behaviour
If an Employee or a Task is moved so that an Employee's Task becomes unaccessible to said Employee, I’d like to have the relation between the two nullified, so that the Employee becomes task-free.
If, at any time, in the database, an Employee has a Task for which he doesn’t have access (is not in its path), the database should be considered corrupted.
Questions
Is it possible to implement this behaviour at the database level, so that it would work like Foreign Key constraints with nullifying cascading rules, for example?
If it's not possible at the database level, can you think of a way to implement this at the application level and keeping the database integrity at any time?
Subsidiary question: should we reconsider our data structure and implement one which would be more suitable for this particular problem?
What we tried so far (and the reasons why it didn’t work):
  • Implement this behaviour at the application level - doesn’t work because we can’t guarantee the integrity of the database in this case
  • Use Views or Common Table Expressions (CTE) - doesn’t work because Foreign Keys can’t be used within Views or CTE
  • Use a separate table for the relations - doesn’t work because of the recursive aspect of the structure which prevents us to use FK constraints for this goal
A note on the stack: PostgreSQL - SQLAlchemy
To keep this question (relatively) short, I simplified the problem and omitted a certain number of elements - please ask if you need more details
Edit: I should have mentioned that retrieving an object's folder from pure SQL is actually much less trivial than in my example
Jivan
  • 315
    Are you expecting data to be put into your database that is managed by something outside your application? – JeffO Sep 30 '15 at 18:05
If the database is under control of the application (not modified by anything else), do it at the application level, not the database level.
In theory you could do it with triggers, but I don't think you should. Checking the validity of such a structure requires computationally complex queries, and there is significant danger that this will have a negative impact on performance and scalability. It is a possibility, but this isn't a good design to choose without a clear need for it (and I don't see one given the information in the question).
I don't understand the concern "we can't guarantee the integrity of the database". Why not? If the database can only be modified via the application, and you ensure (and thoroughly test) that every action the application performs is done correctly and doesn't result in an invalid state, then you should not have a problem with database integrity. And this sort of testing is what you need anyway to ensure that your program is robust.
If you need additional assurance for some reason (most likely because the database can be modified outside the application), you might consider triggers. However, if that is not performant, you could create some custom code that performs an integrity check on demand. Or you might consider providing an API for others who need to modify the database, rather than allowing the database to be modified directly
This is perfectly possible with triggers, and if you must ensure integrity at an application-independent level, this is possibly your best shot. From this example you can see that recursion is possible in POSTGRESQL stored procedures, so traversing the tree should not be too hard to be implemented.
Of course, you may have to implement "AFTER INSERT", "AFTER UPDATE" and "AFTER DELETE" triggers for tables Employee and Task, and to make this bullet proof without significant performance hit you have to be careful, but to my experience, these are solvable problems.
Doc Brown
  • 199,015
  • 367
  • 565
  • Based on the question, I thought the database was owned by the application and not modified by anything else. If that is true, I think it makes little sense to verify within the database. If not...well, yes you could do it with triggers, but unless the database is quite small, this is going to be a significant performance hit. Recursive queries are slow. –  Oct 01 '15 at 07:52
  • @dan1111: the OP wrote explicitly that "implement this behaviour at the application level" is *not* what he is after. And it does not make sense to argue about performance unless one has actually measured it - performance hits are typically where you do not expect them. For example, the performance of a recursion will mostly depend on the depth and overall size of the folder structure (which we don't know), and pulling the whole structure over the network might have a performance impact, too. – Doc Brown Oct 01 '15 at 08:02
    actually what was said is that this hasn't been successful so far. It wasn't clear why. –  Oct 01 '15 at 08:04
  • @dan1111: OP mentions a couple of things he tried, triggers & stored procedures are not on those list. – Doc Brown Oct 01 '15 at 08:07
  • @DocBrown your option looks great - we've definitely had a look at triggers but I would say, apart from anything else, it seems to add quite a burden of SQL code if retrieving the folder of any object in pure SQL is less trivial than in my example (whereas it would be straightforward in the application context) – Jivan Oct 01 '15 at 11:08
    @Jivan: yes, of course, when solving this at the application level is an option, it might be easier there - especially when you already have data structures for the tree structures available there, for which there is no equivalent in PL/pgSQL. But often this is simply a knowledge problem: because application developers prefer coding in Java or C#, and do not know stored procedures well, they overstate the difficulties of solving a problem like yours that way. – Doc Brown Oct 01 '15 at 12:31
