Having static helper functions to create the constructor argument is a perfectly sane solution, but these functions are limited in what operations they can perform since they must produce exactly one argument each, and cannot communicate with each other.
In the most general case where you want to adapt an interface Constructor(A, B, C)
to a more usable interface Constructor(X, Y)
, you can define a private helper constructor that takes a private ArgumentObject
and chains to the existing constructor. The more usable constructor then chains to the helper constructor via a static helper function to create the argument object:
class Constructor {
// constructor you want to wrap
public Constructor(A a, B b, C c) { ... }
// better constructor you are defining
public Constructor(X x, Y y) { this(createArgumentObject(x, y)); }
// helper constructor using an ArgumentObject
private Constructor(ArgumentObject ao) { this(ao.a, ao.b, ao.c); }
// helper to create the argument object
private static ArgumentObject createArgumentObject(X x, Y y) { ... }
private static class ArgumentObject { ... }
In languages that don't have constructor chaining within the same class (such as C++03), you would have to define an intermediate subclass for the helper constructor.
However, this technique is merely a generalization of your usage of static functions in the constructor arguments. The other solutions you have proposed have various drawbacks which is why I would avoid them unless there is a very good reason to prefer them:
implementing good builders takes a lot of effort for very little value. If the new constructor is simple enough, you can do without a builder. Assuming the class you are wrapping performs solid validation, you could make the argument object public so that arguments can be passed using the Constructor(new Constructor.Arguments {{ foo = 42; bar = baz; }})
idiom.
using static variables that are computed in a static initializer block makes sense for truly static data, but care must be taken to avoid global state. Unless the initialization is very simple, you should be using static functions to initialize these variables in order for the initialization to be testable. Now, the only advantage over directly using static methods is that the values are only computed once and reused for all initializations.
Since your question indicates these initializations could be more complex, using static initializer blocks is a big no-no if testability is important for you. (If it isn't, you have more urgent problems.)
