Actually, in this question I do not ask about particular language or architecture, however I understand there might be some differences.
In physics / engineering it is usually better to handle greater numbers than smaller ones, because of better absolute accuracy. For example when I need to calculate the area of a circle, having its diameter, I'd use the equation S = d * d / 4 * pi
rather than S = pi * (d / 2) * (d / 2)
(in both cases calculating from left to right).
How does it look in programming languages?
Is it important to provide "better" order of arguments? Are there any compilers that can optimize calculation for this?
Do such constructions make sense:
// finding a result of a*b/c
if (abs(c)<1){
result = a / c * b;
} else {
result = a * b / c;
(in the example one should also test values of a
and b
but let's assume they are large numbers)?
I know that using too large numbers I am risking an overflow. I know there is a difference between integer numbers (which are better in addition/subtraction) and float (which are better in multiplication / division).
There is also an issue with integer division, for example in Pascal there is common *
multiplication operator and if both numbers are Integer
, the result is Integer
too, if one of them is Real
(equivalent to float
), the result is Real
too. For division there are two operators: /
which always results with Real
number and div
which takes only Integer
s and the result is Integer
. So in this language it would be better first calculate multiplications and then divisions because Integer
divisions may lead to losing the fractional part, and it is better to lose it later than earlier.
But for float
numbers, which are stored with mantissa and exponent order of multiplications/divisions seems to be not necessary.
What I want to achieve is as most exact result as possible (speed is not necessary).
