I have looked at some answers and searched on Google, but I could not find anything helpful (i.e., that wouldn't have awkward side effects).
My problem, in abstract, is that I have an object and need to perform a long sequence of operations on it; I think of it as a sort of assembly line, like building a car.
I believe these objects would be called Method Objects.
So in this example at some point I would have a CarWithoutUpholstery on which I would then need to run installBackSeat, installFrontSeat, installWoodenInserts (the operations do not interfere with one another, and might even be done in parallel). These operations are performed by CarWithoutUpholstery.worker() and yield a new object which would be a CarWithUpholstery, on which I would then run maybe cleanInsides(), verifyNoUpholsteryDefects(), and so on.
The operations in a single phase are already independent, i.e., I am already grappling with a subset of them that may be executed in any order (front and rear seats may be installed in any order).
My logic currently uses Reflection for simplicity of implementation.
That is, once I have a CarWithoutUpholstery, the object inspects itself for methods called performSomething(). At that point it executes all these methods:
myObject.perform001SomeOperation();
myObject.perform002SomeOtherOperation();
while checking errors and stuff. While order of operation is unimportant, I have assigned a lexicographic order in case I ever discover some order is important after all. This contradicts YAGNI, but it costed very little - a simple sort() - and it could save a massive method renaming (or introducing some other method of performing tests, e.g. an array of methods) down the line.
A different example
Let us say that instead of building a car I have to compile a Secret Police report on somebody, and submit it to my Evil Overlord. My final object will be a ReadyReport. To construct it I start by gathering basic information (name, surname, spouse...). This is my Phase A. Depending on whether there is a spouse or not, I may then have to proceed to phases B1 or B2, and gather sexuality data on one or two people. This is made of several different queries to different Evil Minions controlling night life, street cams, sex shop sales receipts and what not. And so on and so forth.
If the victim has no family, I will not even enter the GetInformationAboutFamily phase, but if I do, then it's irrelevant whether I first target the father or the mother or the siblings (if any). But I cannot do that if I haven't performed a FamilyStatusCheck, which therefore belongs to an earlier phase.
It all works wonderfully...
  • if I need some additional operation I only need to add a private method,
  • if the operation is common to several phases I can have it inherited from a superclass,
  • operations are simple and self-contained. No value from one operation is ever required by any of the others (operations that do are performed in a different phase),
  • objects down the line do not need to perform many tests since they could not even exist if their creator objects hadn't verified those conditions in the first place. I.e., when placing inserts in the dashboard, cleaning the dashboard and verifying the dashboard, I needn't verify that a dashboard is actually there.
  • it allows for easy testing. I can easily mock a partial object and run any method on it, and all operations are deterministic black boxes.
...but...
The problem arose when I added one last operation in one of my method objects, which caused the overall module to exceed a mandatory complexity index ("less than N private methods").
I have already taken the matter upstairs and suggested that in this case, the wealth of private methods is not a telltale of disaster. The complexity is there, but it's there because the operation is complex, and actually it's not all that complex - it's just long.
Using the Evil Overlord example, my problem is that the Evil Overlord (aka He Who Shall Not Be Denied) having requested all dietary information, my Dietary Minions telling me that I need to query restaurants, kitchenettes, street vendors, unlicensed street vendors, greenhouse owners etc., and the Evil (sub)Overlord - familiarly known as He Who Also Shall Not Be Denied - complaining that I'm performing too many queries in the GetDietaryInformation phase.
Note: I am aware that from several points of view this is not a problem at all (ignoring possible performance issues etc.). All that's happening is that a specific metric is unhappy, and there is justification for that.
What I think I could do
Apart from the first, all these options are doable and, I think, defensible.
  • I have verified that I can be sneaky and declare half my methods protected. But I'd be exploiting a weakness in the testing procedure, and apart from justifying myself when caught, I don't like this. Also, it's a stopgap measure. What if the number of required operations doubles? Unlikely, but what then?
  • I can split arbitrarily this phase into AnnealedObjectAlpha, AnnealedObjectBravo and AnnealedObjectCharlie, and have one third the operations being performed at each stage. I am under the impression that this actually adds complexity (N-1 more classes), with no benefit except for passing a test. I can of course hold that a CarWithFrontSeatsInstalled and a CarWithAllSeatsInstalled are logically successive stages. The risk of a Bravo method being later required by Alpha is small, and even smaller if I play it well. But still.
  • I can bunch different operations, remotely similar, in a single one. performAllSeatsInstallation(). This is only a stopgap measure and it does increase the complexity of the single operation. If I ever need to do operations A and B in a different order, and I have packed them inside E = (A+C) and F (B+D), I'll have to unbundle E and F and shuffle the code around.
  • I can use an array of lambda functions and neatly sidestep the check altogether, but I find that clunky. This is however the best alternative so far. It would get rid of reflection. The two problems I have is that I would probably be asked to rewrite all method objects, not only the hypothetic CarWithEngineInstalled, and while that would be very good job security, it really doesn't appeal all that much; and that the code coverage checker has issues with lambdas (which are solvable, but still).
So...
  • Which, you think, is my best option?
  • Is there a better way I haven't considered? (perhaps I'd better come clean and ask directly what is it?)
  • Is this design hopelessly flawed, and I'd better admit defeat and ditch - this architecture altogether? Not good for my career, but would writing ill-designed code be any better in the long term?
  • Is my current choice actually the One True Way, and I need to fight to get better quality metrics (and/or instrumentation) installed? For this last option I'd need references... I can't just wave my hand at the @PHB while murmuring These aren't the metrics you're looking for. No matter how much I'd like to be able to
LSerni
  • 2,411
    Or, you can ignore the "exceeded maximum complexity" warning. – Robert Harvey Sep 16 '15 at 21:35
  • If I could, I would. Somehow this metrics thing has acquired a sacred quality all of its own. I am continuing to try and convince the PTB to accept them as a useful tool, but only a tool. I may yet succeed... – LSerni Sep 16 '15 at 21:56
  • Are the operations actually constructing an object, or are you just using the assembly line metaphor because it shares the specific property you mention (many operations with a partial dependency order)? The significance is that the former suggests the builder pattern, while the latter might suggest some other pattern with more details filled in. – outis Sep 17 '15 at 06:45
  • The latter. The object is actually a bunch of data facets, each facet comes from different sources and may not even be present depending on other facets. So when I have a dependency I call that a "phase", and each phase may contain from 1 to a hundred different and parallelizable readings. Each of those may be performed with a different approach. I'm beginning to be quite taken with @GregBurkhardt's approach. – LSerni Sep 17 '15 at 10:54
  • "My problem, in abstract, is that I have an object and need to perform a long sequence of operations on it" Why? Can you give us some specifics rather than the car analogy? – Ben Aaronson Sep 17 '15 at 15:34
    The tyranny of metrics. Metrics are useful indicators, but enforcing them while ignoring why that metric is used is not helpful. – Jaydee Sep 18 '15 at 14:48
    Explain to the folks upstairs the difference between essential complexity and accidental complexity. https://en.wikipedia.org/wiki/No_Silver_Bullet If you're sure that complexity that is breaking the rule is essential, then if you refactor per http://programmers.stackexchange.com/a/297414/51948 you're possibly skating around the rule and spreading out the complexity. If encapsulating things into phases isn't arbitrary (the phases relate to the problem) and the redesign reduces the cognitive load for developers maintaining the code, then it makes sense to do this. – Fuhrmanator Sep 18 '15 at 15:52
The long sequence of operations seems like it should be its own class, which then needs additional objects to perform its duties. It sounds like you are close to this solution. This long procedure can be broken down into multiple steps or phases. Each step or phase could be its own class that exposes a public method. You would want each phase to implement the same interface. Then your assembly line keeps track of a list of phases.
To build on your car assembly example, imagine the Car class:
public class Car
    public IChassis Chassis { get; private set; }
    public Dashboard { get; private set; }
    public IList<Seat> Seats { get; private set; }
    public Car()
        Seats = new List<Seat>();
    public void AddChassis(IChassis chassis)
        Chassis = chassis;
    public void AddDashboard(Dashboard dashboard)
        Dashboard = dashboard;
I'm going to leave out the implementations of some of the components, like IChassis, Seat and Dashboard for the sake of brevity.
The Car is not responsible for building itself. The assembly line is, so let's encapsulate that in a class:
public class CarAssembler
    protected List<IAssemblyPhase> Phases { get; private set; }
    public CarAssembler()
        Phases = new List<IAssemblyPhase>()
            new ChassisAssemblyPhase(),
            new DashboardAssemblyPhase(),
            new SeatAssemblyPhase()
    public void Assemble(Car car)
        foreach (IAssemblyPhase phase in Phases)
            phase.Assemble(car);
The important distinction here is that the CarAssembler has a list of assembly phase objects that implement IAssemblyPhase. You now are dealing explicitly with public methods, meaning each phase can be tested by itself, and your code quality tool is happier because you aren't stuffing so much into one single class. The assembly process is dead simple too. Just loop over the phases and call Assemble passing in the car. Done. The IAssemblyPhase interface is also dead simple with just a single public method that takes a Car object:
public interface IAssemblyPhase
    void Assemble(Car car);
Now we need our concrete classes implementing this interface for each specific phase:
public class ChassisAssemblyPhase : IAssemblyPhase
        car.AddChassis(new UnibodyChassis());
public class DashboardAssemblyPhase : IAssemblyPhase
        Dashboard dashboard = new Dashboard();
        dashboard.AddComponent(new Speedometer());
        dashboard.AddComponent(new FuelGuage());
        dashboard.Trim = DashboardTrimType.Aluminum;
        car.AddDashboard(dashboard);
public class SeatAssemblyPhase : IAssemblyPhase
        car.Seats.Add(new Seat());
Each phase individually can be pretty simple. Some are just one liners. Some might be just blinding adding four seats, and another has to configure the dashboard before adding it to the car. The complexity of this long drawn out process is split into multiple, reusable classes that are easily testable.
Even though you said the order doesn't matter right now, it might in the future.
To finish this off, let's look at the process for assembling a car:
Car car = new Car();
CarAssembler assemblyLine = new CarAssembler();
assemblyLine.Assemble(car);
You can sub class CarAssembler to assemble a specific kind of car, or truck. Each phase is one unit within a larger whole, making it easier to reuse code.
If deciding what I wrote needs to be rewritten was a black mark on my career, then I would be working as a ditch digger right now, and you shouldn't take any of my advice. :)
Software engineering is an eternal process of learning, applying, and then re-learning. Just because you decide to rewrite your code doesn't mean you're going to get fired. If that were the case, there would be no software engineers.
What you have outlined is not the One True Way, however bear in mind that code metrics are also not the One True Way. Code metrics should be viewed as warnings. They can point to maintenance problems in the future. They are guidelines, not laws. When your code metrics tool points something out, I would first investigate the code to see if it properly implements the SOLID principals. Many times refactoring code to make it more SOLID will satisfy the code metrics tools. Sometimes it doesn't. You have to take these metrics on a case by case basis.
Greg Burghardt
  • 34,276
  • 63
  • 114
    Yes, much better then having one god class. – BЈовић Sep 16 '15 at 13:16
  • This approach works, but mostly because you can get the elements for car without parameters. What if you needed to pass them? Then you can throw all this out of the window and completely rethink the procedure, because you aren't really having a car factory with 150 parameters, that's nuts. – Andy Sep 16 '15 at 14:01
  • @DavidPacker: Even if you must parameterize a bunch of stuff, you can encapsulate that as well in some sort of Config class that you pass into the constructor of your "assembler" object. In this car example, paint color, interior color and materials, the trim package, engine, and much more can be customized, but you won't necessarily have 150 customizations. You'll probably have a dozen or so, which lends itself to an options object. – Greg Burghardt Sep 16 '15 at 14:45
  • But only adding the configuration would defy the purpose of the beautiful for loop, which is a tremendous shame, because you would have to parse the configuration and assign it to proper methods which would in return give you proper objects. So you would probably end up with something quite similar to what was the original design. – Andy Sep 16 '15 at 15:35
  • I see. Instead of having one class and fifty methods, I would actually have fifty assembler lean classes and one orchestrating class. In the end the result seems the same, also performance wise, but the code layout is cleaner. I like it. It will be a bit more awkward to add operations (I'll have to set them up in their class, plus inform the orchestrating class; I see no easy way out of this necessity), but still I like it very much. Allow me a couple of days to explore this approach. – LSerni Sep 16 '15 at 15:43
  • @DavidPacker: The configuration would be use in the constructor where the operations are instantiated. You would pass the relevant config settings to each operation's constructor. The foreach loop would not need to change. – Greg Burghardt Sep 16 '15 at 18:23
  • @GregBurghardt Wouldn't it be better to make the `Car` immutable (requires a chassis, a dashboard and seats to be instanciated) and the `CarAssembler` to work in this manner: `Car car = assemblyLine.produce();` ? Therefore the caller will be sure that when he gets a car from the `assemblyLine`, it will be fully constructed. (what if an `assemblyLine` forget to set a chassis to the car ?) – Spotted Sep 17 '15 at 06:55
    @Spotted: That's a good point. But the "configuration" I'm talking about would be for minor things that have intelligent defaults. Paint color is a good example. This example might be a bit too explicit for the OP. I was tossing around suggesting the [Builder Pattern](https://sourcemaking.com/design_patterns/builder), but the OP was talking about the long process being pretty static, so I attempted to replicate that and separate the concerns as well. – Greg Burghardt Sep 17 '15 at 12:57
  • You could use a DI framework to configure the assembly line with the list of phases. I like this approach, but I feel it may fall foul of 'not being OOP' – Ewan Sep 18 '15 at 18:35
  • @Ewan: Can you elaborate on this "not being OOP?" – Greg Burghardt Sep 18 '15 at 19:03
  • "car.Seats.Add(new Seat());"? – Ewan Sep 18 '15 at 19:18
  • say for example, when adding seats I should only add up to four. If this logic is to be put in the assembler class then I need to effectively both get and set the seats property. OOP would say seats should be private and .AddSeat(seat) should contain the limiting logic – Ewan Sep 18 '15 at 19:22
  • @Ewan: The implementation of the `Car` class was intentionally incomplete. That class should have the `AddSeat` method, limiting the car to a certain number of seats. I wanted to focus more on the architecture of the assembly process, rather than doing a deep-dive into the domain model. – Greg Burghardt Sep 18 '15 at 19:38
  • if you put the addSeat logic in Car though, you still have the original problem. eg. can I add a speedometer to a dashboard in a car with no wheels. – Ewan Sep 18 '15 at 19:56
    @Ewan: You are focusing more on the `Car` class -- the Domain Model -- and not the overall pattern. Like I said before, the `Car` class and its supporting classes in this example were kept _very_ thin, hoping to prevent a deeper discussion about how the Car class should be implemented. The focus in my answer is more on the `CarAssembler` and not the `Car`. – Greg Burghardt Sep 18 '15 at 20:43
I don't know if this is possible for you, but I'd be thinking about using a more data oriented approach. The idea is that you capture some (declarative) expression of rules & constraints, operations, dependencies, state, etc... Then your classes and code are more generic, oriented around following the rules, initializing current state of instances, performing operations to change state, by using the declarative capture of rules and state changes rather than using code more directly. One might use data declarations in the programming language, or, some DSL tooling, or a rules or logic engine.
Erik Eidt
  • 33,282
  • 57
  • 91
  • Some of the operations are actually implemented this way (as lists of rules). To keep with the car example, when installing a box of fuses, lights and plugs I do not actually use three different methods, but only one, which generically fits two-pin electrical thingamajigs into place, and takes the List of three Lists of fuses, lights, and plugs. The great majority of other methods are unfortunately not easily amenable to this approach. – LSerni Sep 16 '15 at 15:38
Somehow the problem reminds me of dependencies. You want a car in a specific configuration. Like Greg Burghardt, I'd go with objects/classes for each step/item/….
Each step declares what it adds to the mix (what it provides)(can be multiple things), but also what it requires.
Then, you define the final required configuration somewhere, and have an algorithm that looks at what you need, and decides which steps need to executed/what parts need to be added/which documents need to be gathered.
Dependency resolution algorithms are not that hard. The simplest case is where each step provides one thing, and no two things provide the same thing, and the dependencies are simple (no 'or' in the dependencies). For the more complex cases: just look at a tool like debian apt or something.
Finally, building your car then reduces to what possible steps there are, and letting the CarBuilder figure out the steps needed.
One important thing however is that you must find a way to let the CarBuilder know about all the steps. Try to do this using a configuration file. Adding an extra step would then only need an addition to the config file. If you need logic, try adding a DSL in the config file. If all else fails, you're stuck defining them in the code.
Sjoerd Job Postmus
  • 1,814
A couple of things you mention stand out as 'bad' to me
"My logic currently uses Reflection for simplicity of implementation"
There really is no excuse for this. are you really using string comparison of method names to determine what to run?! if you change the order will you have to change the name of the method?!
"The operations in a single phase are already independent"
If they are truly independent of each other it suggests that your class has taken on more than one responsibility. To me, both your examples seem to lend themselves to some sort of single
MyObject.AddComponent(IComponent component)
approach which would allow you to split the logic for each opperation into its own class or classes.
In fact I imagine they are not truly independent, I imagine that each examines the state of the object and modifies it, or at least performs some sort of validation before commencing.
In this case you can either:
  1. Throw OOP out the window, and have services which operate on the exposed data in your class ie.
    Service.AddDoorToCar(Car car)
  2. Have a builder class which constructs your object by assembling the needed data first and passing back the completed object ie.
    Car = CarBuilder.WithDoor().WithDoor().WithWheels();
(the withX logic can again be split into subbuilders)
  1. Take Functional approach and pass functions/delgates into a modify method
    Car.Modify((c)=> c.doors++);
Ewan
  • 70,664
  • 76
  • 161
  • Ewan said: "Throw OOP out the window, and have services which operate on the exposed data in your class" --- How is this not Object-oriented? – Greg Burghardt Sep 23 '15 at 12:12
  • ?? its not, its a non OO option – Ewan Sep 23 '15 at 15:06
  • You are using objects, which means it's "object oriented". Just because you can't identify a programming pattern for your code doesn't mean it's not object oriented. The SOLID principles are a good rule to go by. If you are implemented some or all of the SOLID principles, it is object oriented. Really, if you are using objects and not just passing structs around to different procedures or static methods, it is object oriented. There is a difference between "object oriented code" and "good code". You can write bad object oriented code. – Greg Burghardt Sep 23 '15 at 16:06
  • its 'not OO' because you are exposing the data as if it were a struct and operating on it in a separate class as in a procedure – Ewan Sep 23 '15 at 16:09
  • tbh I only added the leading comment to try and stop the inevitable "thats not OOP!" comments – Ewan Sep 23 '15 at 16:11
