I've started with TypeScript 2.5 years ago with Visual Studio and ASP.Net MVC. VS Web Essentials would compile ts files on save and the WebOptimizer library would bundle them together at runtime in a specific order. Basically a disaster, once the project was sufficiently large.
Than I had a look at some generated code by the gulp-angular generator. I took the best parts of it, added gulp to my build process and suddenly TypeScripts compiler took care of ordering my compiled JavaScript. The latest version of that generator is using webpack to compile and bundle TypeScript. This allows one to use ES6 styled imports, ... and that's great, but they didn't change anything else.
They are still using bower for client dependencies, even though you could use npm, and the style sheet compilation is also happening in gulp, even though webpack should be able to take care of that. Now, I love bower and the fact that I can configure all the steps, which should happen with the files. It seems very transparent to me, compared to webpack's black magic. I can split different files into vendor libraries and application and always know, what I get.
On the other hand, webpack alone might be great and easier to use for smaller projects. There is a (from my perspective) frightening example of code you can compile in webpack:
style.css
body {
background: yellow;
entry.js
require("!style!css!./style.css");
document.write(require("./content.js"));
The generated JavaScript file contains the CSS and adds it to the pages header. It shows webpacks capabilities, but who would want to do something like that?
So the questions:
- Is this generally a good approach? Why not using npm for client libraries as well?
- In which scenario is it a good approach to bundle CSS content into JavaScript files? (I really can't think of any)
- Why use webpack in the first place? Are there further advantages than having ES6 modules, instead of
///<reference path="..." />
