I understand the idea of package scope, and at times have even thought I wanted it. However, every time I set down with a serious intent to try using it I discovered it did not fit the needs I thought it would serve.
My main issue always seems to be that the things that I wish to limit the scope of are never in the same package. They may conceptually all be linked, but the logical division of data within the application has them as separate child packages of a larger package.
For instance I may have a Mission model and I want only other Mission tools, like my missionServices, to use some methods. However, I end up with Missions.models and Missions.services as my packages, so the MissionModel and MissionService are not the same package scope. It never seems like there is a situation where packages appropriately contain the things that I would want to have elevated permissions without also included numerous things I do not wish to have those permissions; and rarely do I feel the advantage of package scoping a method justifies modifying my project architecture to place everything in the same package. Often either Aspects or some sort of inversion of control turn out to be the better approach to whatever problem I briefly considered package scoping for.
I'm curious rather this is generally considered true across all Java developers, or is just a fluke of the work I do. Is package scope utilized much in the real world? Are there many cases where it's considered good form to use, or is it seen mostly as a legacy behavior to rarely be exploited in modern development?
I am not asking anything about why package private scope is default, I'm asking when it should be used regardless of the defaults. Most discussions as to why it is default don't really get into when package scope is actually useful, instead arguing simply for why the other two commonly used scopes should not be default so package wins by process of elimination. In addition, my question is about current state of development. Specifically, have we developed to the point where other tools and paradigms make package scope less useful then it was back when the decision to make it default made sense.
