I'm working on a small library that provides implementations of basic, well known string metrics. Mostly for my own education. So development happens whenever I've got a bit of spare time.
Because of this I've automated most processes so I can release a version as often as I work on it without too much effort. However maintaining the Java doc is still a burden because it includes examples.
As the API evolves I manually have to check each example over and over again. Is there a better way to do this?
I have considered moving the documentation and examples into a separate project (e.g. Caliper Tutorial) so it can be re-factored and compiled along with the regular code. However that does move the documentation away from the class it is about.
So yeah. I'd like to have my cake and eat it too. :D
* <h2>Tokenization</h2>
* Tokenization cuts up a string into tokens e.g.
* <code>chilperic ii son of childeric ii</code> is tokenized into
* <code>[chilperic, ii, son, of,
* childeric, ii]</code>. Tokenization can also be done repeatedly by tokenizing
* the individual tokens e.g.
* <code>[ch,hi,il,il,lp,pe,er,ri,ic, ii, so,on, of, ch,hi,il,ld,de,er,ri,ic, ii]</code>
* <p>
* <pre>
* <code>
* {@code
* return new StringMetricBuilder()
* .with(new SimonWhite<String>())
* .tokenize(new Whitespace())
* .tokenize(new QGram(2))
* .build();
* </code>
* </pre>
* <p>
If the above it too abstract. This is a sample of documentation. Currently I'm adding static constructors as advised by Effective Java e.g. Tokenizers.createQGram(2)
while depreciating the constructor method. Each time I do something like this, I'd have to update the example code above and check if it still works.
