So far I was under the perspective that while working in the kernel code, working with memory implies working with long integers
and not pointers because dereferencing pointers shouldn't be done in the kernel code:
A quote on the topic from LDD3:
Although, conceptually, addresses are pointers, memory administration is often better accomplished by using an unsigned integer type; the kernel treats physical memory like a huge array, and a memory address is just an indexinto the array. Furthermore, a pointer is easily dereferenced; when dealing directly with memory addresses, you almost never want to dereference them in this manner. Using an integer type prevents this dereferencing, thus avoiding bugs. Therefore, generic memory addresses in the kernel are usually unsigned long , exploiting the fact that pointers and long integers are always the same size, at least on all the platforms currently supported by Linux.
However, I see that there are pointers (source)
char *hwbuf = runtime->dma_area + frames_to_bytes(runtime, hwoff);
And I'm successful at dereferencing them and getting expected results:
printk(KERN_INFO "%s:%i %x \n", __FILE__, __LINE__,*hwbuf);
Questions:
- What memory address is allocated when
char *hwbuf
s run in the kernel? When I say "what memory" I mean if the address is an actual physical address in RAM or something else? - Is it sensible that different parts of the kernel act differently on pointer dereferencing given the relationship that code has on MMU initialization? By this I mean early kernel code deals with physical addresses, driver code deals with some form of virtual addresses?
- What are the basis for not dereferencing pointers in kernel code?
