I've been attempting to learn C++, but it is famously plagued by bad tutorials. I learned about a clever little trick called RAII (Resource Acquisition is Initialization), where one wraps a heap variable in an object placed on the stack. One would free the resources in the destructor of this object, so one would not have to worry about calling delete on the heap based object. However, I also know that you are supposed to create as few objects as possible, as to save RAM. Which brings me to my question, how much should I use RAII? Especially in a project that creates a lot of heap variables.
    recommended reading: **[On discussions and why they don't make good questions](http://meta.programmers.stackexchange.com/q/6742/31260)** – gnat Jul 23 '15 at 04:54
    "create as few objects as possible" Where did you get that idea from? – LorToso Jul 23 '15 at 06:09
    When to use RAII? Simple: everywhere. In fact C++ doesn't let you *not* to use RAII, ever class has a destructor even if a default one is created for you by the compiler. If you're using a lot of heap variables, look at the std:shared_ptr and std:unique_ptr. – gbjbaanb Jul 23 '15 at 07:59
  • I recommend looking for RAII tutorials, specifically ones updated to teach C++11 smart pointers and emplacement. RAII is essentially C++'s way of dealing with the same problem garbage collection deals with: how do I create a metric ton of objects and _guarantee_ they are cleaned up from memory when no longer needed? Use it _everywhere_ you cannot use simple stack storage. –  Jul 23 '15 at 10:34
    I disagree with the close votes on this because the question actually has a very simple and correct answer: Use RAII wherever it might be useful. – Ixrec Jul 23 '15 at 13:46
  • @Ixrec such an answer would be useless without explanation (think of how it would [poll](http://meta.programmers.stackexchange.com/questions/6483/why-was-my-question-closed-or-down-voted/6491#6491) against "almost never", "almost always" etc). And an explanation would likely involve a [list](http://meta.stackexchange.com/tags/list-questions/info) of various possible concrete cases when one should use it – gnat Jul 23 '15 at 13:50
How often should RAII be used?
As often as it makes sense to use (that is, whenever you have an operation that will need to be inverted/undone/closed/finalized/committed/etc. you should probably use RAII).
No; This is a form of premature optimization which is bad enough, but it also relies on a fallacy:
The number of variables in the code should not be a limiting factor in using RAII, because if you need a variable allocated, the allocation will be the same, whether it is in a wrapper or raw. An extra RAII wrapper will not add anything significant to the memory footprint of the application.
In other words, the following pieces of code should have the same (or comparable) memory footprints:
resource* allocate_resource() { return new resource{}; }
void release_resouce( resource * r ) { delete resource; }
// client code
auto r = allocate_resource();
release_resouce(r);
and
struct resource_ptr {
    resource * r_;
    resource_ptr() : r_ { new resource }{}
    ~resource_ptr() { delete r_; }
// client code:
resource_ptr p;
Both the resource* in the first sample and the resource_ptr instance in the second will have the same size (4 bytes on 32bit systems) and the calls to new/delete are in separate functions (which again, should have the same footprint whether in a structure or at top-level).
Something to keep in mind:
RAII can also be translated to mean "Responsibility acquisition is initialization", in which case, it will mean something more abstract (and larger) than "pointer/resource release in destructors". It effectively applies to any operation that requires a counter-operation later:
  • files that are opened will need to be closed
  • database transactions will need to be committed or rolled back
  • mutexes that are locked will need to be unlocked
  • network connections that have been opened will need to be closed
None of these are heap variables, but RAII applies naturally to all of them.
utnapistim
  • 5,285
