Consider the prototypes of C's dynamic allocation functions
malloc - void* malloc(size_t size);
calloc -  void* calloc(size_t n,size);
realloc - void* realloc(void* ptr,size_t newsize);
Now a statement like following
int* p=(int*)malloc(sizeof(int));
I know that casting to (int*) isn't needed in C since a void pointer can be assigned to a pointer variable of any object type, but why these functions by default not return fully typed pointer?. Wouln't it be nice if it returns int* instead of void pointer in this case? What is the reason void* is choosen as return type of these functions?
One other question: I've read here that in older C compilers the type of pointer returned by these functions was char* not void*. Is it true?
Destructor
  • 174
  • possible duplicate of [Why does void in C mean not void?](http://programmers.stackexchange.com/q/254181/31260) – gnat Jul 22 '15 at 18:50
    This is because these methods are allocating memory without any specific type. If `malloc` returned `int*` and you allocate only 1 byte, you would never be able to dereference it safely without casting. – Matthew Jul 22 '15 at 18:52
  • in C, it is a bad idea to have any casting at all when assigning the returned pointer from malloc (and family of functions) – user3629249 Jul 22 '15 at 20:13
    Questions are related but I am not convinced this is a duplicate. Having written the accepted answer on the dupe target, it would add insight to this question but I do not believe it would answer it. –  Jul 23 '15 at 10:37
Because it can't.
How would it return a fully typed pointer? C doesn't have templates/generics, and it doesn't allow function overloading; let alone overloading by return type only. So there's no mechanism to have a malloc that knew what type you wanted.
In C, there is no byte. char is guaranteed to be a byte long, so char* is canonical "a pointer to some byte buffer", which is exactly what memory allocation functions want to return.
Telastyn
  • 108,850
  • 239
  • 365
    conceptually, the returned value from malloc is a char pointer. However, that creates problems when needing to assign that pointer to some other type, such as a struct pointer. 'void', a relatively new keyword, eliminates the need for casting (and makes casting error prone, especially when performing maintenance on the code) – user3629249 Jul 22 '15 at 20:17
    @user3629249: No, conceptually it's a pointer to a new uninitialized memory-block, and you haven't decided what it should contain. – Deduplicator Jul 22 '15 at 22:31
    It might be worthwhile to add that `malloc` returned `char*` in the time before `void*` were invented. Once `void*` existed, the signature of `malloc` was quickly adjusted to follow suit. – Bart van Ingen Schenau Jul 26 '15 at 08:57
  • @BartvanIngenSchenau: It's too bad that C reused the "void" term from functions rather than adding an "untyped memory chunk" type which would allow the free casting of void*, but could also be read and written like "char*". That would allow code to exploit platforms whose minimal addressable unit is smaller than 8 bits and avoid the need to cast untyped memory pointers to char* before using them. – supercat Jan 29 '16 at 23:16
Of course malloc() could return a fully typed pointer. The problem is, of what type? If it returned an int*, it would make you happy, but it would not make me happy, because I want a char* instead. Clearly, we could not both have it our way. So, void* is a good baseline which does not take anyone's side.
Mike Nakis
  • 32,003
  • 76
  • 111
