I am currently trying to refactor some code and one of the problems I came across was the constructors had far too many parameters (15 in fact) and was being initialised by another object which had the same amount of properties.
I am meant to be reducing the amount of classes we have so creating a set of classes which represented the different parts of the parameters seemed silly so I began looking and the best answer I came across was from this question on stackoverflow.
public class DoSomeActionParameters
readonly string _a;
readonly int _b;
public string A { get { return _a; } }
public int B{ get { return _b; } }
DoSomeActionParameters(Initializer data)
_a = data.A;
_b = data.B;
public class Initializer
public Initializer()
A = "(unknown)";
B = 88;
public string A { get; set; }
public int B { get; set; }
public static DoSomeActionParameters Create(Action<Initializer> assign)
var i = new Initializer();
assign(i)
return new DoSomeActionParameters(i);
which can be called like so using a lambda
DoSomeAction(
DoSomeActionParameters.Create(
i => {
i.A = "Hello";
I really liked this method even though it doesn't solve directly the problem of actually initialising the class, it does make it mean that I can have one constructor instead of 3. Also it doesn't require my class to know about objects it doesn't care about.
My problem is however, I do not know what this pattern is called so I can't do any further research on it to find out if it is still valid, is superseded by another pattern or whether it has sever performance issues. From my research the closest pattern I could find is the builder pattern but it seems to be more of an extension on that.
As a bonus point, it would be great if you could give me a hand with how to make certain parameters mandatory as we have about 10 parameters from the database and 5 more which are just flags which we don't really need to know about.
