I'm trying develop an add-in for an application using it's API and I have Option Strict turned on. Trying to work with these COM objects is causing multiple compile issues saying
Option Strict On disallows implicit conversions from 'typeA' to 'typeB'.
I'm currently overcoming the issue by using DirectCast, which means I have to define the type in multiple places, which makes future code maintenance kind of sucky.
A simple example is:
Dim templateMgr As IEdmTemplateMgr5 = TheVault.CreateUtility(EdmUtility.EdmUtil_TemplateMgr)
The CreateUtility method returns an object which implements the interface specified by the argument (argument is an EdmUtility Enum value).
The return is specified at compile time as System.Object
so must be cast to the right type in order to use it.
With option strict on I cannot do this implicitly, so I have been using DirectCast
thusly:
Dim templateMgr As IEdmTemplateMgr5 = DirectCast(TheVault.CreateUtility(EdmUtility.EdmUtil_TemplateMgr), IEdmTemplateMgr5)
There are many, many, many (that many!) COM members that use generic members that make the compiler very unhappy with Option Strict
turned on.
I don't particularly like using DirectCast()
because it means declaring the type in multiple places scattered all throughout the code.
Is this a case where it's better to just turn off Option Strict
I feel like there has to be a better way!
EDIT 1
My compile options are:
- Option Explicit = ON
- Option Strict = ON
- Option Infer = ON
- Option Compare = Text
- Target CPU = AnyCPU
EDIT 2
Here is another example that isn't just creating a new object instance. In this example I am using a loop to get information on all the objects in an array that returned by another function.
The return from Data.Get
is always type System.Object
which again causes teh compiler to complain that implicit conversion from type 'Object' to type 'String' is not allowed with Option Strict on.
Dim DataReturn As System.Array
Dim refreshFlag As Long
Try
refreshFlag = TheTemplate.RunEx(TheCommand.mlParentWnd, TheVault.RootFolderID, DataReturn)
If Not DataReturn.IsAllocated Then Throw New Exception("Nothing was created by the template.")
'Refresh the folder view if required
If refreshFlag = EdmRefreshFlag.EdmRefresh_FileList Then TheVault.RefreshFolder(TheVault.RootFolderPath)
'Return the path(s) of the newly created file(s)
Dim path As String = String.Empty
For Each data As EdmData In DataReturn
Select Case data.Type
Case EdmDataType.EdmData_File
path = DirectCast(data.Get(EdmDataPropertyType.EdmProp_Path), System.String)
If path.Length > 0 Then CreatedFilesPaths.Add(path)
path = String.Empty
End Select
Next
