I've ran into several oddities using javascripts floating point arithmetic, but I can never recall them off the top of my head!
What are some common mistakes when using JavaScript to do math?
The common problems with javascript arithmetic relate to the use of parseInt
, or the lack of.
Not using radix when converting strings to integers:
parseInt("0137"); // 95!
parseInt("0137", 10); // 137
Not using parseInt
at all with arithmetic:
var a = "2";
alert(a + 5); // 25
alert(a - 5): // -3!
Misunderstanding floating point arithmetic (applies to all languages, not just JS):
alert(23 * 1.40 == 32.2); // false, 23 * 1.40 is represented as 32.199999999
alert((23 * 1.40).toFixed(1) == 32.2); // true
Calculating currency with floating points may lead to rounding errors, currency values should be treated as integers (multiplied with 100) before processing.
A common mistake (although with strings & integers, not floats) is forgetting that JavaScript doesn't have strong typing. So you can run into situations where:
var myVar = 7; // 7
myVar += 5; // 12
var myVar = "7"; // 7
myVar += 5; // 75
var myVar = "cat"; // cat
myVar += 5; // cat5
All of these are perfectly valid statements in JavaScript.
But it gets weirder, because while "7" and "cat" are both strings, not all strings are treated the same:
var myVar = 77;
parseInt(myVar); // 77
var myVar = "77";
var myVar = "cat";
parseInt(myVar); // NaN
var myVar = "77cat";
Not to mention that (as @Tatu wrote):
var myVar = "077";
parseInt(myVar); // 63
