23
Exhibit 1, Exhibit 2, I guess you won't find it hard to recall other examples.
Thing is: if there is more than one way to solve a problem, the PHP programmer (I usually browse the PHP tag on StackOverflow) will ask for help on the solution involving regular expressions.
Even when it will be less economic, even when the php manual suggests (link) to use str_replace instead of any preg_* or ereg_* function when no fancy substitution rules are required.
Does somebody have a clue about why this happens?
Don't get me wrong, some of my best friends are regular expressions and I don't despise Perl. What I don't get is why there is no looking for alternatives whatsoever, even when the overkill is obvious (regex to switch strings) or the code complexity rises exponentially (regex for getting data from html in PHP)
cbrandolino
  • 1,999
    You might want to quote what the php manual actually says. – ChrisF Dec 21 '10 at 11:32
    Because they're cryptic, so you want to be part of the exclusive kewl kidz' club? And mostly because they provide a short way of expressing a match or extraction, which is what they're made for. Sure for dummy cases, custom parsing if better, but the dev time over writing a quick regex is in favor of the regex. – haylem Mar 05 '12 at 02:31
  • You emphasized the wrong part of that last sentence: The outrageous part of it is "from html", not "in PHP". – Izkata Mar 05 '12 at 03:48
17 Answers17
49
When the only tool you have is a regex, every problem looks like ^((?>[a-zA-Z\d!#$%&'*+\-/=?^_{|}~]+\x20*|"((?=[\x01-\x7f])[^"\\]|\\[\x01-\x7f])*"\x20*)*(?<angle><))?((?!\.)(?>\.?[a-zA-Z\d!#$%&'*+\-/=?^_{|}~]+)+|"((?=[\x01-\x7f])[^"\\]|\\[\x01-\x7f])*")@(((?!-)[a-zA-Z\d\-]+(?<!-)\.)+[a-zA-Z]{2,}|\[(((?(?<!\[)\.)(25[0-5]|2[0-4]\d|[01]?\d?\d)){4}|[a-zA-Z\d\-]*[a-zA-Z\d]:((?=[\x01-\x7f])[^\\\[\]]|\\[\x01-\x7f])+)\])(?(angle)>)$
glenatron
  • 8,729
  • 43
    The temptation to chose this answer is so strong, but I guess I must resist since it's my first question open here and I have to feign seriousness for a while. – cbrandolino Dec 21 '10 at 12:58
  • @cbrandolino: The best practice we've come up with on SO is not to accept an answer immediately but to give it 1-2 days for everyone to have contributed their answer and then choose the best one. –  Dec 21 '10 at 13:21
    @Dev, it makes plenty of sense. My comment was just a supposedly funny way to express my appreciation for the answer. – cbrandolino Dec 21 '10 at 13:23
    What on earth does this match? – Tom O'Connor Dec 21 '10 at 13:45
    I dunno... I think this pretty much sums up the whole of it. If you know regex, and don't know about the other methods, why would you go looking? You've already got a tool that, if done correctly, will handle the job. Until they stumble across the simpler method or are told about it, regex will be the catch-all method, even if more complex than it need be. – Aeo Dec 21 '10 at 13:55
  • It looks like you're trying to match something with HTML tags. This is a [Bad Idea™](http://stackoverflow.com/questions/1732348/regex-match-open-tags-except-xhtml-self-contained-tags/1732454#1732454) – Alan Pearce Dec 21 '10 at 15:15
    @Tom O'Connor I think it's something close to the Regex for matching an RFC 2822 email address, but I had to take out a couple of characters because they were wreaking havoc with the markdown. – glenatron Dec 21 '10 at 15:25
  • @Aeo: Except that regexes don't solve all problems, including some they come close to solving. – David Thornley Dec 21 '10 at 15:53
    That’s just bull. Learn out to write [proper modern regexes](http://stackoverflow.com/a/4234491/471272). – tchrist Mar 04 '12 at 23:55
  • @tchrist That whistling sound was the joke going right past you. – glenatron Mar 05 '12 at 09:44
23
I think it's because:
  1. They are fantastically concise (when used properly) compared to the equivalent code, and
  2. They are widely supported across programming languages, so most developers are familiar with them.
hallidave
  • 311
In earlier phases of my career (ie. pre-PHP), I was a Perl guru, and one major aspect of Perl gurudom is mastery of regular expressions.
On my current team, I'm literally the only one of us who reaches for regex before other (usually nastier) tools. Seems like to the rest of the team they're pure magic. They'll wheel over to my desk and ask for a regex that takes me literally ten seconds to put together, and then be blown away when it works. I don't know--I've worked with them so long, it's just natural at this point.
In the absence of regex-fluency, you're left with combinations of flow-control statements wrapping strstr and strpos statements, which gets ugly and hard to run in your head. I'd much rather craft one elegant regex than thirty lines of plodding string searching.
Dan Ray
  • 9,106
  • 49
    I can't upvote this enough. – CaffGeek Dec 21 '10 at 15:54
    I'm curious: do you *read* regexp's as fluently as you write them? – peterchen Dec 21 '10 at 16:56
    I hope you're holding regular regex training sessions and/or documenting the hell out of your code; otherwise you are creating a support nightmare for your coworkers. The time you saved by writing that regex may be lost a hundred times over by people trying make sense of what that "elegant regex" is doing. – Jeff Knecht Dec 21 '10 at 20:11
    So great. You can hear the tug-of-war between loving and hating regexes right here in these comments. – Dan Ray Dec 21 '10 at 20:50
  • @peterchen, I can't speak for Dan, but I personally don't think a well-written and appropriately-commented regex is any more difficult to read than a well-written and appropriately-commented traditional method. Most regexes (like most methods) are simple enough to not need any commenting, and these ones I can read as fluently as I can write. – Ben Lee Feb 13 '12 at 20:32
    @Ben Lee: I guess so - OTOH, I've never encountered a commented regex in the wild. Some of the problems with regexes may be based on an attitude of coolness. – peterchen Feb 15 '12 at 16:31
    @peterchen [Read ’em and weap!](http://stackoverflow.com/a/4234491/471272) – tchrist Mar 04 '12 at 23:37
20
Why are regular expressions so morbidly attractive?
Because on the subconscious level they feel like an entire smart program who can accomplish a lot on its own accord while being encompassing and self-adjusting (think patterns).
This is why people immediately believe regular expressions will solve any of their text-based task, somehow not thinking it might be overkill and not realizing it might me underkill (parsing languages with it).
A tiny thing containing magic power. You can't say no, can you?
16
On the contrary. People are parrotting the regex are evil meme way too often IMO. It's obvious that preg_match is overused in php, but it's less obvious that it's oftentimes sensible to do so (in PHP).
I would go so far and conjecture that it's yet another microoptimization in php land to use the string functions. There are many and many useful, and they are usually the better choice. But you shouldn't shun preg_match in favour of multiple strpos and if chains. Because in practice it turns out, libpcre is often faster than PHP can execute a loop looking for string alternatives e.g.
As a recent example made me realize, testing if a string is all-lowercase:
 if ($string == strtolower($string))
Is more readble than:
 if (!preg_match("/[A-Z]/", $string))
And you would assume the first must be faster, since it's all-PHP. But in reality the regex only looks over the string once, and can abort the negated condition as soon as it finds an uppercase letter. The strtolower() approach however looks over the string twice. First strtolower() makes a string duplicate by iterating over each letter, comparing and uppercasing it. Then the == iterates over the original and the copy again, comparing them once more.
So that's not an obvious case. And to be objective the first one is often faster, since you normally just compare short strings. But it's imperative to not go blindly by the assumption that PHP string functions are always advisable over regular expressions.
(I'm tempted to add another rant about @bobince's fun answer regarding xhtml-regexes, and how it's recently often linked in a very unhelpful manner. And the more objective answers below go ignored.)
mario
  • 2,263
    I agree with your example; still, in this particular case, I would prefer ´strtolower()´ anyway: in non-critical code, even such a big (relatively to the other implementation) execution time optimization is insignificant - unless you want to evaluate the lower-case-ness of a huge text file, but I can't imagine a case in which that would be useful. – cbrandolino Dec 21 '10 at 12:56
  • Oh and yes, I do realize the irony of criticizing PHP micro optimizations, yet center my example on which is faster. – mario Dec 21 '10 at 12:57
    @cbrandolino: No discussion there. This stuff should only every be relevant and evaluated for nested loops, where it *might* make a factual difference. – mario Dec 21 '10 at 12:59
    +1 For the fact people always bash them, far more than they are supported. – Orbling Dec 21 '10 at 13:47
    As one of the "regexp bashers": It's fun to see a one-liner more or less express what "manual" string parsing nedds 30 lines for. However, maintenance suffers in most realistic examples. In addition, when trying to apply them to unvalidated input, generating suitable diagnostics for rejected input requires additional acrobatics. For me, it's the prototypical "write only" code - cool for quick scripts, sucksfor long-living apps. – peterchen Dec 21 '10 at 16:54
    Anybody who isn’t writing all his regexes in `/x` mode to allow for whitespace for the elbowroom of cognitive chunking, and for comments to explain why things are being done, should of course have his ears boxed. But for real regexes of reasonable complexity, you need to consider applying [top-down design via grammatical regexes](http://stackoverflow.com/a/4234491/471272). Once you have seen the light, you’ll never go back to `/@#$^^@#$^&&*)@#/`. – tchrist Mar 04 '12 at 23:52
  • @peterchen **Perl pioneered the unit test scene.** Why? Tests are so *darn easy* to write with regexps, they pretty much tested (and still test) everything with little effort. That looks... maintanable to me. It kind of collapsed under the lack of syntax sugar for too many things, though. *(function arguments, objects, classes, inheritance)* and that lack of syntax sugar made most perl code unmaintainable. The regexes, if any, only helped keeping code maintainable. – ZJR Mar 05 '12 at 00:33
Regular expressions are very attractive because they are the best tool for parsing a regular language.
They have the following advantages:
  • They are concise. It generally takes a lot more code to parse a specific regular language using a specific algorithm that you have come up with than with a regexp.
  • They are quick to use. It generally takes a lot more time to write a parser for a specific regular language using a specific algorithm that you have come up with than with a regexp.
  • They are easy. Once you learn the set of special characters and their meanings, it is easy to compose a regexp (although a little harder to read them). Regexps are languages themselves - a useful trait because our species has evolved to be very good at language.
  • They are fast. Once compiled, they can match a string length N in O(N) time.
  • They are flexible. They can match any regular language and a lot of our data is expressed as a regular language.
  • They are ubiquitous. Most programming languages have basic regexp support - either through external libraries or embedded into the language itself. There is also not too much variation between the regexp languages themselves.
This makes them attractive for situations to which they are suited, but people may use them in contexts where they are not the best tool, because they:
  • Don't understand that what they are matching can't be expressed using a regexp (eg. HTML).
  • Are lazy (in a bad way) - they know a tool and recognise that it isn't the best tool for what they are doing but it will work without problems 95% of the time and takes 95% of the effort of learning a particular parser or writing one from scratch.
  • They are unaware that better tools exist.
david4dev
  • 648
  • Er, I was referring to some particular cases in which they are evidently not the best way to proceed but are still used. I like regex (I mean, I find them boring and lifeless but still very useful in some contexts), and know what their advantages are. – cbrandolino Dec 21 '10 at 15:39
  • I agree with the rest, but quick & easy? The learning curve is steep: for a beginner, it's hard to figure out *why* an expression doesn't work, and every regexp implementaiton seems to have at least subtle differences, so oyu have to watch out where you try to learn from. – peterchen Dec 21 '10 at 16:59
  • Why is it that everyone confuses pulling out little bits of HTML with completely parsing a full-blown web page into a full parse tree? ***It’s really stupid.*** Believe me, when I edit HTML pages in `vi`, you bet your life I use `:%s/foo/bar/gc` on it. If it’s good enough for an editor, it’s good enough for a script. – tchrist Mar 04 '12 at 23:54
Hmmm, I can only guess. Maybe some people have experienced that 30 lines of their code were replaced by a 20-character-long regex, so it feels wrong to them to use anything else instead when regexes can be used.
user281377
  • 28,352
  • 75
  • 130
It fits with how some people think. I don't like them, but I have friends who seem to think in regexps. I guess the pattern matching part of their brain is more exposed than the formal logic one. :-)
Lennart Regebro
  • 2,265
    In terms of our evolutionary history that stands to reason. We were matching patterns long before we were defining grammars or discovering syllogisms. – glenatron Dec 21 '10 at 11:35
    I disagree, programming involves logic and pattern matching, two areas. Regexps are *very* good at pattern matching and should be used for such tasks. Too say "I don't like them", is to throw away a good tool for a particular job. – Orbling Dec 21 '10 at 13:48
  • @Orbling: The question is not of they are good or bad, but why some people overuse them and others don't. – Lennart Regebro Dec 21 '10 at 21:17
  • The question may be, but your answer suggests one or the other type of mind is at play, rather than both. – Orbling Dec 21 '10 at 21:21
  • I don't think "suggest" is the correct word. – Lennart Regebro Dec 21 '10 at 21:31
I think the ubiquity of regex is due to the ubiquity of strings. The string is the simplest data structure, the first one that most of us learn. Since all of our code is written in symbolic form, it is natural for a programmer to consider modelling something in symbolic form. But if our programming language offers any resistance when we try to extend its syntax for our clever new symbolic forms, they all end up between quotes. The relational data model has SQL. The XML data model has XQuery. But what about the humble string data model? Regex!
Just yesterday, I was looking over the API for a shiny new Javascript framework that supports HTML5 game development. It has a declarative mechanism for describing the main subsystems that your game would need. How does one specify those features? JSON? Fluent dot notation? An array? Nope -- a string containing a comma- and whitespace-separated list of feature names. I wonder how it parses that list... ?
WReach
  • 131
Because you can see the whole thing at once. By being able to see the whole thing, it can be easier to work with, and that's always nice. It's sort of like the reason that many C++ programmers still use printf-type statements: It's not typesafe (though gcc at least can check types on printf statements), and it's not pretty, but boy is it compact and usable.
If it's a simple enough regex, then they often ARE the best way to do things - their compact form and many capabilities make them perfect for certain tasks. The problem comes when you make the regex so complicated that you can't read it anymore, or when you're using a complex regex to do something that could be more quickly done via simple string operations.
Regex, like any other powerful tool, must be use in proper moderation - not too much, not too little. And unless performance is a big concern, a single regex may at times be quicker to write and easier to debug than a series of string operations.
Michael Kohne
  • 10,038
  • 45
Hmm, the current answers center too much on technical aspects, and the readability pros/cons (which is an important point). So let me try to shift it a bit more onto the PHP environment/community:
  • PHP is Perls little stepsister. And an integral part of Perl are regular expressions (they invented that stuff, didn't they?). Therefore it's one cause why regexps are pervasive in PHP too.
  • The use case of PHP is coincidentally not much unlike the use case for regular expressions. PHP is structurally used for glueing together HTML pages. And regexps work on text. (what WReach said)
  • Micro optimization. As mentioned before: people use regexps and/or PHP string functions frequently after perceived speed. A core problem in PHP circles, not specific to regexps.
  • Regular expressions are built-in. In Python, in Java, in C#, in Ruby? there is availability, but a deterrent in having to load an extra module. And see how in PHP or Javascript where it's a core feature, the usage pattern differs. Another exhibit: CSS where it's getting more frequently used.
  • The PHP manual is at fault. It often is. Regular expressions are easily discoverable, and I postponed this fun fact because it's boring in its obviousness: all the damn tutorials and PHP introduction books always teach about regular expressions, but fail to educate on use cases.
  • The string API in PHP was designed by the same people that brought you magic quotes and the namespace \ separator. It's encompassing, better than Java, but not glamorous in its entirety. Particularily if strings could double as objects (see Python), string functions might outdo regexps.
But that just as side notes. I believe it's anyway mostly perceptional and technical reasons that lead to overuse and/or shunning regular expressions in general. Yet PHP and its userbase has a few properties which compound it, and why we see more questions on SO about it [citation needed!] and they are "morbidly attractive" there.
mario
  • 2,263
They're not. They're actually ugly as hell. And incomprehensible. They're an abomination that should be killed as soon as possible.
Now, this being said, I'm going back to debugging a little Perl app. Can't help it; unfortunatelly, they're still the best tool for the job sometimes.
Rook
  • 19,861
  • 53
  • 96
    I'm fond of saying that regular expressions are neither "regular" nor "expressive" – Andrew Barber Dec 21 '10 at 12:47
    They're ugly and incomprehensible if you don't understand them. Once you achieve the zen of regex, they're really quite elegant. – Dan Ray Dec 21 '10 at 13:09
  • -1 For the abomination comment, even if you do save yourself a little at the end. ;-) They are a thing of beauty - all programmers should be able to read them as easy as they read algebra, and if they can't read algebra either they should become a politician instead. – Orbling Dec 21 '10 at 13:52
  • @Orbling - It has been my experience that a (very large) lot of programmers are not good at algebra either. – Rook Dec 21 '10 at 13:56
  • @Rook: It's a wonder to me how they cope. :-/ Every *decent* computing course I've seen requires a good maths qualification as its primary requirement; for very good reason. When hiring new programmers, I test their maths more than their coding skills (see: http://programmers.stackexchange.com/questions/20927/what-is-your-favorite-whiteboard-interview-problem/28439#28439) – Orbling Dec 21 '10 at 14:04
    -1 For deciding that all programmers like to be obscure, and then not considering any other possible explanation. ...Stating why you think they are ugly or incomprehensible would have helped. – Macneil Dec 21 '10 at 14:06
  • @Dan Ray - Yes, well, one can believe anything if one puts enough faith in it (as history has shown). However, if I take that 99% of people (non programmers) don't understand them, and that let's say 1/3 of the remaining (programmers) don't understand them, and that the remaining who do understand them bitch about them all the time ... yes, then I can safely presume that they're not that understandable. Exceptions exist, but that doesn't make them any better. – Rook Dec 21 '10 at 14:06
    @Macneil - Please, (although yes, my thoughs are along that line), unless you're quoting me don't state that I said/decided on something I didn't (the first part of your comment). As far as your question, you find them beautiful?! ... I don't. And since this is a subjective site, and that is a subjective opinion, I don't have to nor wish to elaborate on it. Nor will I try, for that matter. – Rook Dec 21 '10 at 14:14
    @Rook - I think most people look at a complex regular expression, decide all regular expressions are ugly, and then stop thinking. The fact is, they're a very elegant and expressive tool if you can set down your prejudice about them. BTW, by your own logic, a lot of programmers can't do algebra, so algebra is probably inherently evil and should be abolished since it's clearly not very understandable. – Dan Ray Dec 21 '10 at 14:15
  • @Orbling - No, every decent computing course requires *a maths* qualification ... *a good maths* qualification is something else completely, and often isn't in the domain of engineers, but mathematicians. – Rook Dec 21 '10 at 14:18
  • @Dan Ray - Please, don't do that (think instead of me). For I do not agree ... hell, I've used REs from I don't know, early 90s, and I still think them as ugly. They're hard to read, often misread, and once written hard to process into a simpler form. Unless algebra, which is quite the opposite. – Rook Dec 21 '10 at 14:26
    Also, unlike maths which have a few simple rules, which produce a lot, REs have a lot of rules, and not knowing one of them, can produce hell. There is no simplicity in it; there is just a "learn them well or there'll be hell" approach. Which I find plain and simple, ugly. – Rook Dec 21 '10 at 14:43
  • @Rook: Oh please, I have to quote you verbatim, because saying something where your "thoughts are along that line" isn't good enough? You can't have it both ways; own up to what the content of your rant/joke really is. – Macneil Dec 21 '10 at 15:12
    @Macneil - The devil's in the details, as the old saying goes. And no, I won't pick sides; my reasoning is given above for the interested. – Rook Dec 21 '10 at 15:14
  • @Rook: I'm not asking you to "pick sides." What I mean by "you can't have it both ways" is that you cannot post a rant that insults most every programmer and then say "oh, I didn't really mean that, you're putting all of these words in my mouth, I only said something *like* that!" – Macneil Dec 21 '10 at 15:33
    @Macneil @Rook: I may have voted Rook down for extremely negative comments, but his argument is not wholly without merit and he did state that he uses them himself as they are "the best tool for the job sometimes". So he is not wholly anti, he just finds them ugly - which indeed they could be described as such, many people, including me, say the same of Picaso. – Orbling Dec 21 '10 at 17:39
  • @Macneil - I did not mean to insult anyone by my post/comments. I'm sorry if it was interpreted that way, for that was not my direct or indirect intention. – Rook Dec 21 '10 at 19:33
    @Orbling - Yes, that sums it up nicely (including the Picasso part ;) – Rook Dec 21 '10 at 19:35
  • I think economics gives a good first lesson: Assume people are rational. We know that's not always the case, but many interesting results in economics show us that we can have nice explanations for many complex things. Anyway, if you re-edit your answer I can then change my vote. – Macneil Dec 21 '10 at 19:52
  • @Macneil - Changed to a somewhat more moderate tone. (I'm not changing the part about them being ugly though ;) – Rook Dec 21 '10 at 20:04
  • OK, now that puts you into neutral territory. – Macneil Dec 21 '10 at 21:13
I like regular expressions in general I find them easier to read/understand than the 20 lines of code I would have to replace them with. Short regular expressions are quickly read and understood and they are relatively easy to maintain (if the expression changes you only have one line to change versus looking through the 20 lines of code to make the change). There are times where they are misused but so are many other things.
The reason you probably see so much abuse of them is because your browsing the PHP section of StackOverFlow as I am sure you are aware there are a lot of umm immature PHP programmers out there.
stoj
  • 249
In my experiencie, regexes are like an ancient art, something obscure, some peolpe resent them because they can't understand the sorcery involved and maybe because nobody will explain them to you. I haven't heard of universities teaching them for something less trivial than matching an e-mail. Then there's the mystical inner workings of it, since most people don't understand them, they must be slow. And getting them to work fine in the first try is always a challenge for newcomers.
The same thing can be said about Perl, awk, Linux, and everything that has no shiny buttons or nice colored syntax. So, it's like added complexity to "trivial tasks", just throw some loops, splits, a switch, some magic and that's it, something that might work. But well, if you are on the other side of the road, regexes are beautiful cookie cutters that look like signal noise without any nasty loops or more stuff to debug. I like them also for the flexibility they provide. When the pattern to match changes, you just change the regex, not the algorithm, or tool/whatever, and it's nice and working again. And since they are a magical string, you can put it outside the sourcecode if you wish. And another thing that makes me think of perl, if you write a regex that's 20+ chars long, it feels that you accomplished a lot, at least for me, it's just so neat and compact. I'm a lazy programmer also, i don't like writing a lot of code with nice identation and comments and adding some bugs to the mix.
alfa64
  • 413
Man is a tool-using creature, and regular expressions are powerful tools. A nice metaphor for regular expressions is a meat slicer from a deli. If you want paper-thin slices of turkey, corned beef, etc., it's just the thing. However, you need skilled hands to use it, because you can cut yourself really badly with it and you won't feel a thing until you see the blood. What I mean by this is that the big problem with regular expressions is getting them slightly off means that you match something you shouldn't, or vice versa, and you don't find out until it causes an issue further along in the process.
Larry Coleman
  • 6,101
Regular expressions are very attractive because they wield power. You can do a very complicated piece of work in very few characters.
The problem is that the standard regular expression construct is not Turing-complete which means that there are programs you simply cannot implement with a regular expression, and people don't KNOW that when they are lured by the apparent power of regular expressions.
This - I guess - is the reason for the jwz-quote of "now they have two problems".
I would guess that Perl regular expressions are Turing-complete, but apparently it has not been decisively proved or disproved yet.
Because it's an efficient way to program a finite state machine, which is a powerful tool when it applies. It's basically it's own language for programming FSMs, which is helpful if you know the language, annoying if you don't.
DanTilkin
  • 101
