I am aware that the concept of invariants exists across multiple programming paradigms. For example, loop invariants are relevant in OO, functional and procedural programming.
However, one very useful kind found in OOP is an invariant of the data of a particular type. This is what I'm calling "type-based invariants" in the title. For example, a Fraction type might have a numerator and denominator, with the invariant that their gcd is always 1 (i.e. the fraction is in a reduced form). I can only guarantee this by having some kind of encapsulation of the type, not letting its data be set freely. In return, I never have to check whether it's reduced, so I can simplify algorithms like equality checks.
On the other hand, if I simply declare a Fraction type without providing this guarantee through encapsulation, I can't safely write any functions on this type which assume that the fraction is reduced, because in the future somebody else could come along and add a way of getting hold of a non-reduced fraction.
Generally, the lack of this kind of invariant might lead to:
  • More complex algorithms as pre-conditions need to be checked/ensured in multiple places
  • DRY violations as these repeated pre-conditions represent the same underlying knowledge (that the invariant should be true)
  • Having to enforce pre-conditions through runtime failures rather than compile-time guarantees
So my question is what the functional programming answer to this kind of invariant is. Is there a functional-idiomatic way of achieving more or less the same thing? Or is there some aspect of functional programming which makes the benefits less relevant?
Ben Aaronson
  • 6,883
  • 30
  • 30
  • many functional languages can do this trivially... Scala, F#, and the other languages that play nicely with OOP, But Haskell too... basically any language that allows you to define types and their behavior supports this. – AK_ May 21 '15 at 12:32
  • @AK_ I'm aware F# can do this (though IIRC it requires some minor hoop-jumping) and guessed Scala could as another cross-paradigm language. Interesting that Haskell can do it- got a link? What I'm really looking for is the *functional-idiomatic* answer, rather than specific languages which offer a feature. But of course things can get rather fuzzy and subjective once you start talking about what is idiomatic, which is why I left it out of the question. – Ben Aaronson May 21 '15 at 12:38
    For cases where precondition can't be checked at compile-time, it is idiomatic to check in the constructor. Consider a `PrimeNumber` class. It would be too expensive to perform multiple redundant checks for primality for each operation, but it is not a kind of test that can be performed at compile-time. (A lot of operations you would like to perform on prime numbers, say multiplication, do not form a [closure](http://en.wikipedia.org/wiki/Closure_%28mathematics%29), i.e. results are probably not guaranteed prime. (Posting as comments since I don't know functional programming myself.) – rwong May 21 '15 at 12:53
  • A seemingly unrelated question, but ... [Are asserts or unit tests more important?](http://programmers.stackexchange.com/questions/18288/are-asserts-or-unit-tests-more-important) – rwong May 21 '15 at 12:58
  • @rwong Yeah, some nice examples there. I'm actually not 100% clear what ultimate point you're driving at, though. – Ben Aaronson May 21 '15 at 13:01
  • @BenAaronson (Since I don't know functional programming, I can't provide an answer, but I can still provide some language-agnostic ideas.) My point is that whenever a new value (instance) is produced, the responsible party is also responsible for: asserting (i.e. taken as truth) whether the invariant is universally upheld or broken; if not asserting, it must request a runtime check on that invariant. Some responsible party must declare this somehow (say, the multiplication operator on `ReducedFraction`). – rwong May 21 '15 at 13:08
Encapsulation is not a feature that came with OOP. Any language that supports proper modularization has it.
Here's roughly how you do it in Haskell:
-- Rational.hs
module Rational (
    -- This is the export list. Functions not in this list aren't visible to importers.
    Rational, -- Exports the data type, but not its constructor.
    ratio,
    numerator,
    denominator
    ) where
data Rational = Rational Int Int
-- This is the function we provide for users to create rationals
ratio :: Int -> Int -> Rational
ratio num den = let (num', den') = reduce num den
                 in Rational num' den'
-- These are the member accessors
numerator :: Rational -> Int
numerator (Rational num _) = num
denominator :: Rational -> Int
denominator (Rational _ den) = den
reduce :: Int -> Int -> (Int, Int)
reduce a b = let g = gcd a b
             in (a `div` g, b `div` g)
Now, to create a Rational, you use the ratio function, which enforces the invariant. Because data is immutable, you cannot later violate the invariant.
This does cost you something, though: it's no longer possible for the user to use the same deconstructing declaration as denominator and numerator use.
Sebastian Redl
  • 14,950
  • 51
You do it the same way: make a constructor that enforces the constraint, and agree to use that constructor whenever you create a new value.
multiply lhs rhs = ReducedFraction (lhs.num * rhs.num) (lhs.denom * rhs.denom)
But Karl, in OOP you don't have to agree to use the constructor. Oh really?
class Fraction:
  Fraction multiply(Fraction lhs, Fraction rhs):
    Fraction result = lhs.clone()
    result.num *= rhs.num
    result.denom *= rhs.denom
    return result
In fact, opportunities for this kind of abuse are fewer in FP. You have to put the constructor last, because of immutability. I wish people would stop thinking of encapsulation as some sort of protection against incompetent colleagues, or as obviating the need for communicating constraints. It doesn't do that. It just limits the places you have to check. Good FP programmers also use encapsulation. It just comes in the form of communicating a few preferred functions to make certain kinds of modifications.
Karl Bielefeldt
  • 146,727
  • 38
  • 279
  • 479
  • Well it's possible (and idiomatic) to write code in C#, for example, which doesn't allow what you've done there. And I think there's a pretty clear difference between a single class being responsible for enforcing an invariant and every function written by anyone, anywhere which uses a certain type having to enforce the same invariant. – Ben Aaronson May 21 '15 at 12:58
  • @BenAaronson Notice a difference between *"enforcing"* and *"propagating"* an invariant. – rwong May 21 '15 at 13:02
    +1. This technique is even more powerful in FP because immutable values don't change; thus you can prove things about them "once and for all" using types. This isn't possible with mutable objects because what's true for them now may not be true later; the best you can do defensively re-check the object's state. – Doval May 21 '15 at 13:26
  • @Doval I'm not seeing it. Putting aside that most(?) major OO languages have a way of making variables immutable. In OO I have: Create an instance, then my function mutates the values of that instance in a way that may or may not conform to the invariant. In FP I have: Create an instance, then my function creates a second instance with different values in a way that may or may not conform to the invariant. I don't see how immutability has helped make me feel any more confident that my invariant is conformed to for all instances of the type – Ben Aaronson May 21 '15 at 13:54
  • @Ben, my point isn't that those OOP constructs don't exist. It's that every programmer must *agree* to use those constructs that help enforce the invariant. In FP, you make a similar agreement to use the constructors. – Karl Bielefeldt May 21 '15 at 13:58
  • @KarlBielefeldt But again, in OOP the programmers agreeing are the programmers writing the `Fraction` class. In FP, the programmers agreeing are the programmers *using* the `Fraction` class. – Ben Aaronson May 21 '15 at 14:01
    @BenAaronson Immutability won't help you prove that you've implemented your type correctly (i.e. all operations preserve some given invariant.) What I'm saying is that it allows you to propagate facts about values. You encode some condition (e.g. this number is even) in a type (by checking for it in the constructor) and the value produced is proof that the original value satisfied the condition. With mutable objects you check the current state and keep the result in a boolean. That boolean's only good for as long as the object isn't mutated so that the condition is false. – Doval May 21 '15 at 14:04
  • @BenAaronson: types are just conventions describing the use of data. In a language that provides classes and encapsulation, that convention is embedded in the class implementation. In a language that provides functions and simple collections, that convention is embedded in the function implementation. There's really no difference. – kdgregory May 22 '15 at 11:16
  • In your example, a 2-tuple is a `Fraction` only if it was produced by one of the "fraction" functions (or, as a more relaxed definition, can be used by them). Otherwise it's just a 2-tuple, with no special meaning. – kdgregory May 22 '15 at 11:17
  • @kdgregory Okay, well seen in that context the benefits I'm describing in the original question are the benefit of having to enforce invariants only in a small number of functions relating to a type, which all exist in the same library, and the benefit of knowing at design-time that all functions transforming/creating a type will respect that invariant. – Ben Aaronson May 22 '15 at 12:32
Some functional languages such as OCaml have built-in mechanisms to implement abstract data types therefore enforcing some invariants. Languages which do not have such mechanisms rely on the user “not looking under the carpet” to enforce the invariants.
Abstract data types in OCaml
In OCaml, modules are used to structure a program. A module has an implementation and a signature, the latter being a kind of summary of values and types defined in the module, while the former provides the actual definitions. This can be loosely compared to the diptych .c/.h familiar to C programmers.
As an example, we can implement the Fraction module like this:
# module Fraction = struct
  type t = Fraction of int * int
  let rec gcd a b =
    match a mod b with
    | 0 -> b
    | r -> gcd b r
  let make a b =
   if b = 0 then
     invalid_arg "Fraction.make"
   else let d = gcd (abs a) (abs b) in
     Fraction(a/d, b/d)
  let to_string (Fraction(a,b)) =
    Printf.sprintf "Fraction(%d,%d)" a b
  let add (Fraction(a1,b1)) (Fraction(a2,b2)) =
    make (a1*b2 + a2*b1) (b1*b2)
  let mult (Fraction(a1,b1)) (Fraction(a2,b2)) =
    make (a1*a2) (b1*b2)
end;;
module Fraction :
  sig
    val gcd : int -> int -> int
    val make : int -> int -> t
    val to_string : t -> string
    val add : t -> t -> t
    val mult : t -> t -> t
  end
This definition can now be used like this:
# Fraction.add (Fraction.make 8 6) (Fraction.make 14 21);;
- : Fraction.t = Fraction.Fraction (2, 1)
Anyone can produce values of the type fraction directly, bypassing the safety net built in Fraction.make:
# Fraction.Fraction(0,0);;
- : Fraction.t = Fraction.Fraction (0, 0)
To prevent this, it is possible to hide the concrete definition of the type Fraction.t like that:
# module AbstractFraction : sig
  type t
end = Fraction;;
sig
  type t
end
The only way to create an AbstractFraction.t is to use the AbstractFraction.make function.
Abstract data types in Scheme
The Scheme language does not have the same mechanism of abstract data types as OCaml does. It relies on the user “not looking under the carpet” to achieve encapsulation.
In Scheme, it is customary to define predicates like fraction? recognising values giving the opportunity to validate the input. In my experience the dominant usage is to let the user validate its input, if he forges a value, rather than to validate input in each library call.
There is however several strategies to enforce abstraction of returned values, like returning a closure which yields the value when applied or returning a reference to a value in a pool managed by the library – but I never saw any of them in practice.
Michaël Le Barbier
  • 2,025
