This question is related to both of these questions - Efficient try / catch block usage? and Dealing with error in data - Idempotent approach.
When I encounter a void while reading a GIS data file I throw an Exception. This Exception is a subclass of java.lang.Exception. The question is of what happens after the void data exception is reached. Post processing would require that I go to another URL where the void filled data file is available and then download that and then proceed to read it in.
From the "efficient-try-catch-block-usage" question it appears doing inside this the catch block is a strict NO. Would it better then instead of throwing an application specific exception it is better to check for a return code or a post condition and proceed to do the post processing ?
