I am writing a library for working with special types of trees, called Foo trees. A Foo tree has very special structure. There some operations, called bar and baz, which only make sense on Foo trees. So I'm designing a FooTree
class to represent Foo trees.
To construct a FooTree
instance, one might pass some object representing a tree. This object will be checked for special structure and stored internally:
class FooTree(object):
def __init__(self, tree):
... # check that tree is a valid Foo tree
self._tree = tree
def bar(self):
# operation that only makes sense on a foo tree
The problem is: what if I construct a FooTree
from a mutable object? For example, say Tree
is a type whose instances are mutable:
tree = Tree()
... # build a valid Foo tree
foo_tree = FooTree(tree)
tree.remove_node(0) # tree is no longer a Foo tree
Since tree
is no longer a valid Foo tree, and foo_tree
wraps a reference to tree
, foo_tree
is no longer valid.
Instead I might copy the tree when creating a FooTree
self._tree = tree.copy()
def bar(self):
This solves the problem, but creates a new one: Foo trees are typically very large, so copying them is expensive.
What patterns exist for creating FooTree
objects from Tree
objects, without copying and without the mutability problem?
For example, I might have FooTree
accept a callable which produces a Tree
class FooTreeBuilder(object):
def __init__(self, data):
self.data = data
def __call__(self):
tree = Tree()
... # build tree from self.data
return tree
def __init__(self, builder):
self._tree = builder()
builder = FooTreeBuilder(data)
foo_tree = FooTree(builder)
Are there any better approaches? I'm specifically looking for approaches that lend well to Python implementations.
