Often when translating between languages (whether with program translation or compiling) it's a one-way, destructive translation. The functionality of the "port" isn't lost, but some of the intent and expression is.
For instance, porting a program from Java to C is possible, but you lose the notion of classes and methods. If that program were to be ported back to Java you'd need to infer the intent of what would be considered an object to get back to the original state. And that's something that a computer isn't good at doing. As such you'd end up with a Java program that looked more like a C program with data structures and a big collection of static functions.
Also consider a compiler. Once a language has been compiled down to assembler or even to say CIL or JVM, concepts such as if statements are lost as they are turned into branches.
On a higher level, source to source translators exist, but some languages have features (i.e. delegates in C#) which don't exist in other languages (like Java not having delegates). The translation can happen, but is mildly destructive (i.e. Java would need a wrapper class to simulate delegates).
So, having said all that, is there a language who's goal is to be structurally compatible with all other languages by supporting all language features of all languages?
I'm not so concerned with being able to fully translate between languages as I am with being able to express each language's code in the common language. So the goal would be translating to the common language and back again to the source language without losing anything. Like: Java->Common->Java or LISP->Common->LISP
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
Sam Washburn
  • 163
    see [Are non Turing-complete languages considered programming languages at all?](http://programmers.stackexchange.com/questions/172979/are-non-turing-complete-languages-considered-programming-languages-at-all) and [Measure of power other than Turing completeness](http://programmers.stackexchange.com/questions/812/measure-of-power-other-than-turing-completeness) – gnat May 16 '15 at 19:36
    @gnat I don't see how this relates to Turing-completeness. I'm not interested in the translation process, just the one common language. – Sam Washburn May 16 '15 at 19:46
  • Okay, maybe you could create a common intermediate language for few of them most popular languages. But where do you stop? At Haskell? At all of its extensions? At [APL](https://en.wikipedia.org/wiki/APL_%28programming_language%29)? At [INTRECAL](https://en.wikipedia.org/wiki/INTERCAL)? At [Malbolge](https://en.wikipedia.org/wiki/Malbolge)? And would you keep updating your common intermediate language forever, as new languages are developed (and old ones updated)? – svick May 16 '15 at 21:05
    Also, you didn't answer the most important question: **Why?** What would be the point of such language existing, if the only thing it could do well would be to get back the code you already had? – svick May 16 '15 at 21:07
  • @svick I think at some point you'll hit a critical mass where all language features are supported. The common language doesn't have to support all language *syntax*, just features. Enough that you could trivially rebuild the syntax for the source language. – Sam Washburn May 16 '15 at 21:47
  • @svick Why? You could unify code projects easier for one. Though "Why?" is a different question, I'm just curious if such a thing exists. – Sam Washburn May 16 '15 at 21:51
  • @rwong I'm not sure any lowering would need to take place. – Sam Washburn May 17 '15 at 01:50
  • It can't exist. Trivially: a language with a finitely long specification must support finitely many features in it. Then, you can invent one which does not. For example, language FooBarBaz, that I just made up, does something special if the MD5 hash of the source file ends in a 5. Does your intermediate language support that flag? Probably not. If it does support that flag, then I just have to find another flag which it doesn't. – user253751 Feb 17 '20 at 10:36
Not particularly in practice. If you look at a tool like Reflector, it will happily turn CIL back into pretty accurate C# code, ifs and all.
No, because at that point we wouldn't need compilers or source translators since we have the One True Language. Sarcasm aside, this is effectively asking why we have different languages in the first place. Language features are not things that live in isolation. Providing one often hinders (or breaks) others. If there was a language that could provide the features of others without loss, why would we be using the others?
Telastyn
  • 108,850
  • 239
  • 365
    `If you look at a tool like Reflector, it will happily turn CIL back into pretty accurate C# code, ifs and all.` -- That's because CIL includes a substantial amount of metadata that helps reconstruct the original C#, including identifiers. This is not generally true of languages like C, whose compile process is *lossy.* – Robert Harvey May 16 '15 at 20:13
  • @RobertHarvey - sure, but even "substantial amount of metadata" isn't "100% of the information contained in the source language". – Telastyn May 16 '15 at 20:26
    Which is why Reflector isn't 100% accurate at reproducing the original source code. – Robert Harvey May 16 '15 at 20:27
    That's not quite the same question because there are some features we clearly *don't* want, like COMEFROM. – DeadMG May 16 '15 at 20:32
    @DeadMG: That's a trivial case; most of the time, language design is far more involved than that, and deals not with misfeatures but with features that are not quite good enough, or that have some wart that has a particularly unfortunate reaction with some other minor feature in the language, or the like. Look up, say, Eric Lippert's writings for a good idea of all the tradeoffs. Or Jonathan Shapiro's, if you want a less mainstream approach. – Nathan Tuggy May 16 '15 at 21:34
  • Telastyn, Can you give an example of one feature breaking another? Where the two features couldn't exist in parallel with each other? I'm not sure it's as common as you say. There are language choices, for sure, but everything compiles down to the same machine language at some point. – Sam Washburn May 16 '15 at 21:56
  • @SamWashburn - consider Erlang's concurrency model vs mutable state. – Telastyn May 17 '15 at 00:20
  • Concurrency is a good point. However, what about multiple concurrency options depending on how you code? As horrible as that sounds from a "pure language" vantage point, wouldn't that still work? Almost like using OpenCL with C. The GPU parts are massively parallel but the mutable C parts are full of semaphores. – Sam Washburn May 17 '15 at 00:50
  • @SamWashburn - `However, what about multiple concurrency options depending on how you code?` And how would this language know what concurrency options can be used with the various semantic options available? – Telastyn May 17 '15 at 01:12
  • By specifying it? Maybe the Erlang to Common translator specifies the type of concurrency to use. – Sam Washburn May 17 '15 at 01:43
  • @SamWashburn - And what happens when you need to encode Scala's specific concurrency semantics, or some new language you've never heard of. You're missing the point. You're asking why there is no informational superset of all languages. [There can be no such thing.](http://en.wikipedia.org/wiki/Russell%27s_paradox) – Telastyn May 17 '15 at 01:52
  • @Telastyn I don't see how Russell's paradox applies. This isn't a superset of all conceivable languages past-present-future, just all the ones currently implemented in the common language. If a new language is developed, you add any of it's unique features to the common language. And the common language exists as the superset and is not included in the set. I.e. the barber doesn't shave. Where's the paradox? – Sam Washburn May 17 '15 at 02:09
  • @SamWashburn - I suppose it doesn't since the common language isn't executable. Still, I don't see how a language that defines all of the unique semantics of languages in such an iterative way is going to be any more common or useful than having a bunch of source files with different extensions denoting the language they're written in. Anyways, if you're so deadset on your idea, go do it and prove me wrong. – Telastyn May 17 '15 at 02:26
  • @Telastyn I just may. :) But either way, you're right, it doesn't currently exist. Thanks for the good discussion. – Sam Washburn May 17 '15 at 02:27
  • @Nathan: Of course it's a simple example, but it proves the point and there's no need for a more complex one. – DeadMG May 17 '15 at 09:47
Some intermediate languages have been successfully used as target for a lot of various languages, e.g. LLVM (or Ramsey & Jones' C--, which might be a dead project in 2015).
Notice that an intermediate language does not carry all the information provided in the source language (e.g. you are losing information when compiling from C to LLVM).
However, I am not sure that your wish makes sense. There are some programming language features which are not compositional, or are a whole program thing. Eg continuations (you can't implement call/cc without some support from your intermediate language), exceptions, or even garbage collection or parallelism or homoiconicity or persistence or threads (or concurrency).
Notice that for your question programming language semantics matter much more than syntax. Of course, all these intermediate representations are theoretically Turing-equivalent e.g. to a RAM machine.
BTW, some people might believe that x86-64 machine code or JavaScript is actually what you want....
In 2020 consider also libgccjit or Gimple or even generating C code. See of course this answer and Bismon. In RefPerSys we want to generate C++ code
Basile Starynkevitch
  • 32,434
  • 84
  • 125
The only way for a conversion from language X to some intermediate language IL and back to be lossless is for IL to be a superset of X. If you want to have multiple languages as X, then IL has to be a superset of all of them.
Therefore, I would suggest that IL has the following structure:
delimiter: ---------SOMERANDOMSTRING----------
language: C
#include <stdio.h>
int main() { printf("hello world\n"); return 0; }
language: Java
public class Main { public static void main(String[] args) {
  System.stdout.println("hello world");
In other words, MIME-like embedding of the actual source code into the language. The "compiler" then has to parse apart the pieces and pass them to a proper processor for that language.
This obviously isn't useful.
Sebastian Redl
  • 14,950
  • 51
  • I mean lossless from a semantic standpoint. The syntax can vary so long as the original language can be reconstructed in a "pretty print" fashion. Do you still think this is the only solution? – Sam Washburn May 20 '15 at 05:09
  • @SamWashburn You'd have to have a language with every feature from every language, or at least features so powerful that they can represent every feature, along with annotations containing hint about what the original looked like. Such a language would be completely unusable for humans because of the learning curve involved, and the compiler would be incredibly massive. My solution is much easier to implement, even though it wasn't meant quite seriously. – Sebastian Redl May 20 '15 at 08:26
