21
I have to send a file (very large file) to a server. I'm studying what options I have and how to do it. I'm using angular + express + nodejs.
If I use a simple form, I could catch the file on the server using multer with no problem. Is very simple. The html is just a form, in which I specify the target etc. and everything works. The nodejs code is also very simple and straight forward.
As soon as I try to use angular, everything becomes incredible complicated. Meaning, I have to use a directive, and still have trouble with the server. As I said I'm using multer, which requires the data to be "multipart/form-data", and I get from the server "Error: Multipart: Boundary not found"
There are many modules to load files in angular. Which shows that is a recurrent problem with more than one solution. Now, I don't want to post code because for that I asked at Stack Overflow. My question is more subtle:
Why what can be done with a simple form, get's so complicated in angular? I don't mean it in a bad way. I mean it in a 'I want to understand' way.
cauchi
  • 1,192
  • is this somehow related to [your recent question at Stack Overflow](http://stackoverflow.com/q/30080966/839601)? "How do I solve the error 'Boundary not found' and what does it means..." – gnat May 06 '15 at 15:44
    Yes, that's why I put the link on the question. But here I don't want to solve the problem. I would like to know why is it a problem in the first place. – cauchi May 06 '15 at 15:51
Angular is for Single Page Applications, forms are sent using AJAX to avoid the page to be reloaded. For sending multipart forms with AJAX, your browser need to support FormData(IE10+): http://caniuse.com/#search=FormData
https://developer.mozilla.org/en-US/docs/Web/API/FormData
ngModel doesn't work with input[type="file"], so you have to create your own directive. Your own directive should be simple: on change, update a File object on your scope.
When sending your form, create a FormData object and add your file(s) to it using FormData.set or FormData.append. You can send your FormData with $http or $resource, and you are relying on the browser for setting the content-type and boundary.
var formData = new FormData();
formData.append('file', $scope.file);
$http.post('yourUrl', formData, {
   transformRequest: angular.identity,
   headers: {'Content-Type': undefined}
}).then(function () {
angular.identity prevents Angular to do anything on our data (like serializing it).
I recommend this article: https://uncorkedstudios.com/blog/multipartformdata-file-upload-with-angularjs
Thomas Roch
  • 396
