DRY exists for a reason, because the more places that the same code exists, the more chances there are of bugs arising from one of those places not being changed when the system needs to change. It is also, obviously enough, easier to test if you only have any given part of your code in one place. Consequently, in most cases where I need to do something more than once I will break it out into it's own function or method.
One place where I think repetition is alright, or even helpful, is when you have the same code working with different intents - so you might have a function or method that shows very similar behaviour, but in one place it is part of the system for retrieving a user from an authentication system and in another it is retrieving some data from a store. Even if the code is identical this can exist in different places because it is part of different flows and with these divergent intentions it is very likely that they will diverge at some point in functionality. If I was sharing the code at that point, I would have to make things more complex and less readable.
That said, if I have the same or very similar code in multiple places that starts to smell WET to me and I will certainly get to thinking about whether I could be abstracting the relevant behaviour in a way that would facilitate sharing.
