I am starting to design a typical product based MySQL database but I keep running in circles on how to design the tables.
I have many types of products
  • Jeans
  • Tshirts
  • Dresses
Which have many of the same attributes
  • Size
  • Price
  • Colour
But some of the products have specific attributes, like length or logo or package.
Do I make a separate table for every product even though many of the columns are the same, or do I make a general product table and then have some sub-tables for specific products?
Tulains Córdova
  • 39,201
  • 154
Berry Bonds 3
  • 101
    How many 'specific attributes' do you have? Is it an entirely known list? or are you going to get odd ball ones in there from time to time as new products are added? –  Apr 13 '15 at 21:06
  • I would imagine sizing information is different for jeans, t-shirts and dresses too... – h.j.k. Apr 14 '15 at 01:23
  • The reason I ask this is that its one thing to have a bunch of specific clothing related details if you are, say, a clothing store. On the other hand, if you are a general retailer, that level of detail of clothing fields isn't going to be applicable to the toy department, or home improvement, or automotive, or ... And thus you will want a more general solution across the board. But it would help to understand the nature of the product areas and range of items to be added. –  Apr 14 '15 at 03:24
Do not make a table for every product.
This problem has been solved many ways. Try this:
Make a product (or products) table, put your common product attributes in the product table, then make an attribute table and a productattribute table, something like:
attribute
attributeId
attributeName
attributeDescription
productattribute
productId
attributeId
attributeValue
Then you can assign arbitrary attributes to your products.
You can take the schema a little further if you like, using:
attribute
attributeId
attributeName
attributeType // [float, int, varchar, etc.]
productAttribute
productId
attributeId
attributeValueFloat
attributeValueInt
attributeValueVarChar
This technique complicates your schema a bit, so be aware of what you are getting into if you decide to use the extra columns to store values by data type.
An alternative that might just suit your needs a little better would be to use a NoSQL Store like MongoDB for your products. Then you can store the attributes you need for each type of product without resorting to the complexity of a relational database schema.
Robert Munn
  • 1,221
One approach would be to design your database similar to how you would define a class hierarchy, where you define base table(s) (classes) that provide the common attributes, and then you add additional tables that provide specific attributes to extend the table to the specific products.
Define a base product table
create table Products_base as
    id
    item
    brand
    model
    description
    size
    color
    price #more about this later
Define additional tables for products that differ substantially
create table pants as
    base #foreign key to base product
    waist
    length
    material
    style
create table dress as
    base #foreign key to base product table
    waist
    hemlength
    bust
    material
    belt
Another approach would be to define the base product table, and then define an attributes table, and provide the attributes for each additional product,
    id autoincrement
    item
    brand
    model
    description
    size
    color
create table attributes as
    id autoincrement
    name
    description
create table product_+attributes as
    product_id #product.id
    attribute_id #attributes.id
    value
Using pants as an example, you would want to add attributes to pants (add to the attributes table)
"length", "length of item"
"inseam", "length of inseam"
"style", "style of article" #example, "jeans"
#etc
And then you would add values for the attributes
product.id("pants"), attribute.id("inseam"), "32in"
product.id("pants"), attribute.id("waist"), "34in"
product.id("pants"), attribute.id("style"), "jeans"
product.id("dress"), attribute.id("style"), "sundress"
#etc
ChuckCottrill
  • 525
