make
(the tool or direct use of it via a Makefile) is not outdated, particularly for "small, personal projects" as you use it for.
Of course, you can also use it for larger projects, including those targeted for multiple platforms. With target-specific variables you can easily customize how you build for different platforms. Nowadays, Linux distributions come with cross-compiling toolchains (e.g. mingw-w64) so you can build a complete Windows software package (with installer if you like) from Linux, all driven from your Makefile.
Tools like cmake and qmake can be useful, but they are not without their problems. They are usually fine for building an application itself along with any libraries (though I always had problems with qmake doing proper dependency checking between libraries and programs that use them), but I always struggle with the constraints of those tools when doing the rest of the job (creating installers, generating/installing documentation or translation files, doing unusual stuff like turning an archive into a shared library, etc.). All of this can be done in make
, though things like dependency tracking can require a little effort.
IDEs like Qt Creator and Eclipse can also import Makefile-based projects, so you can share with IDE-using developers. I think the Qt Creator IDE is excellent as a C++ IDE, but after spending some time to become more effective with Emacs, and since I'm doing more Ada development, I'm finding myself preferring Emacs for everything. To relate back to the question about make
, as a post-link step in my Makefile, I update my TAGS file (for symbol navigation in Emacs), loaded with M-x visit-tags-table
find $(SRC_DIR) $(TEST_DIR) -regex ".*\.[ch]\(pp\)?" -print | etags -
Or for Ada development:
find $(SRC_DIR) $(TEST_DIR) -name "*.ad?" -print | etags -
