-2
I have a function for which the complexity raise by the square ten of the exponent of the number.
Ex:
|Input|Complexity|
|0    |     1    |
|10   |     2    |
|100  |     3    |
|123  |     3    |
|1001 |     4    |
|9999 |     4    |
|10000|     5    |
|99999|     5    |
How to express its complexity in big O notation ?
Antzi
  • 105
    ...and not nearly enough information to perform a real Big-Oh analysis. –  Apr 02 '15 at 17:23
  • I started editing the question to fix the grammar when I realized that the question would answer itself. Hint: if you define the relationship between "Input" and "Complexity" you will come up with the most likely answer, although the proof will be an analysis of the actual code. –  Apr 02 '15 at 17:40
The mathematical function that is like that is log n. So the big O notation would be O(log n).
Becuzz
  • 4,815
  • Log(n) is indeed very very close to the expected result, but slightly above. When giving a Big O notation, is it expected to be a (pretty accurate) approximation ? – Antzi Apr 02 '15 at 18:01
