Deciding whether an object should request data (by calling a function) or receive data (by having a function called from another object) is probably dependent on the exact situation. So how do I decide how to handle this?
If a specific example could help:
I'm currently designing an app using the Kinect camera. I want to split the signal and pass it to multiple objects that process the data (there is some bookkeeping involved, because I need to dispose a frame before requesting the next one). What should I do? Get data from the Kinect and store it, so other objects can request it? Or should I pass the data to the objects that need it?
A drawing with generic names, arrows indicate how data should flow:
Kinect ---> KinectManager |---> DataProcessor
|---> DataHandler
|---> DataSomething
My suspicion is the first case, because then I could have different objects request data, without KinectManager having to know about the objects. Though in the second case I could design an Interface with, for example, an Update() method that receives Kinect Data.
