27
When I split big methods (or procedures, or functions — this question is not specific to OOP, but since I work in OOP languages 99% of the time, it's the terminology that I'm most comfortable with) into a lot of small ones, I often find myself displeased with the results. It becomes harder to reason about these small methods than when they were just blocks of code in the big one, because when I extract them, I lose a lot of underlying assumptions that come from the context of the caller.
Later, when I look at this code and see individual methods, I don't immediately know where are they called from, and think about them as ordinary private methods that can be called from anywhere in the file. For example, imagine an initialisation method (constructor or otherwise) split into a series of small ones: in the context of method itself, you clearly know that object's state is still invalid, but in an ordinary private method you probably go from assumption that object is already initialised and is in a valid state.
The only solution I've seen for this is the where clause in Haskell, which allows you to define small functions that are used only in the "parent" function. Basically, it looks like this:
len x y = sqrt $ (sq x) + (sq y)
    where sq a = a * a
But other languages I use don't have anything like this — the closest thing is defining a lambda in a local scope, which is probably even more confusing.
So, my question is — do you encounter this, and do you even see this is a problem? If you do, how do you typically solve it, particularly in "mainstream" OOP languages, like Java/C#/C++?
Edit about duplicates: As others noticed, there are already questions discussing splitting methods and small questions that are one-liners. I read them, and they don't discuss the issue of underlying assumptions that can be derived from caller's context (in example above, object being initialised). That's the point of my question, and that's why my question is different.
Update: If you followed this question and discussion underneath, you might enjoy this article by John Carmack on the matter, in particular:
Besides awareness of the actual code being executed, inlining functions also has the benefit of not making it possible to call the function from other places. That sounds ridiculous, but there is a point to it. As a codebase grows over years of use, there will be lots of opportunities to take a shortcut and just call a function that does only the work you think needs to be done. There might be a FullUpdate() function that calls PartialUpdateA(), and PartialUpdateB(), but in some particular case you may realize (or think) that you only need to do PartialUpdateB(), and you are being efficient by avoiding the other work. Lots and lots of bugs stem from this. Most bugs are a result of the execution state not being exactly what you think it is.
Max Yankov
  • 901
  • possible duplicate of [Is it OK to split long functions and methods into smaller ones even though they won't be called by anything else?](http://programmers.stackexchange.com/questions/195989/is-it-ok-to-split-long-functions-and-methods-into-smaller-ones-even-though-they) – gnat Mar 23 '15 at 10:16
  • see also: [How do you decide what code to put into a function?](http://programmers.stackexchange.com/questions/200089/how-do-you-decide-what-code-to-put-into-a-function) – gnat Mar 23 '15 at 10:16
  • @gnat the question you linked to discusses whether or not to extract functions at all, while I don't question it. Instead, I question the most optimal method to do it. – Max Yankov Mar 23 '15 at 10:18
  • one may argue that conceptually, this has been addressed in [How would you know if you've written readable and easily maintainable code?](http://programmers.stackexchange.com/a/141010/31260) If your peers keep complaining about your way of doing things, you better change to make them feel better – gnat Mar 23 '15 at 10:19
    @gnat there are other related questions linked from there, but none of these discuss the fact that this code may rely on specific assumptions that are valid only in caller's context. – Max Yankov Mar 23 '15 at 10:19
  • @gnat this question has nothing to do about my peers; also, I've added an edit about why this question is not about duplicate of the ones you linked. – Max Yankov Mar 23 '15 at 10:22
  • edited question sounds more like a duplicate of: [How do you balance out code structuring (few big functions vs. many small ones)?](http://programmers.stackexchange.com/q/201130/31260) (side note, asking about "mainstream" OOP languages makes me wonder why doesn't it have respective tags) – gnat Mar 23 '15 at 10:59
  • @gnat That question is about finding a balance between granularity and readability. There's some common ground, but I believe this question addresses a subtly different issue: "associating" a helper function with its beneficiary in languages that don't provide a mechanism for this (which is most of the popular ones.) – Doval Mar 23 '15 at 11:22
  • @Doval as far as I can tell, [top answer](http://programmers.stackexchange.com/a/201136/31260) in the question I referred addresses this, by pointing out to cohesion principle – gnat Mar 23 '15 at 11:40
  • @gnat Cohesion doesn't address the problem; a class may be perfectly cohesive (e.g. all the methods are clearly related to the class's purpose and they all use all of the class's instance variables) yet each method may still need one or two helper functions that won't be used by any of the other methods. – Doval Mar 23 '15 at 11:49
    @Doval in my experience, it really does. When there are troublesome helper methods hanging around like you describe, extracting a new _cohesive_ class takes care of this – gnat Mar 23 '15 at 11:53
  • @gnat I think this question is closer to "Is it OK to split long functions and methods into smaller ones even though **they don't preserve the class invariants**?" – CodesInChaos Mar 23 '15 at 15:17
  • Relevant: [Is it always a best practice to write a function for anything that needs to repeat twice?](http://programmers.stackexchange.com/q/269882/11833) – user541686 Mar 24 '15 at 00:21
6 Answers6
29
For example, imagine an initialisation method split into a series of small ones: in the context of method itself, you clearly know that object's state is still invalid, but in an ordinary private method you probably go from assumption that object is already initialised and is in a valid state. The only solution I've seen for this is...
Your concern is well-founded. There is another solution.
Take a step back. What fundamentally is the purpose of a method? Methods only do one of two things:
  • Produce a value
  • Cause an effect
Or, unfortunately, both. I try to avoid methods that do both, but plenty do. Let's say that the effect produced or the value produced is the "result" of the method.
You note that methods are called in a "context". What is that context?
  • The values of the arguments
  • The state of the program outside of the method
Essentially what you are pointing out is: the correctness of the result of the method depends on the context in which it is called.
We call the conditions required before a method body begins for the method to produce a correct result its preconditions, and we call the conditions which will be produced after the method body returns its postconditions.
So essentially what you are pointing out is: when I extract a code block into its own method, I am losing contextual information about the preconditions and postconditions.
The solution to this problem is make the preconditions and postconditions explicit in the program. In C#, for instance, you could use Debug.Assert or Code Contracts to express preconditions and postconditions.
For example: I used to work on a compiler which moved through several "stages" of compilation. First the code would be lexed, then parsed, then types would be resolved, then inheritance hierarchies would be checked for cycles, and so on. Every bit of the code was very sensitive to its context; it would be disastrous, for instance, to ask "is this type convertible to that type?" if the graph of base types was not yet known to be acyclic! So therefore every bit of code clearly documented its preconditions. We would assert in the method that checked for type convertibility that we had already passed the "base types acylic" check, and it then became clear to the reader where the method could be called and where it could not be called.
Of course there are lots of ways in which good method design mitigates the problem you've identified:
  • make methods that are useful for their effects or their value but not both
  • make methods that are as "pure" as possible; a "pure" method produces a value that depends only on its arguments, and produces no effect. These are the easiest methods to reason about because the "context" they need is very localized.
  • minimize the amount of mutation that happens in program state; mutations are points where code gets harder to reason about
Eric Lippert
  • 45,799
  • 87
  • 126
  • +1 for being the answer that explains the problem in terms of preconditions/postconditions. – QuestionC Mar 23 '15 at 21:21
    I would add that it's often possible (and a good idea!) to delegate checking pre-and post-conditions to the type system. If you have a function that takes a `string` and saves it to the database, you're at risk of SQL injection if you forget to clean it. If, on the other hand, your function takes a `SanitisedString`, and the only way to get a `SantisiedString` is by calling `Sanitise`, then you've ruled out SQL injection bugs by construction. I increasingly find myself looking for ways to make the compiler reject incorrect code. – Benjamin Hodgson Mar 23 '15 at 21:34
  • +1 One thing that's important to note is that there is a cost to splitting up a big method into smaller chunks: it's typically not useful unless the preconditions and postconditions are more relaxed than they would have been originally, and you can end up having to pay the cost by re-doing checks that you would have otherwise already done. It's not a completely "free" refactoring process. – user541686 Mar 24 '15 at 01:02
  • "What is that context?" just to clarify, I mostly meant private state of the object that this method is called on. I guess it's included in the second category. – Max Yankov Mar 24 '15 at 08:29
  • This is an excellent and thought-provoking answer, thank you. (Not to say that other answers are in any way bad, of course). I won't mark the question as answered just yet, because I really like the discussion here (and it tends to cease when answer is marked as answered) and need time to process it and think about it. – Max Yankov Mar 24 '15 at 08:31
13
I often see this, and agree that it is a problem. Usually I resolve it by creating a method object: a new specialized class whose members are the local variables from the original, too-large method.
The new class tends to have a name like 'Exporter' or 'Tabulation', and it gets passed whatever information is necessary to do that particular task from the larger context. Then it is free to define even smaller helper code snippets that are in no danger of being used for anything but tabulating or exporting.
Kilian Foth
  • 107,706
  • 45
  • 295
  • 310
  • I really like this idea the more I think about it. It can be a private class inside the public or internal class. You don't clutter up your namespace with classes that you only care about very locally, and it is a way to mark that these are "constructor helpers" or "parse helpers" or whatever. – Mike Mar 23 '15 at 13:46
  • Recently I was just in a situation that would be ideal for this from architecture perspective. I wrote a software renderer with a renderer class and a public render method, which had a LOT of context that it used to call other methods. I contemplated creating a separate RenderContext class for this, however, it just seemed enormously wasteful to allocate and deallocate this project every frame. https://github.com/golergka/tinyrenderer/blob/master/src/renderer.h – Max Yankov Mar 24 '15 at 08:34
Many languages let you nest functions like Haskell. Java/C#/C++ are actually relative outliers in that regard. Unfortunately, they are so popular that people come to think, "It has to be a bad idea, otherwise my favorite 'mainstream' language would allow it."
Java/C#/C++ basically think a class should be the only grouping of methods you ever need. If you have so many methods that you can't determine their contexts, there are two general approaches to take: sort them by context, or split them by context.
Sorting by context is one recommendation made in Clean Code, where the author describes a pattern of "TO paragraphs." This is basically putting your helper functions immediately after the function that calls them, so you can read them like paragraphs in a newspaper article, getting more details the further you read. I think in his videos he even indents them.
The other approach is to split your classes. This can't be taken very far, because of the annoying need to instantiate objects before you can call any methods on them, and inherent problems with deciding which of several tiny classes should own each piece of data. However, if you've already identified several methods that really only fit in one context, they are probably a good candidate to consider putting into their own class. For example, complex initialization can be done in a creational pattern like builder.
Karl Bielefeldt
  • 146,727
  • 38
  • 279
  • 479
  • Nesting functions... isn't that what lambda functions achieve in C# (and Java 8)? – Arturo Torres Sánchez Mar 23 '15 at 16:08
  • I was thinking more like a closure defined with a name, like [these python examples](https://realpython.com/blog/python/inner-functions-what-are-they-good-for/). Lambdas are not the clearest way to do something like that. They're more for short expressions like a filter predicate. – Karl Bielefeldt Mar 23 '15 at 16:12
  • Those Python examples are certainly possible in C#. For example, the [factorial](https://gist.github.com/R2D221/d4d9110255fa0726369a). They may be more verbose, but they are 100% possible. – Arturo Torres Sánchez Mar 23 '15 at 16:25
    No one said it wasn't possible. The OP even mentioned using lambdas in his question. It's just that if you extract a method for the sake of readability, it would be nice if it were more readable. – Karl Bielefeldt Mar 23 '15 at 16:34
  • Your first paragraph seems to imply it's not possible, especially with your quote: "It has to be a bad idea, otherwise my favorite 'mainstream' language would allow it." – Arturo Torres Sánchez Mar 23 '15 at 16:54
  • `Function sq = a -> a*a;`. How is this any different from the example given? (apart from the verbose `Function` which is unavoidable in a strongly and explicitly typed language) – k_g Mar 23 '15 at 22:29
  • You can also nest functions in C using gcc (but I don't know if that's a language thing or a gcc extension) – Izkata Mar 23 '15 at 23:56
I think the answer in most cases is context. As a developer writing code, you should assume your code is going to be changed in the future. A class might be integrated with another class, might replace it's internal algorithm, or might be split off to several class in order to create abstraction. Those are things beginner developers usually don't take into consideration, causing a need for messy workarounds or complete overhauls later.
Extracting methods is good, but to some degree. I always try to ask myself these questions when inspecting or before writing code:
  • Is this code only used by this class/function? will it stay the same in the future?
  • If I'll need to switch out some of the concrete implementation, can I do it easily?
  • Can other developers on my team understand what's done in this function?
  • Is the same code used somewhere else in this class? you should avoid duplication in almost all cases.
In any case, always think single responsibility. A class should have one responsibility, it's functions should serve one single constant service, and if they do a number of actions, those actions should have their own functions, so it's easy to differentiate or change them later.
Tomer Blu
  • 41
I didn't realize how big of a problem this was until I adopted an ECS which encouraged bigger, loopy system functions (with systems being the only ones having functions) and dependencies flowing towards raw data, not abstractions.
That, to my surprise, yielded a codebase so much easier to reason about and maintain compared to the codebases I worked in during the past where, during debugging, you had to trace through all kinds of teeny little functions, often through abstract functions calls through pure interfaces leading to who knows where until you trace into it, only to spawn some cascade of events which lead to places you never thought the code should ever lead.
Unlike John Carmack, my biggest problem with those codebases wasn't performance since I never had that ultra-tight latency demand of AAA game engines and most of our performance issues related more to throughput. Of course you can also start to make it more and more difficult to optimize hotspots when you're working in narrower and narrower confines of teenier and teenier functions and classes without that structure getting in the way (requiring you to fuse all these teeny pieces back to something bigger before you can even begin to effectively tackle it).
Yet the biggest issue for me was being unable to confidently reason about the system's overall correctness in spite of all tests passing. There was too much to take into my brain and comprehend because that type of system didn't let you reason about it without taking into account all these tiny details and endless interactions between tiny functions and objects that were going on everywhere. There were too many "what ifs?", too many things that needed to be called at the right time, too many questions about what would happen if they were called the wrong time (which start to become raised to the point of paranoia when you have one event triggering another event triggering another leading you to all kinds of unpredictable places), etc.
Now I like my big ass 80-line functions here and there, as long as they're still performing a singular and clear responsibility and don't have like 8 levels of nested blocks. They lead to a feeling that there are less things in the system to test and comprehend, even if the smaller, diced up versions of these bigger functions were only private implementation details not able to be called by anyone else... still, somehow, it tends to feel like there's less interactions going on throughout the system. I even like some very modest code duplication, as long as it's not complex logic (say just 2-3 lines of code), if it means less functions. I like Carmack's reasoning there about inlining making that functionality impossible to call elsewhere in the source file. There's something there to it when you have a shallower call stack and bigger, meatier functions and objects... a "flatter" system, not a "deeper" one.
Simplicity doesn't always reduce complexity at the big picture level if the option is between one meaty function vs. 12 uber-simple ones which call each other with a complex graph of dependencies. At the end of the day you often have to reason about what goes on beyond a function, have to reason about what these functions add up to ultimately do, and it can be harder to see that big picture if you have to deduce it from the smallest puzzle pieces.
Of course very general-purpose library type code that's well-tested can be exempt from this rule, since such general-purpose code often functions and stands well on its own. Also it tends to be teeny compared to the code a bit closer to the domain of your application (thousands of lines of code, not millions), and so widely applicable that it starts to become a part of the daily vocabulary. But with something more specific to your application where the system-wide invariants you have to maintain go far beyond a single function or class, I tend to find it helps to have meatier functions for whatever reason. I find it much easier working with bigger puzzle pieces in trying to figure out what's going on with the big picture.
I don't think it's a big issue, but I agree it's troublesome. Usually I just place the helper immediately after its beneficiary and add a "Helper" suffix. That plus the private access specifier should make its role clear. If there's some invariant that doesn't hold when the helper is called, I add a comment in the helper.
This solution does have the unfortunate drawback of not capturing the scope of the function it helps. Ideally your functions are small so hopefully this doesn't result in too many parameters. Normally you'd solve this by defining new structs or classes to bundle up the parameters, but the amount of boilerplate required for that can easily be longer than the helper itself, and then you're back where you started with no obvious way of associating the struct with the function.
You already mentioned the other solution - define the helper inside the main function. It may be a somewhat uncommon idiom in some languages, but I don't think it'd be confusing (unless your peers are confused by lambdas in general). This only works if you can define functions or function-like objects easily though. I wouldn't try this in Java 7, for example, since an anonymous class requires introducing 2 levels of nesting for even the smallest "function". This is as close to a let or where clause as you can get; you can refer to local variables before the definition and the helper can't be used outside of that scope.
Doval
  • 15,347
  • 43
  • 58
