I am currently working with Java 8 and using functional interfaces a lot. I often find myself writing code like this:
public interface MessageHandler extends Consumer<String> { }
Is this a good idea or an indicator of me abusing functional interfaces to make Java feel more like C#?
Edit: Maybe to expand a little:
public class MessageGenerator {
    public void registerMessageHandler(MessageHandler handler) {
Janis F
  • 143
    But typing is implicit anyway, right? It's just `registerMessageHandler((str) -> doSomething(str))` one way or the other, no? Where is it that you benefit from having aliased the `Consumer`? Finding usages? – Konrad Morawski Mar 23 '15 at 09:19
    "...abusing ... to make Java feel more like C#" - but is it a bad thing? C# team approves C# being abused to feel more like F#, and Java-style annotations were added to TypeScript (not C#-style). Pick and mix the best. – Den Mar 23 '15 at 09:23
I wholeheartedly agree with this:
Interfaces should almost always be named after what they do, not after some generic syntactic idea.
(Taken from this answer: https://softwareengineering.stackexchange.com/a/276866/41811)
So, adding a functional interface whose name explains precisely what the underlying Consumer<String> is going to be used for is a very good idea. It harms nothing, and it improves readability.
Mike Nakis
  • 32,003
  • 76
  • 111
Anything that makes code more readable while keeping the semantics unchanged is good. Whether or not this is due to your experience with another language is irrelevant - programming languages are tools to achieve ends, not values in themselves.
Therefore, if your way of writing things reads better than using the bare language-provided types, do it. (Things could be different if adding another layer of types affected the efficiency of the code that is actually run, but I'm fairly certain that in this case it doesn't.)
Kilian Foth
  • 107,706
  • 45
  • 295
  • 310
  • I do generally agree, but breaking established patterns is actually language dependent, and can be a bad thing despite increased readability. In essence, what I do boils down to a substitute for declaring a delegate signature in code (which you can't do in Java). – Janis F Mar 23 '15 at 08:54
